Página 1 de 3 1 2 3 Última
    Nov 2005
    4850/3850/7800gt testes
    Bom a principio a x850xtpe iria entrar nesse comparativo entretanto a pobre "coitada" morreu durante o teste no crysis ( assassino :P ) ! Tambem fiquei sem tempo para testes com a x1900xt512 e 4830 caso tenha condicoes esse fim de semana adiciono resultados dessas ultimas !
    SISTEMA
    Intel Q6600 @ stock
    P5WDH DELUXE WIFI AP
    750GB seagate sataII
    2GB DDR2 800
    OCZ Modstream 520W
    http://img145.imageshack.us/img145/4260/sistema.jpg
    Windows Xp Professional SP2
    Ati catalyst 9.2 - - HD4850/HD3850
    175.16_geforce_winxp_32bit_english_whql - - 7800gt
    PROGRAMAS
    Driver Cleaner Pro
    HardwareOC Crysis Benchmark
    Ozone 3D Furmark Benchmark Tool´s
    3DMark2001 SE
    3DMark2003
    3DMark2005
    Fraps
    JOGOS
    Counter Strike Source
    Codemasters Grid
    Farcry 2
    Crysis
    Need For Speed Most Wanted
    vamos as placas :
    BFG 7800GT OC 256MB PCIEX
    Memory Interface 256BITS Memory Clock Speed (MHz) 500MHZ
    Core Clock Speed 400MHZ Pixel Shader Pipelines 20
    Vertex Shading Units 7 Peak Texel Fill Rate 8000
    Peak Memory Bandwidth 32GB/S Peak Power Consumption 85W
    SHAPIRE HD3850 256MB PCIE
    256MB GDDR3 PCI-E Dual DL-DVI / TVO, 256-bit
    RV670 PRO
    Single Slot Fan Cooler
    PCI Express 2.0 x16 bus interface
    DirectX® 10.1 support
    CrossFire X™ support
    ATI PowerPlay™
    Hardware processed 1080p video playback of Blu-ray™ and HD DVDs
    HDMI with 5.1 surround sound audio
    XFX HD4850 512MB
    * Interface: PCI Express 2.0 x16
    * Chipset:
    - Chipset Manufacturer: ATI
    - GPU: Radeon HD 4850
    - Core clock: 625MHz
    - Stream Processors: 800 Stream Processing Units
    * Memory:
    - Memory Clock: 1990MHz
    - Memory Size: 512MB
    - Memory Interface: 256-bit
    - Memory Type: GDDR3
    * 3D API:
    - DirectX: DirectX 10.1
    - OpenGL: OpenGL 2.1
    * Ports:
    - DVI: 2
    - TV-Out: HDTV / S-Video Out
    * General:
    - RAMDAC: 400 MHz
    - Max Resolution: 2560 x 1600
    - RoHS Compliant: Yes
    - CrossFire Supported: Yes
    - Cooler: With Fan
    - System Requirements: Minimum Power Supply Requirement: 450 Watt
    - Power Connector: 2 x 6 Pin
    - Dual-Link DVI Supported: Yes
    - HDCP Ready: Yes
    FARCRY 2 HIGH NOHDR NOBLOOM
    BFG 7800GT 256MB
    1024X768 NOAA
    * Average Framerate: 9,81
    * Max. Framerate: 16,02
    * Min. Framerate: 7,58
    1280X1024 NOAA
    * Average Framerate: 6,28
    * Max. Framerate: 10,05
    * Min. Framerate: 4,89
    HD3850 256MB
    1024X768 HIGH 2XAA
    * Average Framerate: 37,50
    * Max. Framerate: 50,68
    * Min. Framerate: 29,80
    1280X1024 HIGH 2XAA
    * Average Framerate: 31,31
    * Max. Framerate: 44,98
    * Min. Framerate: 23,90
    XFX HD4850 512MB
    1024X768 HIGH 2XAA
    * Average Framerate: 48,03
    * Max. Framerate: 64,18
    * Min. Framerate: 37,04
    1280X1024 HIGH 2XAA
    * Average Framerate: 44,03
    * Max. Framerate: 58,39
    * Min. Framerate: 35,62
    Última edição por wolfmancs : 07-03-2009 às 14:18
    Nov 2005
    CRYSIS HIGH NOAA DX9
    BFG 7800GT 256MB
    1024X768
    * Average Framerate: 4,55
    * Max. Framerate: 14,96
    * Min. Framerate: 2,29
    1280x1024
    * Average Framerate: 3,02
    * Max. Framerate: 8,97
    * Min. Framerate:0,90
    HD3850 256MB
    1024X768
    * Average Framerate: 40,24
    * Max. Framerate: 49.66
    * Min. Framerate: 9.47
    1280x1024
    * Average Framerate: 27,68
    * Max. Framerate: 33.84
    * Min. Framerate: 11.66
    XFX HD4850 512MB
    1024X768
    * Average Framerate: 49,80
    * Max. Framerate: 68,05
    * Min. Framerate: 10,52
    1280x1024
    * Average Framerate: 44,9
    * Max. Framerate: 53,27
    * Min. Framerate: 16,67
    3DMARKS
    BFG7800GT 256MB
    3DMARK2001 - 27145 pts
    3DMARK2003 - 9465 pts
    3DMARK2005 - 4150 pts
    3DMARK 2001- 40255
    3DMARK 2003 - 30981
    3DMARK 2005 - 14729
    XFX HD4850 512MB
    3DMARK2001 - 41890 pts
    3DMARK2003 - 33582 pts
    3DMARK2005 - 15128 pts
    ozone3d furmark rendering
    BFG7800GT 256MB
    FPS Min:5 FPS Max:18 FPS Avg:8
    FPS Min:33 FPS Max:53 FPS Avg:40
    XFX HD4850 512MB
    FPS Min:38 FPS Max:58 FPS Avg:44
    All max vsync off 1280x1024 + filtros
    challenge series - corrida 1 - golf
    BFG7800GT 256MB
    Avg: 33.586 - Min: 24 - Max: 54
    Avg: 53.541 - Min: 39 - Max: 68
    XFX HD4850 512MB
    Avg: 75.781 - Min: 58 - Max: 84
    RACER DRIVER GRID
    1024X768 ULTRA 4XAA
    BFG7800GT 256MB
    Avg: 11.660 - Min: 2 - Max: 16
    Avg: 51.530 - Min: 42 - Max: 64
    XFX HD4850 512MB
    Avg: 87.577 - Min: 75 - Max: 101
    COUNTER STRIKE SOURCE
    ALL HIGH 4AA 8AF NOHDR NOCC DX9
    BFG7800GT 256MB
    1024X768 149FPS
    1280X1024 112FPS
    1024X768 201FPS
    1280X1024 166FPS
    XFX HD4850 512MB
    1024X768 256,57 FPS
    1280X1024 243,32FPS
    algumas screens :
    Conclusão !
    De testes de 3850 e 4850 atualmente temos muitos entao pensei pq nao comparar a 7800gt com essas usando resoluções baixas mas com graficos no maximo , afinal de contas a 7800gt foi/era uma TOP para sua epoca e para minha surpresa , tirando o CSS que ja e um jogo relativamente antigo a 7800gt em materia de jogabilidade foi :
    - sem condições no crysis tanto 1024x768 quanto 1280x1024 (tudo high)
    - ruim d+ no FC2 em 1024x768 e em 1280x1024 pior ainda logicamente
    - muitas "lag" tanto em 1024 qut em 1280 no Grid , ultra com filtros
    - totalmente jogavel no Need for speed most wanted tanto em 1024 qut em 1280 ( pequenos lags em 1280 esporadicos)
    - muito boa ainda para CSS em ambas as resolucoes !
    Membro Avatar de Sirjoul
    Feb 2009
    Bom teste
    Ei cara, me diz o que você esta achando da 4850 XFX... comprei uma, só estou esperando chegar...
    Sistema de exaustão eficiente? Faz muito barulho? Algum artefato? Testou overclook?
    Nov 2005
    sem duvida e a melhor modelo de 4850 depois da his iceQ
    ja tive 4870 e o cooler parecia uma turbina e 2 4850 uma da shapire e uma powercolor modelos de cooler referencia
    que exigem que se aumente a rotacao do fan e fazem um pouco de barulho na casa dos 55% , essa da xfx nao precisa de controle
    manual nao esquenta demasiadamente !
    uma otima placa !
    Feb 2009
    Bom saber
    Membro Avatar de XOTISNEGUER
    OVER 9000 NG/DL
    faltou só uma 8800gt que é placa excelente custo beneficio ae nesse comparativo, mas mesmo assim vc está de parabéns ^^
    UmK
    UmK está offline
    calma la, most wanted rodava muito bem, quase liso numa radeon 9500PRO e com anti aliasing ainda em 1280x960. impossivel ficar "jogavel" só numa 7800GT
    Última edição por UmK : 07-03-2009 às 13:32
    Nov 2005
    essa tua 9500pro e boa demais !
    tenho aqui uma 9800pro num a64 3.7 e enao aguenta tudo full em 1280x1024 ! leiaa-se TUDO FULL
    nem jogavel fica , alias bem longe disso ! minimo pra ser considerado "jogavel" sao 30fps num game desse ! minimo mesmo ! e a 9800pro nas mesmas condicoes nao fez 23 max logico que num sistema mais fraco tb !
    no grid e mw foi usado o fraps e terminada as corridas e foi sofrivel grid no ultra usando 7800gt !
    Última edição por wolfmancs : 07-03-2009 às 14:14
    Membro Avatar de manisnk
    Ja chegou o disco voador!
    Jan 2006
    x1900xt512
    Ainda ta disponível pelo visto!
    Citação Citando UmK Ver mensagem
    7800GT talvez rode com mais efeitos, HDR e tal? e 9500 sem?!
    no 3dm05 minha 8600 ddr2 faz o dobro do score, em um X2
    Membro Avatar de Moheekan
    É, a 7800gt não da mais. Só CSS mesmo.
    A x1900xt deve se sair melhor que a 3850 se vc conseguir testar. Eu tive uma x1950xt, era muito boa.
    Tô com uma 4850 da visiontek, é das esquentadas. O desempenho vale a pena e é só configurar os perfis do cooler. Se fosse automático seria muito melhor, mas...
    abcs
    Nov 2005
    sim 7800gt roda com mais efeitos mesmo , mas mesmo assim uma 9500pro nao aguenta rodar tudo full
    1280x1024 no mw nunca !
    e 3dmark so usei por usar mesmo pq ele nao reflete a diferenca real ( in-game) das vga´s nunca , ate pq uma 8600gt 256mb ddr3 vai muito bem no 3dmark2005 encosta na x1900xt 512
    Citação Citando manisnk Ver mensagem
    nem ta nao
    Citação Citando wolfmancs Ver mensagem
    nem ta nao
    sim claro, as coisas variam, porem nos jogos atuais ainda mais considerando o potencial de OC, nao tenho duvidas quanto a superioridade de uma 8600 frente a 7800GT...
    mas para conseguir uma jogabilidade confortavel, é so abaixar alguns detalhes com essa 7800GT
    quanto a 3850, eu tive uma 3850 256mb, no CMR dirt eu conseguia a mesma performance da minha 8600 em MEDIUM com ela em Ultra... a diferença é boa.
    o crysis voce rodou o "gpu benchmark"? aqui com a 3850 a performance era bem pior, dava media de uns 30 ou menos, em 1024 high... deve ser CPU + drivers novos sei la, tive em janeiro de 2008.
    Última edição por Spectrobozo : 07-03-2009 às 15:56
    Nov 2005
    bom por enquanto so posso te adiantar que a 8600gt nao aguenta nao !
    esta se saindo pior que a 7800 !
    tudo varia, mas estou falando em jogos mais novos tipo:
    http://www.pcgameshardware.de/aid,63...icle_id=637474
    8600GTS batendo 7900GT, entao é natural 8600GT bater 7800GT, ainda mais considerando o OC maximo.
    mas para comparativo com produtos do tipo 7800, 8600 nao adianta colocar grid em ultra com aa4x, coloca um medium sem AA e coisa do tipo, alias as series 7 nao tem limitações quanto HDR + AA?
    crysis 1024 medium sem AA tambem...
    grid eu jogava praticamente travado a 30fps, em 1024 com coisas em medium e em high, e AA2x, crysis zerei os 2 em com shader e shadow em medium, algumas coisas em high... com esse tipo de vga tem que ser assim, senao hehe... fica um lixo.
    Última edição por Spectrobozo : 07-03-2009 às 17:06
    Jan 2006
    Ahhh já ia te pertubar no msn pra comprar ela.
    Se tiver uma 8800 por ai te volto aquele 8600 e te dou uma volta.
    Membro Avatar de nicolasm
    ja testei 7900GT e 8600GTS, sao praticamente a mesma coisa. em stock a 8600GTS é um pouco melhor que a 7900. Mas com over a 7900 vira o capeta. De qualquer maneira qualquer uma delas abre as pernas pra jogar a partir de 1280x1024 com tudo no talo, em jogos um pouco mais atuais.
    A 8600GT é pedir pra sofrer heuheu, nao consegui ficar 1 dia com uma, mas é algo melhor do que a 7800GT.
    Serie 7 tem limitacao pra HDR + AA sim. Nao roda.
    Nov 2005
    bom continuo discordando de voce , primeiro pq se compara a vgas em stock e nao em over , segundo que
    uma 8600gt nao e parea mesmo , alem de estar percebendo isso tem esse comparativo que apesar de tudo no geral a 7800 e um pouco melhor que a 8600gt
    http://www.tomshardware.com/charts/g...s-fps,572.html
    hj em dia consideraria uma 8600gt/7800gt placas "quebra galho" pq tanto uma como outra nao possuem força para rodar games com qualidade , claro se for exigente !
    Nov 2005
    bom maninsk uma 3870 voltou de rma e eu negociei ela pegando aquela x1900xt de volta ! entretanto dei a x1900xt pro meu irmao mais novo , o que tenho aqui sobrando sao essas 2 placas , a 7800 e a 3850 !
    "primeiro pq se compara a vgas em stock e nao em over"
    isso é relativo, por isso mesmo comparei TANTO em stock como em over. não existe regra, tanto que em variados reviews apresentam o resultado em stock e em over.
    se compara em overclocking sim, eu por exemplo sou assíduo de mods e overclock, por isso me interessa muito mais o resultado desses do que em stock.
    Nov 2005
    acho besteira comparar em over ja que nenhuma placa e igual a outra ou aguenta mesmo over !
    sem contar que se for 10% dos usuarios que usam em over 24/7 e muito !
    eu uso tudo com over, para mim testes levando isso em consideração sao interessantes...
    nem tem o que discutir em jogos atuais 8600GT é melhor do que 7800GT, so em jogos velhos nao, mas nos velhos as duas vao "bem" mesmo, nesse chart do THG ta cheio de jogo velho, doom 3, prey!? nao é muito importante... 7800GT é pior que 7900GS, e tem varios testes por ai que mostram em jogos novos 8600GT stock superando 7900GS,
    e como eu disse, para comparar esse tipo de coisa (vga velha, low end), é legal usar configurações realistas, tipo 1024 medium sem filtros no crysis.
    mesmo a 7800GT é bem usavel hoje em dia, ao menos eu com a 8600 ddr2 nao deixei de jogar nada por falta de vga até agora.
    agora outra coisa, nessa 3850 voce nao nota travadinhas pela falta de vram?
    quando tive uma no cmr dirt era triste, se eu colocava AA4x o jogo dava paradas, sem AA normal...
    Última edição por Spectrobozo : 07-03-2009 às 20:11
    Nov 2005
    bom no thg se prestares atencao tb eles usam os 3dmarks e neles a 8600gt tem uma pontuacao totalmente irreal pro desempenho dela , digo isso pq ela chega muiitooo perto da x1900xt512 nesses testes !
    segundo o chart do THG a 8600gt ddr3 de referencia esta atras da x850xtpe que nos sabemos nao ser parea para 7800gt !
    tenha calma que daqui ha alguns dias posto uns testes dela sob as mesmas condicoes da 7800gt !
    e a 3850 foi muito bem no fc2 em 1024x768 tudo high sem aa2x sem travadas , grid tb , mw numa boa e css so notei alguns slowss no crysis em 1280x1024 ! lembre que ela e concorrente da 9600gso/9600gt e que ate 1280x1024 nao e preciso muita memoria , diria que so dos 1600x1200 ou 1680x1050 para frente que 512/1gb fazem alguma diferenca!
    e cada um defende seu peixe ja estou acostumado com isso ! e essa sua 8600gtddr2 for 512 achas mesmo que esses 512 dela fazem alguma diferenca ? que ela e parea para a 8600gt 256mb ddr3 ?
    Última edição por wolfmancs : 07-03-2009 às 20:40
    minha vga tem 256mb de vram, a diferença era o preço, uns paguei uns 180 a 1 nao atras,
    bom, eu usava em 1024x768 e a falta de vram da 3850 ja era visivel com mais filtros... no CMR dirt.
    nao acho que a performance do 3dm seja irreal, apenas ela demonstra mais a evolução da serie 8 quanto a shader... tenha certeza que meu objetivo nao é defender o que tenho, so estou comentando que a 7800GT chega a ser inferior a 8600GT nos jogos atuais...
    e acho a seleção de jogos desse teste do thg BEM ruim...
    agora aqui
    BFG 7800GT 256MB
    1024X768 NOAA
    é no teste padrao?
    aqui da 30fps de media, minimo 24, com HDRe bloom ligado e no modo "high".
    e é um jogo bem cpu intensive, talvez meu X2 atrapalhe ai.
    so acho que sua conclusao foi errada quanto a 7800, ja que nao explorou muito as configurações que o jogo te permite... so no crysis passando shader e shadow para medium faria a diferença, ainda mantendo um visual "bacana", no grid voce ligou AA, sendo que a vga nem roda AA + HDR, e ultra para 7800GT esta errado, grid em medium deve ficar perfeitamente jogavel nela...
    Última edição por Spectrobozo : 07-03-2009 às 21:10
    Nov 2005
    tem certeza disso ? tudo high e com hdr ?
    cara 30fps e muito pra essa tua placa no crysis num x2 pra fazer esse avg !
    acho que voce esta meio equivocado
    olha aqui
    pc igual ao seu , 8600gtddr3
    crysis 1024x768 com algumas coisas no high outras no medium e sombras no low
    media de 25fps , com quedas bem maiores que a que vc relata com a sua 8600gtddr2
    http://img108.imageshack.us/img108/3981/crysis9ug5.jpg
    http://adrenaline.com.br/forum/placa...c-mediano.html
    e aqui melhor ainda uma ddr3 da gainward que e linda por sinal ! mesma coisa quality no medium pc link do teste http://www.overclock3d.net/reviews.p...dition_256mb/2
    volto a perguntar tem certeza que esse teu avg nao foi o max e o 24 era 14 de avg nao ?
    comentarios deles !
    sistema deles
    Intel Core2Quad Q6600 @ 3.6GHz
    Asus P5E3 DDR3 Motherboard
    Kingston HyperX PC3-11000 CL7 DDR3 2gb Kit
    OCZ GameXtream 850w
    Hitachi 7K160 HDD
    Samsung DVD-RW
    Silverstone TJ09S Case
    Noctua NH-U12P Cooler
    Dell 2405FPW Display
    Crysis on medium settings at 1368 x 768 was laggy at the points where combat came into the game. As this is the most advanced game in our tests this is slightly disappointing
    so 1 adendo a minha 8600gt ddr3 aqui tudo no high 1024x768 no meu sistema em stock que e melhor que o seu em over ta fazendo menos que a 7800 no crysis !
    Última edição por wolfmancs : 07-03-2009 às 21:39
