    Membro Avatar de D.O.G.
    [GigaAccel 180] Playstation 3 on a pci card!
    http://us.fixstars.com/products/gigaaccel/
    Fixstars GigaAccel 180
    Cell on a Card
    The Fixstars GigaAccel 180 is built upon the innovative multi-core IBM PowerXCell 8i processor, a new generation processor based on the Cell Broadband Engine (Cell/B.E.) architecture. The GigaAccel 180 incorporates the IBM PowerXCell 8i microprocessor which offers 5x the double-precision performance of the previous Cell/B.E. processor. With 4GB of DDR2 RAM, this supercomputer on a PCIe form-factor card will increase performance of Cell optimized 32- and 64-bit applications.
    Ease of Deployment
    # Transition from a Sony PLAYSTATION3 to the GigaAccel 180 and dramatically improve your performance without rework of code.
    # Host up to 4 GA-180s in a single tower or rackmount host.
    # Assemble a cluster of GA-180 workstations for rapid, scalable growth of a distributed system using Y-HPC, TORQUE, and Cluster Resources Moab.
    # Incorporate the GA-180 into your embedded solution for an open or blackbox turn-key solution.
    Cheguei neste link após visitar a página do YellowDog Linux!
    http://us.fixstars.com/products/ydl/
    Membro Avatar de Corredor2009
    Mar 2009
    Pena que:
    Compatible Motherboards
    Officially, IBM only supports the IBM IntelliStation as the host system for the GigaAccel 180 (i.e. PXCAB). The following motherboards, however, will work with the GigaAccel 180.
    Scalable Informatics
    Scalable Informatics designs, builds, and supports high performance storage, clusters and workstation hardware, scalable and accelerated software, and offers support, consulting and development services. Scalable offers the Fixstars GA-180 pre-installed and configured in customized Cell + GPU hybrid x86 workstations.
    To learn more, visit www.scalableinformatics.com
    HP XW4300
    This motherboard has issues with the latest BIOS; once the system is booted, however, the GA-180 remains functional. Booting into a non-failure state appears to be random.
    Lenovo ThinkStation S10
    This motherboard is slated to be an officially supported host, once several issues are resolved.
    olha, não entendi direito ainda para que serve a placa... 6100 dólares para rodar Play 3 pelo pci-e do seu pc?? o que mais ela faz?
    e realmente, a compatibilidade dela com placas-mãer é triste , mesmo não sabendo exatamente para que ela serve hehe..
    Mar 2009
    Se eu entendi bem, é um sistema secundário, composto de um duplo processador e memória, compatível com o do Playstation 3, pelo fato de ter arquitetura semelhante. Portanto, é útil para quem deseja usar aplicações construídas para "Cell microprocessors". Para usuários comuns, não tem utilidade nenhuma.
    eh soh paara render ou games ?
    Citação Citando Baros Ver mensagem
    ah, entendi.. faz sentido, já ví centros de pesquisas que usam playstations 3 para pesquisas pelos procesadores cell deles... a Unicamp acho que fazia alguma pesquisa com uns 7 deles; ví a notícia algum tempo atrás, não lembro onde...
    quem sabe com uma placa dessas então seja mais proveitoso e menos dispendioso do que o cluster de ps3 q era usado na tal pesquisa... realmente pode ser bem vantajoso em algumas ocasiões...
