    Membro Avatar de FireMax
    Vix
    [velhariaMOB] Voodoo 3 @ 1080P - Edit: Funcionou!
    Pessoal, remontei o meu antigo PC para utilizar como maquina de downloads, um velho P3 866 + 512 PC133 + Voodoo 3500. Provisoriamente ele esta embutido no rack da sala sem gabinete, e estou usando minha Samsung 32 A550 como monitor.
    Fiz algumas alteracoes no driver dela, e a resolucao maxima que consigo setar foi 1360x768. Se tento setar 1920x1080 a TV apaga.
    Alguem tem ideia por que isso esta acontecendo? Teriocamente uma Voodoo 3 aguenta bem mais que essa resolucao.
    Segue abaixo parte do INF do driver dela.
    Código:
    HKR,"TIMINGS\1360,768\60Hz",,,"GTF"
    HKR,"TIMINGS\1360,768\60Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1600,1024\60Hz",,,"2088,1632,1792,1070,1027,1030,12,134049600,6000,8,28063"
    HKR,"TIMINGS\1600,1024\60Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1600,1024\76Hz",,,"2088,1632,1792,1070,1027,1030,12,169796160,7600,8,33238"
    HKR,"TIMINGS\1600,1024\76Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1600,1024\85Hz",,,"2088,1632,1792,1070,1027,1030,12,189903600,8500,8,36149"
    HKR,"TIMINGS\1600,1024\85Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1600,1200\60Hz",,,"2088,1664,1856,1250,1201,1204,0,156600000,6000,8,30931"
    HKR,"TIMINGS\1600,1200\60Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1600,1200\65Hz",,,"2088,1664,1856,1250,1201,1204,0,169650000,6500,8,32736"
    HKR,"TIMINGS\1600,1200\65Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1600,1200\70Hz",,,"2088,1664,1856,1250,1201,1204,0,182700000,7000,8,34541"
    HKR,"TIMINGS\1600,1200\70Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1600,1200\75Hz",,,"2088,1664,1856,1250,1201,1204,0,195750000,7500,8,36346"
    HKR,"TIMINGS\1600,1200\75Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1600,1200\80Hz",,,"2088,1664,1856,1250,1201,1204,0,208800000,8000,8,38151"
    HKR,"TIMINGS\1600,1200\80Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1600,1200\85Hz",,,"2088,1664,1856,1250,1201,1204,0,221850000,8500,8,39956"
    HKR,"TIMINGS\1600,1200\85Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1600,1200\100Hz",,,"2088,1664,1856,1250,1201,1204,0,261000000,10000,8,45371"
    HKR,"TIMINGS\1600,1200\100Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1792,1344\60Hz",,,"2448,1920,2120,1394,1345,1348,4,204750000,6000,8,37062"
    HKR,"TIMINGS\1792,1344\60Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1792,1344\75Hz",,,"2456,1888,2104,1417,1345,1348,4,261000000,7500,8,44170"
    HKR,"TIMINGS\1792,1344\75Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1856,1392\60Hz",,,"2528,1952,2176,1439,1393,1396,4,218250000,6000,8,38721"
    HKR,"TIMINGS\1856,1392\60Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1856,1392\75Hz",,,"2560,1984,2208,1500,1393,1396,4,288000000,7500,8,47353"
    HKR,"TIMINGS\1856,1392\75Hz",Supported,,"BPP+8+16+32,DDRAW"
    HKR,"TIMINGS\1920,1080\60Hz",,,"GTF"
    HKR,"TIMINGS\1920,1080\60Hz",Supported,,"BPP+8+16+32,DDRAW"
    Bonus...
    Última edição por FireMax : 23-08-2009 às 20:56
    Membro Avatar de Rubonov
    Zeh Ruela
    Jan 2001
    [Offtopic] Não sei nada pra te ajudar, mas se passar os cabos por trás e colocar um vidro fumê na frente vai ficar um HomeTheaterPC bunitin bunitin
    Membro Avatar de Garth Algar
    Colaborador hardMOB
    Jun 2009
    Com essa ventilação tosca, esse HD vai viver pouco..
    Membro Avatar de [ExT] ARNOLD
    mude os drivers que vai aguentar!
    aonde achar??? só o gugo pode dizer...
    ja tentou ver na 3dfxzone se tem alguma solução? tentou usar aquele "power strip" que era comum na epoca e permite resoluções custom?
    Vix
    Citação Citando Rubonov Ver mensagem
    Já pensei nisso, mas pra um P3 rodar MKV em 720P só por milagre.
    Montei mesmo para ser um PC de baixo consumo de energia para torrent. O TDP do P3 se não me engano é só 25W. Se somar HD, Voodoo 3 e placa mãe (Shuttle AV18) deve dar no máximo 55W.
    Citação Citando John Connor Ver mensagem
    Uia, vai mesmo.
    Será que você não leu a palavra "Provisoriamente" no meu texto? Além disso tem a fan da ST-350 de 12cm ali do lado puxando o ar. Monitoro a temperatura do HD e não aumentou 1 ºC em relação ao gabinete.
    Pois é, tentei usar ele, mas achei muito complicado.
    Por isso eu editei a linha do INF e adicionei a resolução de 720P que queria.
    Código:
    Fiz o mesmo em 1080P, mas não fumcionou.
    O estranho é que usava 1080P na minha 8600GT via VGA e funcionava de boa.
    qual driver ta usando? tenta um daqueles modificados que tem na 3dfxzone...
    hhehehehh fica maneiro isso , fiz a décadas atrás.
    Vix
    Citação Citando Cross(|_uiz) Ver mensagem
    Lembro quando eu liguei a primeira vez a minha MX 440 na TV de tubo da casa dos meus pais... falei uau!.
    Estou usando o SFFT 1.5, o último que saiu. Mas ele ou nenhum dos outros tem alguma reolução em wide no INF do driver.
    http://www.3dfxzone.it/files/?object=doc&objid=803
    então nao sei, tentaria o power strip
    a resolução da max da voodoo 3 é acima de 1080p... é 2048 por 15xx ou algo assim
    Membro Avatar de manisnk
    Ja chegou o disco voador!
    Jan 2006
    Não e na assiantura do Cocones ou do Calconha que tem uam site só de drivers da voodoo?
    Eu tenho essa VGA ai, muito foda.
    Membro Avatar de nicolasm
    Curti, sou fissurado em enjambração e gambiarras
    Membro Avatar de Cocones
    Opala!
    Me conta um trem:
    Qual S.O. você tá usando?
    Quando precisei de maiores resoluções, usei o Powerstrip (conforme o Spectrobozo citou acima).
    Dependendo do S.O., você pode usar o antigo Voodoolizer que não tem nenhum "bloqueio" de resolução.
    Vix
    Citação Citando Cocones Ver mensagem
    Me conta um trem:
    Estou usando o XP SP3. Como eu disse, modifiquei o INF do driver para aceitar 1360x768. A resolução de 1920x1080 já existia no INF, porém não dava sinal.
    Então eu retirei os valores logo após o HKR,"TIMINGS\1920,1080\60Hz" e deixei parecido com o
    HKR,"TIMINGS\1360,768\60Hz",,,"GTF" mas mesmo assim não apareceu nada.
    Opala!
    Tentou usar o Powerstrip?
    Da ultima vez que fiz algo parecido no .inf (era alguns testes em alguns jogos... anos luz atrás) também não deu certo.
    Tenta com o Powerstrip ai e me conta se deu certo.
    Vou remexer algumas velharias aqui... sinceramente faz uns 2 anos que nem mexo na minha Voodoo
    Edit:
    http://downloads.guru3d.com/PowerStr...nload-169.html
    power strip é bom para esse tipo de coisa....
    Cocones o topico dos voodoozeiros no forumpcs ta abandonadão
    Vix
    Aeee.. foi com o PowerStrip. Pra quem não acreditava, tá aí 1080P na Voodoo 3 a 60Hz! Isso numa plaquinha com 10 anos.
    Desculpa as fotos, mas são do meu K810.
    Não senti nenhuma diferença de velocidade em 2D de 1024x768 para 1920x1080.
    Quero agradecer ao Spectrobozo e ao Cocones pela ajuda!
    Última edição por FireMax : 26-08-2009 às 8:29
    Membro Avatar de IrmaoDoSasuke
    Sep 2007
    Voodoo era foda mesmo..
    Tinha um K6 II 266.... uma Sis 6326 4mb PCI e uma Voodoo2 8mb PCI (ela só era 3D, dai so ativava nos jogos que tinham suporte a ela hehe)
    Nos jogos que tinham suporte, ela fazia milagre.. PC era fraco pra caramba...
    Foda foi a ganância da Voodoo, cabou sendo comprada =/
    Se não teríamos 3 grandes fabricantes hoje hehehe..
    @topic: parabens ae cara, ficou maneiro mesmo.. PCzim simples e que é ótimo pra deixar na sala... a Voodoo ainda tem captura hehe
    Membro Avatar de Proper
    Belém-PA
    Tive uma Voodoo 3 3000... bons tempos, pois você sabia que ela ia rodar de tudo que tinha.
    Fui muito feliz com uma VOODOO 3 3000 e modem 56k, saudades...
    hardMOB Staff - Moderação Avatar de PESCA
    *****O PROTETOR*****
    Citação Citando [ExT] ARNOLD Ver mensagem
    eu quem o diga
    Membro Avatar de Elrond
    Voodoo era foda...
    Qdo rolava Glide nos jogos, era a diferença suprema.
    Membro Avatar de Bozzano
    Nov 2004
    Eu ainda vou montar um Pentium 2 com uma Voodoo Banshee, só pra jogar os jogos da época em 3DFX.
    Pagava um pau tremendo, mas não tinha dinheiro pra comprar
    Ouvia esse nome "Voodoo Banshee" e fica louco, como eu quis isso meo deos.
    Fui ter a minha bem depois, já era a Voodoo 4 4500, competia com a GeForce já, outros tempos.
    Eu queria ter tido uma na época dourada
    Membro Avatar de Mandarin_bu
    Pooutz! Tenho ainda uma banshee 16MB...meldels...Rodava feliz da vida alien vs predator...hauhauhuau
    Membro Avatar de G.Garotinho
    Ráaa, eu ainda tenho minha aceleradora voodoo 1 , jogada em algum canto, bons tempos de pentium 133mhz e quake1 3d a quase 30fps
