    Membro Avatar de bernardosalomao
    Nov 2008
    HD4870 512mb ou HD48501gb ?
    Galera , gostaria de saber qual seria melhor ? Uma HD4870 512mb ou uma HD4850 1gb ?
    Olha as descrições :
    HD4870 :The ATI Radeon HD 4870 GPU brings the power of graphics supercomputing to gamers, setting a new standard for visual computing. Redefine the way you play and take HD gaming to the extreme with best-in-class performance. The new TeraScale graphics engine delivers an immersive, cinematic gaming experience. Add this GPU to your PC and watch Blu-ray movies and play HD content with incredible visual fidelity.* Do it all with break-through efficiency that doesn`t compromise performance.
    * TeraScale Graphics Engine
    The powerful new TeraScale graphics engine features deliver high resolutions and fast frame rates.
    * Enhanced Anti-Aliasing & Anisotropic Filtering
    High performance anisotropic filtering and 24x custom filter anti-aliasing (CFAA) smooth jagged edges and create true-to-life graphics, for everything from grass to facial features.
    * DirectX 10.1
    Play today while preparing for tomorrow with state-of-the-art DirectX 10.1 graphics capabilities.
    * ATI CrossFireX™ Technology
    ATI CrossFireX™ technology with up to quad GPU support offers superior scalability so your system is ready to level up when you are.
    * PCI Express 2.0
    Support for PCI Express 2.0 will prepare you for bandwidth-hungry games and 3D applications.
    * Power to Spare
    This GPU has the brute processing power needed for physics, artificial intelligence, stream computing and ray tracing calculations.
    # Display Output: Dual DL-DVI-I+HDTV
    # Core Clock: 750 MHz
    # Memory Clock: 900 MHz, 3.6Gbps
    # PCI Express 2.0 x16 bus interface
    # 512MB /256bit GDDR5 memory interface
    # Dual Slot Active Cooler
    # HDMI compliant via dongle
    # 7.1 Audio Channel Support
    # Microsoft® DirectX® 10.1 support
    # Shader Model 4.1 support
    HD4850 1gb
    Graphics Engine RADEON HD4850
    Video Memory 1GB GDDR3
    Engine Clock 625MHz
    Memory Clock 993MHz (1986Mbps)
    Memory Interface 256bit
    DirectX Support 10.1
    Bus Standard PCIE 2.0
    # 956 million transistors on 55nm fabrication process
    # 256-bit GDDR3
    # MicrosoftR DirectXR 10.1 support
    * ShaderModel 4.1
    * 32-bit floating point texture filtering
    * Indexed cube map arrays
    * Independent blend modes per render target
    * Pixel coverage sample masking
    * Read/write multi-sample surfaces with shaders
    * Gather4 texture fetching
    # Unified Superscalar Shader Architecture
    * 800 stream processing units
    o Dynamic load balancing and resource allocation for vertex, geometry, and pixel shaders
    o Common instruction set and texture unit access supported for all types of shaders
    o Dedicated branch execution units and texture address processors
    * 320 stream processing units
    * 128-bit floating point precision for all operations
    * Command processor for reduced CPU overhead
    * Shader instruction and constant caches
    * Up to 160 texture fetches per clock cycle
    * Up to 128 textures per pixel
    * Fully associative multi-level texture cache design
    * DXTC and 3Dc+ texture compression
    * High resolution texture support (up to 8192 x 8192)
    * Fully associative texture Z/stencil cache designs
    * Double-sided hierarchical Z/stencil buffer
    * Early Z test, Re-Z, Z Range optimization, and Fast Z Clear
    * Lossless Z & stencil compression (up to 128:1)
    * Lossless color compression (up to 8:1)
    * 8 render targets (MRTs) with anti-aliasing support
    * Accelerated physics processing
    Oq vcs tem ah dizer ?
    Email inválido
    Aug 2006
    4870 Ftw...
    Membro Avatar de TM99
    4870, certeza
    Pega a 4870 com 1gb, q é só uns 20 dolares mais cara q a 4870 normal.
    Citação Citando Angus Young Ver mensagem
    exatamente
    Membro Avatar de Cesar Romero
    Vo come a tia do Batima
    eu ficaria com a 4850 1gb, ja tem jogo q usa mais de 512 mb de memoria de video em dx10, crysis warhead é um exemplo
    vc vai ter belos framedrops com uma vga de 512mb, por mais poderosa q ela seja
    Membro Avatar de Pynot
    Apr 2008
    Sem pensar 2x a 4870
    hel
    hel está offline
    oi
    Citação Citando Pynot Ver mensagem
    é isto que estou pensando... fica melhor que uma 4870 X2, mas consome mais
    Citação Citando Danilo Borges Ver mensagem
    1GB de VRAM é pra HD5870/RV8xx,etc..
    É completamente inútil pra uma HD4850,placa do nível de uma 9800GTX+(e não de uma GTX280 )
    Crysis usa bastante VRAM mas nem por isso perde tanto desempenho.(só quando passa bastante da capacidade de VRAM,mas aí a HD4850 já nem tem capacidade mais pra uma desempenho aceitável)..
    Ngm vai usar uma HD4850 pra jogar Crysis em 1920x1200 ou 2560x1600 com Fitros no talo ,logo 512MB faz mto mais sentido..
    Levando isso em consideração,acho a HD4870 512MB mto mais negocio..
    Qndo ser normal precisar mesmo de 1GB de VRAM,pode ter certeza que RV770 já vai ser"lixo".
    Membro Avatar de leo_bsb
    Nov 2007
    pra esse seu monitor de 17" compre a 4850 de 512MB mesmo.
    Economize a grana pra trocar de monitor.
    Membro Avatar de migNAz
    falou tudo
    não esquece que uma gráfica é que nem um pc numa placa... o chip dela é o cpu e a memória é que nem a ram pro cpu... serve pra armazenar os dados que o chip processa... melhor um 8400 com 2gb do que um p3 com 8gb (exagero aqui mas... )
    se o que a memória da placa serve é armazenar as texturas pro chip processar e mandar pro monitor, então por exemplo vai depender do tamanho (qualidade) e quantidade (resolução) das texturas que são usadas, e no caso a 4850 como o dvsv falou, não vai passar de 1280x1024 (teu monitor já tá pedindo uma esticada prum novo de 22 wide) no melhor dos casos e então os 512 da 4870 vão ser mais do que suficientes e o chip dela processa bem mais dados do que a 4850, que os 512 adicionais vão ficar boiando...
    se fosse entre a 4870 512 ou 1gb, talvez valesse a pena se fosse pouca a dif (eu peguei pq foi o msm preço) pegar a de 1gb nem q fosse pelo valor comercial futuro ou pelo descargo de consciência
    obvio que no geral a 4870 512 é melhor, mas em alguns casos...
    ja temos jogos que gostam de vram, em resolução alta e filtros
    por exemplo FC2 em dx10
    note que em 1680x1050 com AA4x, a hd4850 1gb ja supera a 4870 512mb,
    http://www.bit-tech.net/hardware/200...-hd-4850-1gb/3
    ja no crysis nao... so que com monitor de 17"...
    hel
    hel está offline
    oi
    para mim a 4870 e 4850 é a mesma placa, 800 shadders e pá..só fazer um overzinho nela e tá igual, fui burro de pegar a 4870 em uma troca... vou tentar vender pra pegar 2x 4850.
    Membro Avatar de Cardone
    Citação Citando hel Ver mensagem
    Essa alta do dólar ta foda. Preços das placas está absurdo.
    overzinho nenhum faz a ddr3 chegar na ddr5 fiote...
    é... mas se voce jogar a 4850 a 800/1100 digamos, da para chegar a menos de 10% de distancia da 4870 em stock.
    edit: alias até com menos, 750 no core, sem OC na mem, ja faz chegar perto, a ddr5 nao da um "boost" gigante geralmente, acho que no geral a 4850 nao é tao limitada pela ddr3.
    Última edição por Spectrobozo : 01-12-2008 às 0:24
    Mas olha o framerate(31Fps média )
    mas 750 no core com o cooler stock da 4850 vc vai ter que ele deixar em 100% o tempo todo
    nao sei, é questao de testar,
    mas existem varias 4850 com cooler mais eficiente que o reference ja
    Oct 2007
    Pega uma 4870 1giga sem medo, popa muito da sua memoria ram, com 512, para rodar os games em altos, falta com uma de 512, procura 1giga, nao se arrependerá;
    4850, é muito inferior; menor força, tendo verba, vai de 4870 na veeeeeia.
    Abraz
