    Membro Avatar de John Urban
    Tem que ver
    Jan 2009
    Qual o melhor Q8300 ou Q6600 SLACR G0?
    Specs Q6600 SLACR G0 - R$610
    sSpec Number: SLACR
    CPU SPEED: 2.40Ghz
    PCG: 05A
    Bus Speed: 1066Mhz
    Bus/Core Ratio: 9
    L2 Cache Size: 8Mb
    L2 Cache Speed: 2.4Ghz
    Package Type: LGA775
    Manufacturing Technology: 65 nm
    Core Stepping: G0
    CPU ID String: 06FBh
    Thermal Design Power: 95W
    Thermal Specification: 71ºC
    VID Voltage Range: 0.8V - 1.5V
    Product Documentation:
    http://www.intel.com/design/core2quad/documentation.htm
    Product Order Codes:
    Box Order Code:
    BX80562Q6600
    OEM Order Code:
    HH80562PH0568M
    Supported Features:
    • Quad Core
    • Enhanced Intel Speedstep® Technology
    • Intel® EM64T 1
    • Intel® Virtualization Technology
    • Enhanced Halt State (C1E)
    • Execute Disable Bit 2
    • Intel® Thermal Monitor 2
    Notes:
    These parts have PROCHOT enabled.
    These parts have THERMTRIP enabled.
    These parts have PECI enabled.
    Specs Q8300 - R$698
    sSpec Number: SLB5W
    CPU Speed: 2.50 GHz
    PCG: 05A
    Bus Speed: 1333 MHz
    Bus/Core Ratio: 7.5
    L2 Cache Size: 4 MB
    L2 Cache Speed: 2.5Ghz
    Manufacturing Technology: 45nm
    Core Stepping: R0
    CPUID String: 1067Ah
    Thermal Specification: 71.4ºC
    VID Voltage Range: 0.85 – 1.3625V
    Box Order Code:
    BXC80580Q8300
    BX80580Q8300
    OEM Order Code:
    AT80580PJ0604MN
    Supported Features:
    • Quad Core
    • Intel® EM64T 1
    Notes:
    These parts have PROCHOT# enabled
    These parts have THERMTRIP# enabled
    These parts have Extended Stop Grant State (C2E) enabled
    These parts have Deep Sleep State (C3E) enabled
    These parts have Deeper Sleep State (C4E) enabled
    E ai, qual vence? Q6600 G0?
    Apesar do cache menor, o Q8300 é melhor por ser uma arquitetura mais nova (45nm) ter FSB 1333mhz contra 1066mhz...
    Com certeza, superior o Q8300.
    O FSB1333 do Q8300 pode ser um belo contra(e é na minha opinião),aliado ao mult ridículo de 7.5,dificulta bem o overclock,só rola com mbs boas,vc precisa de mto fsb mesmo.
    E tb tem cache menor.
    A arquitetura é a mesma(Core 2),só muda algumas coisas,com desempenho levemente melhor pros da "revisão" 45nm(com excessão de casos onde usa SSE4,etC)
    Última edição por DVSV : 26-01-2009 às 4:18
    A arquitetura é a mesma(Core 2),só muda algumas coisas,com desempenho levemente melhor pros 45nm(com excessão de casos onde usa SSE4,etC)
    Como pode ser um contra, se o desempenho de todo o sistema é baseado na largura do barramento?!
    Qt mais alto o FSB, melhor o desempenho geral do sistema.
    O fato do multiplicador ser menor pode significar menor clock do processador, porém, um clock baseado em FSB alto, gera mto mais desempenho do q o gerado através de multiplicador.
    Membro Avatar de Cesar Romero
    Vo come a tia do Batima
    Q6600 com fsb 333 ai mermao!
    espanca o Q8300 qualquer hora!
    Citação Citando brrodo Ver mensagem
    p/ overclock é bem pior.. uso em stock não
    Como eu falei,é um contra se vc pensa em fazer overclock!
    E FSB não é tudo isso não hein,se eu quiser eu posso socar FSB1333 até no meu e2180..
    Se for pra OC,é muito mais interessante jogar o Q6600 a FSB1333 e pegar um clock bem maior que o Q8300(Que precisa de mb bem melhor pra atingir um fsb bem alto,e o mult baixo atrapalha bem tb)
    Hoje tb não acho que o FSB tem essa importância enorme no desempenho geral do sistema,isso era mais da época do P4..
    Claro que quanto mais,melhor,mas nem toda aplicação se beneficia de um fsb alto(alguem confirma aí )
    Agora se for usar tudo em stock,desconsidera o que estou falando
    Membro Avatar de rbuass
    Nov 2006
    Informe-se melhor...
    QQ processador vagabundo pega 1600 (400 de FSB)...e não precisa ter isso de fabrica
    O multi baixíssimo dele exige que vc tenha um sistema mais poderoso para obter o mesmo clock...
    QQ Q6600 vagabundo trabalha dia a dia com 3600 mhz sem forçar nada...
    Pra isso vc precisa de 480 de FSB num quad 8300 ...
    Claro que a arquitetura 45nn é melhor...mas no geral não pode avaliar como fez nesta sua observação
    Isso é claro.
    O que eu disse é: Um sistema q trabalha com um processador com clock 9x266mhz, vai ter desempenho pior do q um com 7.5x333mhz...Embora o "mesmo" (quase) clock resultante.
    Não estou tão mal informado assim...Basta ler o q escrevi.
    Última edição por brrodo : 26-01-2009 às 9:08
    Membro Avatar de Neon
    (¬'-')¬ C-('-'Q)
    Isso é claro.
    você contestou algo que o cara já tinha explicado.
    o que o DVSV disse era ter o FSB alto (em stock) é um ponto negativo por causa do overclock. [já explicado por uns 2-3 posts...]
    eu ficaria com o Q8300 pra usar stock, e o Q6600 pra OC.
    mas puuutz, 700r$ num Q8300? :S
    Última edição por Neon : 26-01-2009 às 9:19
    Tudo bem. Mal entendidos à parte, o cara não disse se ia fazer over, então respondi baseado apenas no q ele tinha perguntado.
