    Membro Avatar de al XerxeS
    Hp Dv6899es Vale A Pena?!?!?!
    bom galera eu tenho um camarada que veio da espanha e ta querendo me vender esse note pela bagatela de 2800!!
    oq vc"s acham?!?!
    segue a config dele!!
    Product Name dv6899es Product Number KU126EAMicroprocessor 2.10 GHz Intel Core 2 Duo processor T8100Microprocessor Cache 3 MB Level 2 cacheMemory 3072 (1 x 1024 MB + 1 x 2048 MB)Memory Max Up to 4 GB (Up to 1 GB may not be available due to 32-bit operating system resource requiements)Video Graphics NVIDIA Georce 8400M GSVideo Memory Up to 1535 MB (256 MB dedicated)Hard Drive 250 GB (5400)Multimedia Drive Blu-Ray ROM with SuperMulti DVD±R/RW Double LayerDisplay 15.4” WXGA High Definition BrightView Widescreen (1280 x 800)Fax/Modem High speed 56K modemNetwork Card Ethernet 10/100BT integrated network interfaceWireless Connectivity Intel PRO/Wireless 4965AGN Network Connection
    BluetoothSound Altec Lansing speakers
    3D Sound Blaster Pro compatible sound 16 bit integratedKeyboard 101 key compatiblePointing Device Touch Pad with On/Off button and dedicated vertical Scroll Up/Down pad, volume control, mute buttons, 2 Quick Launch ButtonsPC Card Slots
    • One ExpressCard/54 slot (also supports ExpressCard/34)
    External Ports
    • 5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro, or xD Picture cards
    • 3 USB 2.0
    • 1 VGA port
    • 1 HDMI connector
    • 1 RJ11 modem connector
    • 1 RJ45 ethernet connector
    • S-video TV out
    • 1 headphones-out
    • 1 mic-in
    • 1 IEEE 1394
    • remote control infrared port (remote optional)
    • cable docking connector
    Dimensions 35.70 cm (L) x 25.70 cm (W) x 2.54 cm (min H) / 3.96 cm (max H)Weight 3.10 kg (6.87 lbs)Power
    • 90 W AC Power Adapter
    • 6-cell Lithium-Ion (Li-Ion) battery
    What's In The Box HP Pavilion WebCam with Integrated Microphone
    HP Mobile Remote Control
    Melhor eu colar o link
    http://h10025.www1.hp.com/ewfrf/wc/d...reg_R1002_USEN#
    tipo eu to ate digitando dele aqui e talz.. ele deixo comigo...
    o unico impecilho que vejo eh o teclado espanhol
    eh fogo digitar os acentos e talz...
    mas a config eh boa!!!
    ele tem uma pintura meia cobre!! eh lindo e talz.. vem ate com um mouse da cor dele!!!
    POXA
    ´Prescisava saber ate as 15:00
    Membro Avatar de EuZaO
    o problema vai ser depois pra revender ele, com teclado em espanhol e tal...
    se ingles ja eh dificil de vender.
    2800 ?
    Sinceramente nao achei nenhuma bagatela nao. O note nao tem nada demais e ainda é pesado (3.1KG).
    Em outro tópico a gente montou um Dell menor 13.3" BEM mais leve e com config parecida (C2D 2GHz, 2GB de RAM, Ge-Force 8400m por 2300 reais. A unica coisa que esse da HP tem que o Dell nao tem é o leitor de Blue-Ray.
    Achei até relativamente caro pro que é esse HP que vc postou.
    Dá uma olhada nesse link antes de fechar negócio
    http://www1.la.dell.com/content/prod...310&l=pt&s=bsd
    por 2350 vc monta um C2D 2GHz, 2GB, 8400m, Wireless Intel, HD160GB pesando 1KG a menos que o HP.
    HMM....
    BLZ
    mas eu vou te far velho....
    o note eh a coisa mais linda uiaehaeiuh
    eh cobre com aço escovado
    Membro Avatar de durango_bh
    Notes da linha DV2000 Dv6000 e DV9000 estao com problemas no Chipset, necessita de atualizar a bios para resolver..
    E a garantia de fora nao cobre aqui no brasil.
    Cuidado com isso.
    Com esse valor tb nao arriscaria nao, pois nao tera garantia.
    Busque no www.buscape.com.br tem ofertas melhores ok.
    Abs
