    cxc
    cxc está offline
    Membro Avatar de cxc
    Aug 2008
    que tipos de processadores essa placa aguenta?
    aguém sabe se essa placa mãe
    http://www.smartdata.com.br/sistema/...=8591130791026
    aguenta o processador pentium 4
    Aug 2008
    Veja as especificações da placa que está no site do fabricante:
    CPU LGA775 socket for latest Intel® Yorkfield/ Wolfdale/ Conroe/Core 2 Extreme/Core 2 Quad/Core 2 Duo/ Pentium Dual Core/ Celeron Dual Core/ Celeron 4xx processor
    FSB 1333/1066/800 MHz
    CHIPSET Intel® Eaglelake P45 & ICH10R North Bridge: Intel® Eaglelake P45 South Bridge: Intel® ICH10R
    MEMORY Dual-channel DDR2 memory architecture 4 x 240-pin DDR2 DIMM socket support up to 16GB Support DDR2 800/667 DDR2 SDRAM
    EXPANSION SLOT 2 x PCI Express x16 slots When using two VGA cards, the bandwidth is @8 badnwidth; when using one VGA card, the bandwodth is @16.
    2 x PCI Express x1 slots
    2 x PCI slots
    STORAGE Support by Intel® ICH10R
    6 x Serial ATAII 3.0Gb/s devices
    (Supports RAID 0, 1, 5, 10 ICH10R)
    Support by JMB 361
    1 x IDE channel support 2 Ultra DMA133/100/66 devices
    1 x eSATA
    AUDIO Realtek ALC883 7.1 Channel High Definition Audio codec
    LAN Gigabit LAN, Atheros L1 PCIe GigaLAN controller
    REAR PANEL I/O 1 x PS/2 keyboard & PS/2 mouse connectors
    6 x USB ports
    1 x RJ45 LAN connector
    1 x Audio port
    1 x Serial port (COM1)
    1 x Externel SATA connector
    INTERNAL I/O CONNECTORS & HEADERS CPUFAN/PWRFAN/SYSFAN connectors
    1 x IDE connector
    1 x FDD connector
    1 x Speaker header
    1 x SPDIF out header
    6 x Serial ATA connectors
    1 x Front panel switch/LED header
    1 x Front panel audio header
    1 x CD in header
    3 x USB 2.0 headers support additional 6 USB ports
    1 x Power button/1 x Reset button
    SYSTEM BIOS AMI BIOS with 8Mb SPI Flash ROM
    Supports Plug and Play, STR/STD, Hardware monitor, PCI interrupt selection, ACPI & DMI, CPU FSB adjustment (increase of 1MHz)
    Audio, LAN, can be disabled in BIOS
    F11 hot key for boot up devices option
    CPU voltage adjustable
    Memory voltage adjustable
    Support over-clocking
    FORM FACTOR ATX Size, 305mm*244mm
    Membro Avatar de DeDz
    iariaria dorgas
    ou seja suporta qualquer processador 775. Pentium 4 é 478.
    Membro Avatar de leo_bsb
    Nov 2007
    tem pentium 4 775 também.
    iariaria dorgas
    Citação Citando leo_bsb Ver mensagem
    que bagunça essa intel, nao sabia disso. My bad.
    May 1999
    Cara, esse placa da ECS é horrorosa para O/C.... não vale apena!!!!!
    Pega essa que é muito melhor
    http://www.terabyteshop.com.br/produ...?ProdutoID=452
    Membro Avatar de manisnk
    Ja chegou o disco voador!
    Jan 2006
    shuhasuhas inclusive tenho um P4 775 aqui rodando.
    Membro Avatar de #Stifler
    Citação Citando cxc Ver mensagem
    aproveitando o topico...
    Essa loja é confiavel ?? Me interessei por alguns itens !
    Citação Citando NoRRiTT Ver mensagem
    Cara a pergunta que o cara fez, o maluco não deve nem saber o que é O/C.
    Jan 2006
    Citação Citando NeNi Ver mensagem
    Sim, e confiavel.
    Membro Avatar de morphews
    Nov 2005
    Hehe eu tenho um Dell P4 530 comprei logo quando saiu o 1 P4 775! Ta até hoje vivo sem trocar nada nele hehe.
    Serve pra P4 sim.
