    Membro Avatar de Lorden Darkblade
    Jul 2006
    Coolers Silenciosos
    Galera eu tava querendo trocar os meus Ambers aqui.
    Eles realmente são sileciosos mas não ventilam nada. Especialmente os de 12cm, achei o fluxo desses MUITO baixo.
    Qual vocês me recomendam pra colocar no lugar deles?
    Preciso de coolers de 8cm e 12cm, se possivel com baixo ruído mas um bom fluxo de ar.
    Jun 2007
    http://www.silentpcreview.com/article832-page1.html
    O que achei melhor compra e comprei, foi esse:
    120mm Scythe SY1225SL12M "Slip Stream" Case Fan (68.54 CFM, 24 dBA)
    The Medium speed Slip Stream is probably the most sensible choice among the five. It spins reasonably fast at full speed and undervolts well, becoming effectively inaudible at 5V. It also has a very low starting voltage of only 2.4V. What impressed us most was how smooth and consistent the fan sounded, no matter what speed it was running at. At high speeds, a typical sleeve bearing fan drones and whines, and at low speeds it ticks or chatters. We listened very carefully for increasing and decreasing bearing/motor noise as the speed was adjusted, and the difference was minimal.
    As for performance, well, it was simply the best. Of all the fans we've tested at approximately 18-19 dBA, none could match the 24 CFM the Slip Stream M pushed, not even our reference Nexus fan. Interestingly, according to various reports, the Scythe Ninja Rev. B now ships with this exact fan model. Some heatsinks do not even come with fans, so for Scythe to include their best fan with the current Ninja gives us all sorts of warm and fuzzy feelings.
    Jul 2006
    Mas esse cooler se acha a venda no Brasil?
    Ou alguém importa ele?
    Ele realmente tem esse ruído baixo assim?
    Eu tava fazendo uma pesquisa e achei esse:
    FAN 120MM EVERCOOL SPIDER FILTER FAN SFF-12
    Sistema: Ever lubricate bearing
    Tamanho: 120 x 120 x 25mm
    Velocidade: 2000 R.P.M.
    Fluxo de ar: 80 CFM
    Vida-útil: 80000/hrs
    Conector: 4-3 pinos ( placa mae e fonte )
    Voltagem: 12V
    Ruído: 25.0 dB(A)
    Acompanha: 4 parafusos e 1 Fan Filter Spider
    Parece ser bom. Já a versão de 8cm não tem um fluxo muito maior que o Amber de 8cm.
    FAN 80MM EVERCOOL SPIDER FILTER FAN SFF-8
    Tamanho: 80 x 80 x 25mm
    Velocidade: 2500 R.P.M.
    Fluxo de ar: 32,5 CFM
    Voltagem: 12V
    Ruído: 20.0 dB(A)
    Alguém ai tem ou já testou um desses?
    Membro Avatar de dimo
    Da uma olhada nesses daqui:
    http://www.umpoukodetudo.com.br/prom...nm_cat=Noctua#
    São bons mas são caros, não sei quanto você está disposto a gastar.
    Th1ag0w
    Esse aqui tem vários reviews aprovando: coolermaster 90cfm @ 19dba.
    http://www.dhcp.com.br/product_info....oducts_id=1503
    Ele não tem realmente 90cfm, algumas pessoas dizem ter cerca de 70-75cfm, mas o preço é ótimo e ele é realmente muito silencioso.
    [ ]'s
    Jul 2006
    Citação Citando plagio Ver mensagem
    Esses Noctua de 12cm NF-P12-1300, se a informação de fluxo tiver certa, parece bom.
    Os de 8cm são pouca coisa melhor que os meus Amber dai já não sei se vale a pena...
    Bem que poderiam tá disponiveis...
    Citação Citando Th1ag0w Ver mensagem
    [ ]'s
    Foda é esse LED...
    Jun 2007
    [ ]'s
    90 CFM, 19DB e custando R$19,00 eu diria que é um tanto milagroso.. Você tem os links dos reviews que você leu?
    Geralmente algumas marcas (silenx é uma dela ) mudam a forma de medir as especificações das fans para mascarar os resultados. Por exemplo, se for medido apenas a fan em funcionamento sem nenhum obstáculo na frente, ela será bastante silenciosa. Mudando a posição do sensor também afeta drasticamente os resultados.. No link que passei no meu primeiro posto tem várias matérias (procure também umas mais antigas) com vários testes comparando todos usando a mesma forma de medição..
    Noctua são bons e realmente silenciosos, mas são muito fraquinhos.. (pelo menos eram na época que eu estava procurando os meus há uns 6 meses).
    Os que indiquei não sei se encontram a venda aqui no Brasil, eu importei o meu da petrastechshop.com. Se não quiser importar você mesmo, acho que dá para encomendar dos vendedores daqui do fórum..
    Sobre o noctua que postou acima, 92,3m³/h acredito que não seja 92,3 CFM.. Visto esse review aqui:
    http://www.silentpcreview.com/articl...e4.html#noctua
    onde ele diz: Airflow Rating 81 m³/h (48 CFM)
    Edit 2: De um forum português: "A 1 Cfm corresponde a 1,7 m3/h "
    NOCTUA NF-P12-1300
    54.3 cfm
    92,3m3/h
    e 19,8dB/A
    Última edição por eduardoll : 30-11-2008 às 12:51
    hel
    hel está offline
    oi
    eu uso noctua 50cfm, não vejo necessidade mais que isso.
    aliás eu paguei 20 dolares em cada que dá quase 45 reais sem o frete.. perto da waz que vende por 70 reais fiquei muito feliz.
    Jul 2006
    Citação Citando hel Ver mensagem
    50CFM em um de 12cm ou 8cm?
    Que se o de 12cm realmente tiver só isso acho que fico com meu Amber de 12cm que tem 44CFM.
    Não vai justificar a mudança pro Noctua.
    Já aqueles Evercool que eu postei acima, alguém sabe algo?
    Membro Avatar de luilui
    baixei R$130.00
    olha esse pacote, e é bom, é CoolerMaster .
    http://www.e-coyote.com.br/produtos/...com-4-unidades-
    espero ter ajudado.
    Jul 2006
    Acabei pegando os Evercool Spider de 8cm e 12cm.
    Assim que eles chegarem eu posto aqui o que achei deles.
    Membro Avatar de hirano
    hiranosan
    Nov 2007
    Tenho um desses spider, 80mm no gabinete, achei bom até.
    Mas o melhor que comprei até agora foi o Artic Cooling PWM, é barato e silencioso, com controle de velocidade. Achei tão bom que coloquei ele no meu Buffalo pra resfriar o Athlon. Muito melhor que o cooler stock do Buffalo.
    Esses fans PWM são os mais silenciosos, pq ajustam a velocidade de acordo com a necessidade. Vc pode comprar um desses pro gabinete e ligar naquele slot da mobo. Show de bola!
    Eu sou BEM chato com barulho.
    Tenho um Noctua de 12 q acho muito bom. Não ouço meu micro ligado.
    Ouvi falar bem tb dos SilentX.
    Nov 2008
    qualquer cooler master ótimo flow e nem se escuta ligado tenhu um de 12 que eh uma blz pode confiar...
    Membro Avatar de DeDz
    iariaria dorgas
    Akasa Ultraquiet nao é bom?
    Tinha um que botei numa Seventeam podre que o cooler original tinha morrido e gostei do resultado, a fonte esfriou mais e nem parecia q estava ligada.
    Membro Avatar de Moheekan
    Eu gosto dos Zalman, já tive vários, e estou tendo uma experiência boa com a Arctic Cooling também.
    abcs
    Esse da cooler master é bom.
    Nao dá pra se basear no CFM. Existem coolers para gabinete e pra processador. A diferenca é que um empurra o ar sem restricao e o outro com restricao. Essa é a diferenca entre esse da coolermaster90cfm e o da noctua50cfm.
    Nov 2008
    urgh.... nem se compara fan pra gabinete com fan para processador cada um eh pra uma coisa diferente ^^
    Membro Avatar de AccellX®
    abcs
    A questão é.. ele faz bastante vento?? pq ser silencioso é facil.. o dificil é ser silencioso e fazer vento..
    A Zalman se posiciona como uma marca que tem a melhor performance com o menor ruído possivel.
    O cooler da AC q eu tenho é um AC Freezer 64 Pro e segura meu dual core overclocado numa boa. E o fan é inaudível na rotação máxima, tem um sistema de fixação loki com borracha pra diminuir vibração e num sei q mais. O sistema também existe em algunas fans da marca.
    http://www.arctic-cooling.com/fans1.php
    abcs
    Jul 2006
    Citação Citando AccellX® Ver mensagem
    Exato!
    Se for pra ser silencioso os Amber já são. Mas também mal fazem vento.
    Os coolers devem chegar aqui até amanhã no máximo.
    Assim que eu instalá-los postarei aqui o que achei dos Evercool Spider.
    Jul 2006
    Os coolers chegaram ontem mas só tive tempo de monta-los hoje.
    Realmente o fluxo deles é BEM melhor que os Amber, mas obviamente, eles também fazem um pouco mais de ruído.
    Infelizmente acho que não existe cooler silencioso e com bom fluxo de ar.
    iariaria dorgas
    quais tu comprou afinal?
    Membro Avatar de In a RUSH
    Tough ain't enough!
    Citação Citando Lorden Darkblade Ver mensagem
    Pessoal, tenho uma hd4850 da power com o cooler padrão, aquele ruinzinho.
    Só q no inicio ele tava dando conta. Ficava a 35% em idle a uns 50 graus. E quando ia jogar mandava uns 75% o cooler e sussa. Agora ta cada vez mais alto. Tanto que tenho q manter uns 65% pra em idle ficar uns 55 graus. Eu acho que lotou de poeira o bixo. Então to bolando dois filtrinhos pras entradas de ar q eu possa trocar eles externamente.
    Paralelo a isso eu tenho duas fans de 12cm jogando ar pra dentro pela frente e pela lateral (em direção a vga) e elas são meia boca mas tdo bem. Só q não tem nenhuma TIRANDO o ar... e acho q isso contribui e muito pra aquele ar quente ficar bufando la dentro. To pensando em por um ou dois coolers de 80mm na traseira (pq tem espaço pra isso) pra tirar o ar... QUAL COOLER dentro desse nessa loja vcs me indicam?
    http://www.fgtec.com.br/coolers.htm
    http://www.wittech.com.br/catalogo.a...s)&sgrupo=CAPA
    Coloquei dois links de lojas de poa pq ficamais facil de eu ir buscar e já resolver, mas se tiverem alguma dica de outra loja de poa ou pela internet q esteja valendo mais a pena pode mandar. Não é nada profi, so algo sem muito barulho que resolva o problema sem precisar gastar muito.
    Vlw pessoal.
