    Sep 2005
    Mini Review DFI Lanparty DK X48 T2RS
    Peguei essa mobo semana passada e resolvi fazer uns testes ae pro pessoal. A primeira coisa que se nota nela é o fato dela ser mt bonita os slots laranjas reagentes a luz negra assim como os cabos SATA dão um toq especial na mobo mas oq importa msmo é o overclock dela n é rs e foi mt facil chegar a 4ghz com ela foi praticamente de primeira oq é mt bom abaixo umas fotos dela e resultados dos testes preliminares
    A mobo
    Especificações
    LGA 775 socket for:
    - Intel® CoreTM2 Quad and Intel® CoreTM2 Duo
    Supports Intel Enhanced Memory 64 Technology (EMT64T)
    Supports Enhanced Intel SpeedStep Technology (EIST)
    Supports Intel Hyper-Threading Technology
    Supports 1600/1333/1066/800MHz FSB
    Chipset
    Intel chipset
    Northbridge: Intel X48 Express chipset (with Intel Fast Memory Access technology)
    Southbridge: Intel ICH9R
    Memory
    Four 240-pin DDR2 DIMM sockets
    Supports DDR2 667/800 MHz
    Delivers up to 12.8Gb/s bandwidth
    Supports dual channel (128-bit wide) memory interface
    Supports up to 8GB system memory
    Supports unbuffered x8 and x16 DIMMs
    Expansion Slots
    2 PCI Express (Gen 2) x16 slots (PCIE 1 and PCIE 3)
    2-way CrossFire at x16/x16 bandwidth
    1 PCI Express x4 slot (PCIE 2)
    3 PCI slots
    BIOS
    Award BIOS
    8Mbit flash memory
    CMOS Reloaded
    Audio
    Realtek ALC885 High Definition audio CODEC
    8-channel audio output
    DAC SNR/ADC SNR of 106dB/101dB
    Full-rate lossless content protection technology
    Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
    Hardware Monitor
    Monitors CPU/system/Northbridge temperature and overheat alarm
    Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    Monitors the speed of the cooling fans
    CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
    PCB
    6 layers, ATX form factor
    24.5cm (9.64") x 30.5cm (12")
    Sistema de Testes
    DFI LP DK X48 T2RS
    HD4870
    2x2gb OCZ Reaper 1066
    E8400 c\ Xigmatek HDT-S1283
    Super Pi 1M Stock
    Super Pi 1M 4ghz
    3dMark Vantage Stock
    3dMark Vantage 4ghz
    Foi mt facil subir o E8400 a 4ghz a bios da mobo tem mts opções para quem n conhece mt de over pode ser meio dificil no inicio mas dps fik tranquilo em relação ao vdroop n senti mt diferença ela variou cerca de 0,2v oq é normal
    No geral é uma excelente mobo mt estavel com otima performance e poder de over o bundle dela realmente deixa a desejar é bem simples somente cd com drivers cabos Sata e IDE , espelho e manual nada mais.Vou fazer mais testes para tentar atingir o FSB Wall dela dps posto mais fotos
    Nov 2004
    dfi é outra historia. Mobo de qualidade indiscutível.
    quanto menos merda vem junto, melhor. Assim o cara não paga por tranqueiras.
    aliás, quanto saiu a brincadeira aí ?
    Sep 2005
    kra eu peguei ela por R$ 690,00 vendi a minha Maximus Formula para pegar ela n axei um preço absurdo pela qualidade da mobo
    bom resultado,
    alias as DFIs deram uma sumidinha dos foruns brasileiros nos ultimos tempos hein?
    no s939 e fim de carreira do socket A so se falava em DFI...
    Membro Avatar de Trovalds
    Sopa de tartaruga!
    Citação Citando Serginho_J Ver mensagem
    Em qualidade de fabricação particularmente acho que elas são pau a pau com as gigabyte (pra mim giga são as melhores). Agora em matéria de over, como sempre as DFI Lan Party estão voltando à fama de "imbatíveis".
    Só para mostrar do que essa série é capaz:
    http://www.matbe.com/articles/lire/1...-overclocking/
    O site está em francês, mas já dá pra ter uma noção do que a série é capaz. Eles testaram a mesma DFI, mas com chipset P45, conseguiram "apenas" 680MHz de FSB com um E8600.
    Sep 2005
    Citação Citando Trovalds Ver mensagem
    O site está em francês, mas já dá pra ter uma noção do que a série é capaz. Eles testaram a mesma DFI, mas com chipset P45, conseguiram "apenas" 680MHz de FSB com um E8600 (claro, com refrigeração adequada).
    É a qualidade realmente fik pau a pau com a Gigabyte eu axo o controladore de voltagem da Gigabyte melhor no caso a DFI são so 4 fases sendo q a Gigabyte X48 tem 8 fases isso ajuda um poko na hora do over mas oq segura msmo as gigabytes são as bios axo mt ruims e essa DFI P45 ta pareo duro com a Biostar axo q mt gent vai preferir a DFI pelo nome mas ambas são mt boas
    Acho que essas DFI usam mosfets de maior qualidade, por isso nao precisa de tantos.
    Membro Avatar de Neon
    (¬'-')¬ C-('-'Q)
    esahuehawu tem opção demais, pqp... eu nunca parei pra mexer mt ali pq não faço over tao cabuloso [uso pc 24/7 e tals]
    tenho uma LanParty LT X48-T2R
    Sep 2005
    Essa sua LT é mais cavala ainda em over e tem mais opções tb rs e essa sua é akela q vai com o dissipador da Thermalright n é ?
    po 3mb de cache faz uma boa diferença hein?
    Aqui o [email protected] tá fazendo 13.010 no superPI 1MB.
    Sem contar que os 4Ghz vc conseguiu com um VCORE ridiculo. Aqui em 4GHz (9.5x420) tem que meter 1.5 no core. Resultado, o proc frita bonito.
    Sep 2005
    rs da uma diferença boa sim mas em performance msmo n muda nada em jogos vc ganha 2-3 fps rs
    Membro Avatar de Cardone
    Notei que essa mobo vem com o ICH9R, existe alguma grande diferença pros novos controladores ICH10R ?
    Sep 2005
    Kra eu realemente n sei qual a diferença rs
    (¬'-')¬ C-('-'Q)
    eh e nao eh. a fodidona mesmo eh a UT, o heatsink da termalright eh um heatpipe que liga o sb, nb e mosfets, com um puta hestsink que fica fora do case senao me engano. se nao fica fora, fica ai no paine trasero, com saida e tals (nunca vi ela num case)
    a minha eh mas humilde heuhee tem soh um heatsink tipo torre no n/b. creio que tb seja da TR
    o ich10r saiu junto com o p45, por isso as x48 vem com o 9. agora sobre diferencas, eu que ja usei os dois, nao sei te dizer pra falar a verdade, nao vejo diferencas desde o ich7r, jah que nao uso mt nenhuma funcao do s/b.
    Sep 2005
    O lance do ICH eu tb n sinto diferença nenhuma desde o 7 rs pra mim em uma mobo oq importa msmo é poder de over , qualidade de componentes isso é fundamental
    (¬'-')¬ C-('-'Q)
    sobre os heatsink, essa é a UT que eu falei:
    e essa é a LT (a que eu tenho):
    a foto é da X38, mas os heatsinks e layout são identicos, eu acho.
    os heatsinks da LT:
    [solto]
    e o do s/b dá pra ver na propria imagem dela de boa :P
    aqui a foto do meu pc, faz um bom tempo já [foi em maio - e tá melhor arrumado agora lol], troquei o cpu e as memos, mas o importante, dá pra ver que tá justo o espaço entre o TRUE e o cooler do n/b:
    Sep 2005
    Show de bola seu pc esse case é o Cosmos 1000
    hel
    hel está offline
    oi
    dfi é bacana, mas para intel to vendo que as gigabytes estão bombando.
    Sep 2005
    as Gigabyte tb estão mt boas as a sensação do momento é a Biostar quebrando varios recordes de FSB
