    Membro Avatar de Supervitao
    Raikkonen #7
    Nov 2005
    # Info para quem possui Notebook Toshiba #
    Estou aqui para alertar os usuários de Notebook Toshiba (não todos, abaixo os modelos afetados), para que não sofram do mesmo perereco o qual passei durante todo o mês de Junho.
    É o seguinte: Alguns modelos da Toshiba, sofrem de um mal proveniente de um bug da bios. Simplesmente do nada, o notebook não passa da inicialização, e passa a pedir uma senha da bios, a qual não existe. É um bug relatado pelo site da Toshiba:
    "The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
    If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
    The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you."
    Resumindo em poucas palavras: Quando este problema ocorre, a única solução seria enviar o equipamento para o Provedor de Serviço Autorizado Toshiba. Os modelos afetados são os seguintes:
    Satellite A100-SP471, A105-S4364, A100-ST8211, A100-ST1042, A100-ST1041, A105-S4001, A105-S4002, A105-S4004, A105-S4011, A105-S4014, A105-S4022, A105-S4074, A105-S4104, A105-S4054, A105-S4102, A105-S4124, A105-S4114, A105-S4132, A105-S4134, A105-S4064, A105-S4024, A105-S4144, A105-S4342, A105-S4284, A105-S4274, A105-S4254, A105-S4244, A105-S4214, A105-S4204, A105-S4211, A105-S4201, A105-S45472, A105-S4547, A105-S4397, A105-S4374, A105-S4384, A105-S4334, A105-S4324, A105-S4304, A105-S4294, A105-S4344, A105-S4092, A105-S4084, A105-S4184, A105-S4194, A105-S4174, A105-S4164, A105-S4154, A105-S4034, A105-S4094, A105-S4051, A105-S4031, A105-S4021, A105-S4012, A130-ST1311, A130-ST1312, A130-ST1313, A135-S2246, A135-S2256, A135-S2266, A135-S2326, A135-S2336, A135-S2356, A135-S4637, A135-S2426, A135-S2396, A135-S2386, A135-S4527, A135-S2346, A135-S2376, A135-S2276, A135-S2286, A135-S2296, A135-S2306, A135-S4407, A135-S4417, A135-S4427, A135-S4437, A135-S4447, A135-S4457, A135-S4467, A135-S4477, A135-S4487, A135-S4507, A135-S4478, A135-S4488, A135-S4498, A135-S4499, A135-S4517, A135-S4656, A135-S4666, A135-S4677, A135-S4727, A200-ST2041, A200-ST2042, A205-S4537, A205-S4557, A205-S4567, A205-S4577, A205-S4578, A205-S4587, A205-S4597, A205-S4607, A205-S4617, A205-S4618, A205-S4629, A205-S4638, A205-S4639, A205-S4707, A205-S4787, A205-S4797, A200-ST2043, A205-S4777, A205-S7442, A205-S7443, A205-S7456, A205-S7458, A205-S7459, A205-S7464, A205-S7466, A205-S7468, L35-S1054, L35-S2151, L35-S2161, L35-S2171, L35-S2174, L35-S2194, L35-S2206, L35-S2316, L35-S2366, L35-SP1011, M200-ST2001, M200-ST2002, M205-S3207, M205-S3217, P100-ST7111, P100-ST7211, P100-ST9212, P100-ST9612, P100-ST9412, P100-ST1071, P100-ST9732, P100-ST1072, P100-ST9762, P100-ST9772, P100-ST9752, P100-ST9742, P100-ST9712, P100-ST9012, P105-S921, P105-S9312, P105-S6074, P105-S6034, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6024, P105-S6054, P105-S6014, P105-S6004, P105-S6012, P105-S6002, P105-S931, P200-ST2071, P205-S6297, P205-S6298, P205-S6237, P205-S6247, P205-S6267, P205-S6287, P205-S6257
    Tecra A7-ST5112, A7-ST7711, A7-ST7712
    Raikkonen #7
    Nov 2005
    Continuando...
    Caso seu notebook seja um destes listados a cima, a recomendação da Toshiba é para que se faça a atualização da bios, um processo rápido, e que deixa livre do inconveniente.
    Esta semana, em um último ato para tentar resolver o problema do meu, um A135-S2386, desmontei todo o aparelho, afim de localizar a bateria da placa-mãe, que por sinal fica em um local de fácil acesso, embora se tenha de desmontar todo o equipamento.
    O que eu fiz, e deu certo, foi o seguinte: Enconstei uma chave de fenda nos contatos da bateria da placa-mãe, e liguei o notebook. De início ele aparece a tela normal pedindo a famosa senha inexistente. Passados 30 segundos, desliguei o aparelho e removi a chave de fenda.
    Esperei mais 2 minutos (o tempo para remontar as peças), e liguei o notebook. Para minha surpresa, ele entrou direto no setup, sem pedir a tal senha. Por sorte, dentro do drive tinha um cd de boot para atualizar a bios, que eu tinha baixado do site da Toshiba.
    Coloquei para dar boot no cd, atualizou a bios, e agora voltei a usar meu notebook normalmente, como se nada tivesse acontecido.
    A idéia de criar este tópico, é para alertar o pessoal que tem Toshiba, para que não venham a ter o mesmo problema que eu.
    Última edição por Supervitao : 05-07-2008 às 22:17
    Jun 2001
    Não tem como fazer um clear na bios não?
    See ya! []'s
    Raikkonen #7
    Nov 2005
    Citação Citando Kaworu Ver mensagem
    See ya! []'s
    A única forma que encontrei, foi desmontando, e ligando o notebook com uma chave de fenda encostada nos contatos da bateria da placa-mãe... e funcionou haha... estou usando meu notebook nesse exato momento.
    Em São Paulo, tem box na Sta Ifigênia que cobra R$ 150,00 para resolver o problema, e acredito eu, que o método utilizado é o mesmo.
    Abraço
    Jun 2001
    Citação Citando Supervitao Ver mensagem
    Abraço
    150 conto por um clear na bios com a perca da garantia? a pa puta que paril.
    See ya! []'s
