    Intel Bearlake G33
    Olá.
    Tenho um desktop Dell.
    A placa mãe tem o chipset Intel Bearlake G33.
    No site da Intel não diz que tem suporte à ddr3.
    O Everest diz que tem suporte à ddr3.
    Quero comprar mais memória RAM e gostaria de saber se posso comprar ddr3.
    --------[ EVEREST Ultimate Edition ]------------------------------------------------------------------------------------
    Version EVEREST v5.00.1650
    Benchmark Module 2.4.258.0
    Homepage http://www.lavalys.com/
    Report Type Quick Report
    Computer DELL
    Generator Vostro
    Operating System Microsoft Windows Vista Ultimate 6.0.6001 (Vista Retail)
    Date 2009-02-19
    Time 10:38
    --------[ Chipset ]-----------------------------------------------------------------------------------------------------
    [ North Bridge: Intel Bearlake G33 ]
    North Bridge Properties:
    North Bridge Intel Bearlake G33
    Intel Platform Salt Creek
    Supported FSB Speeds FSB800, FSB1066, FSB1333
    Supported Memory Types DDR2-667 SDRAM, DDR2-800 SDRAM, DDR3-800 SDRAM, DDR3-1066 SDRAM, DDR3-1333 SDRAM
    Maximum Memory Amount 8 GB
    Revision / Stepping 02 / A2
    Package Type 1226 Pin FC-BGA
    Package Size 3.4 cm x 3.4 cm
    Core Voltage 1.25 V
    In-Order Queue Depth 12
    Integrated Graphics Controller:
    Graphics Controller Type Intel GMA 3100
    Graphics Controller Status Enabled
    PCI Express Controller:
    PCI-E 1.0 x16 port #2 In Use @ x16 (ATI RV635 - High Definition Audio Controller, Sapphire Radeon HD 3650 512MB DDR2 Video Adapter)
    Chipset Manufacturer:
    Company Name Intel Corporation
    Product Information http://www.intel.com/products/chipsets
    Driver Download http://support.intel.com/support/chipsets
    BIOS Upgrades http://www.esupport.com/biosagent/in...m?refererid=40
    Driver Update http://driveragent.com?ref=59
    [ South Bridge: Intel 82801IR ICH9R ]
    South Bridge Properties:
    South Bridge Intel 82801IR ICH9R
    Revision / Stepping 92 / A2
    Package Type 676 Pin mBGA
    Package Size 3.1 cm x 3.1 cm
    Core Voltage 1.05 V
    High Definition Audio:
    Codec Name Realtek ALC888/1200
    Codec ID 10EC0888h / 10280238h
    Codec Revision 00100001h
    Codec Type Audio
    Supported Sound Formats 44 kHz, 48 kHz, 96 kHz, 192 kHz, 16-bit, 20-bit, 24-bit
    Última edição por Castelli : 19-02-2009 às 12:05
    Membro Avatar de Neon
    (¬'-')¬ C-('-'Q)
    o chipset pode até suportar, mas nada adianta ele suportar e sua mobo não ter slot para ddr3 =)
