Página 2 de 2 Primeira 1 2
    Membro Avatar de Grabbag
    e aquele Samsung T220 é bom?
    Membro Avatar de BIGX333
    Citação Citando Fode Tudo Ver mensagem
    Dvsv...
    Infelizmente eu to falando da taxa de atualizacao!!
    Na area de trabalho do windows fixa aparecendo uns riscos na tela
    da uma procurada no google ou youtube que vc vai ver!!!
    Alias essas 3 plcas so estao me dando dor de cabeca
    eu criei um review na adrena di tri cross depois ce quiser da um olhada
    vai la!!
    http://forums.amd.com/game/messagevi...hreadid=119598
    OK I know why this issue occurs now. It is not a hardware fault. The cards 2D speed is too low to drive a 120Hz monitor. AMD are working on a fix to have a higher 2D speed should 120Hz be set. That will take a while though.
    The issue shouldn't occur in games as obviously the card uses a higher clockspeed while gaming.
    For now you could use a overclocking util such as amdgpuclock or whatever to set a higher 2d clock speed.
    Game.AMD Administrator
    Thanks! I tried gaming with 120Hz and it seems to work fine on the 5870, although it didn't work right with the 4870. Haven't had a chance to play with the 2D clocks but I will give that a try later today.
    TF2 with 4xAA, 16xAF at constant 120Hz with v-sync enabled. . . just awesome. Thanks everybody for your help!
    Chegou a tentar?
