    Membro Avatar de Cesar Romero
    Vo come a tia do Batima
    [nao tente isso em casa] metodo muito louco pra reviver gpus!
    http://www.gpureview.com/how-to-fix-...ticle-798.html
    How to fix your broken video card. Step 1: Preheat your oven to 385F.Posted By: Steve McBarnes - 04:26:30 Sun, May 31, 2009
    You may have noticed that it has been a while since I posted a story. There are two reasons for this. I was on vacation from May 21-26th and I was without Internet access and I have not really seen anything worth posting. Well I am back from vacation and I just found something worth posting. Hurray!
    [H]ard|Forum member Haste266's 8800 GTX was showing definite signs of death so he decided to treat it like a "baked potato". After baking it for 8-10 minutes at 385F and letting it air cool, he had a fixed 8800 GTX. Apparently the heat from the oven re-melted some solder joints that were failing.
    It is a good thing that the 8800 GTX (like almost all recent card) are RoHS compliant. If it was not, there could have been some pretty toxic gases coming off the card.
    Congrats Haste266! You are officially a neat person.
    um dos comentários:
    Friday, June 12, 2009 4:22:42 PM
    muralla
    n00b IT WORKS!!! My 8800GTX died 2 months ago so I got myself a GTX260. It didnt really die, it just filled the screen with artifacts. After reading about baking it I gave it a shot thinking "what the heck, I got nothing to loose".
    Well, amazingly it worked!
    I rapped it up in aluminum foil after removing the heatsink and fan, and baked it for 10 minutes at 200�C.
    It was the baking that fixed, as I tried the card again right before baking it.
    I have been playing games with it the whole day and still runs as new.
    achei interessante e resolvi postar
    alguem sabe mais a respeito?
    Última edição por Cesar Romero : 03-07-2009 às 2:24
    Cara isso deve resolver problema de solda e etc, como é intrinsincas e etc aquecer "refaz" a ligação. A uinca lógica que eu vejo é isso.
    Basicamente o Towel Trick dos XBOX360.
    é a mesma coisa sim...
    um amigo meu está com uma x800gto assim, será que tem algum risco de queimar alguma peça do PC por soldas derretidas fechando curto-circuito na placa?
    se não tiver, acho bem válido...
    Membro Avatar de vcalves
    Dec 2004
    Só mesmo se for pra eliminar soldas frias mesmo.
    E dá pra tentar com outros componentes também, incluse placas-mãe. Principalmente placas da PcChips que adoram dar solda fria.
    Membro Avatar de hirano
    hiranosan
    Nov 2007
    Tenho uma 7900gs aqui com artefatos, mas tô com medo de tentar.
    Membro Avatar de FireMax
    Vix
    Já esquentei o GPU da minha 8600 até quase derreter com soprador, e depois soquei ela no freezer por 12hs.
    A bixinha que nem estava ligando tá funfando agora, apesar de peidar em jogos mais pesados e dar artefatos.
    Membro Avatar de G.Garotinho
    Tinha um outro tópico, q o pessoal lavava com alcool isopropilico e um outro onde lavavam com água e sabão! e em alguns casos conseguiram ressuscitar a bichinha
    nesse caso parece re-soldar os caminhos eletricos derretendo-os por poucos minutos
    falando em bake to comendo um pao de milho feito por mim mesmo, lembreai da vga hahoauhoauuoaho
    opa... só para constar nos autos das falecidas vgas, fiz o experimento com uma X800GTO da powercolor e... não deu certo
    alguns resistores, capacitores e outros componentes se soltaram da placa... FAIL pra mim... devo ter aquecido mais do que devia...
    mas não desconsidero o procedimento... boa sorte aos interessados! []'s
    Membro Avatar de Diablero
    Exorcista
    Vo fazer isso na minha 9800GX2....
    SNisf snif
    Citação Citando El Slaugho Ver mensagem
    HEAIheoiahiehua
    Deu pena de ver os componentes do lado de fora!
    PS: Desculpa por ter rido!
    tem nada não, pikachu... eu tb rí
    o dono da vga ainda não riu pq não viu o resultado...
    Mar 2009
    mais fácil aqueçe-la com um secador de cabelo,heheheh.
    Citação Citando Diablero Ver mensagem
    SNisf snif
    veio, uma das placas da minha 9800gx2 bailou... eu postei um tópico um tempo atras.
    eu to com uma gtx 275 agora e humilha a 9800gx2 em todos os games q eu joguei, acho q a minha 9800gx2 ja tinha vindo bixada, já que era pra ser equivalente a uma gtx280...
    Membro Avatar de raiost
    Nov 2004
    aqui ja recuperei uma gerforce 2 assim e esta funcionando bem no micro de um amigo meu a placa não dava nehum sinal de vida depois do processo voltou a funcionar.
    Membro Avatar de Whisky
    Mar 2001
    Só não acho uma boa deixar a placa com os componentes virados para baixo, umas vez que, devido a famosa força da gravidade, aquilo que já estava "solto"ou com mal contato tende a soltar ainda mais!!!
    Além do mais... 200 graus por 10 minutos me parece um tanto exagerado
    Apr 2006
    Bem , vou assar a minha 8600 GTS aqui, vamos ver oque da. Vou fotografar e posto aqui depois.
    Quando fizerem isso tentem nao passar de 150C e nunca passem de 250C. 2 minutos em 150C já basta. E deixem resfriar no ar, NAO PONHA NA GELADEIRA.
    Citação Citando Whisky Ver mensagem
    depois da minha experiência, considerei a mesma coisa... o artigo não mencionou e eu não imaginei que as soldas derreteriam a ponto de caírem os componentes internos... só depois percebii que 200°C é uma temperatura bem acima do necessário a para um filamento de solda entrar em fusão... mas acredito na validade do teste, sim...
    anyway, gg pra mim... hehe
