Página 5 de 8 Primeira ... 3 4 5 6 7 ... Última
  1. #101
    Originalmente enviada por kakaroto(dbz)
    hauhauha q comédia essa foto!!!!.......... se essa merda de GF4 é tão poderosa!!! fica de frente pruns monstrinhos, comessa a dar tiro
    e da ALT+PRintScreen pra eu ver!!!!
    TOMOU? DEVE SER O MEU PROCESSADOR NE OTARIO?
    Tae o amado anisotropic PORCO da Ati:
    (fonte reactor critical)
    "When using anisotropic filtering, the image quality is significantly higher than with trilinear filtering. There is a big difference, however, between NVidia's and ATI's chips, which first of all concerns the walls that are situated at the angle 45 degrees to the ceiling. Vertically and horizontally oriented fragments look similar with the both companies' chips, since only strictly vertically or horizontally oriented footprints are used. But those fragments which are oriented at 45 degrees just correspond to the case I examined above, where the ATI's filter can not cope with the task.
    NVidia's level 8 anisotropic filtering provides the highest texture quality. Trilinear filtering provides the lowest quality. ATI's anisotropy works fine with ceiling and walls (the quality is the same as NVidia's), but it can do nothing about the walls at 45 degrees, in which case the quality remains at the level of trilinear filtering.
    As you see, NVidia has implemented anisotropic filtering at a higher level of quality. But ATI's simplified anisotropy has one great advantage - the speed. When turning on anisotropic filtering on Radeon series cards the speed drops by 5-10%. With NVidia's chips the speed drop is much more, up to 20-40%. In Radeon, anisotropic filtering is "free", though the image quality is lower. "
    Atualmente soh tem 1 jogo q dah pau, q eh o NFS:HP2
    Aqui funciona perfeito...
  4. #103
    só sei q brigar por causa de placa de vídeo é um coisa muito nerd.. pqp vcs dois (motherf e kakaroto), vão trabalhar...
  5. #104
    Que coisa mais ridícula brigar por uma ou por outra marca... alguém ganha alguma coisa aqui para defender tal ou qual marca???
    mas o fato é:
    A Nvidia perdeu seu ciclo de 6 meses de renovação de produtos para lançar a NV30...
    Seja o que for, a placa vai custar muito $$$... só vai valer a pena pra quem sempre compra a placa mais cara, não importando o preço, pq a performance vai ser astronômica, mas o preço também, então o custo benefício não será grande coisa...
    Em compensação, até lá a R9700 vai baixando de preço... e a Ati vai preparando a R350...
    Isso é muito sério para a Nvidia.
    Placas high-end representam menos de 5% do mercado... também custando esses preços absurdos...
    Viva a NV30... a verdade é que o Doom III vai impulsionar e muito as vendas da NV30...
    Daqui a uns 9 meses deve ter uma versão econômica da NV30, tipo a Ti4200... aguardem...
    E aquele texto sobre o aniso da Ati é referente a R8500... a R9700 pode fazer tanto o Aniso da Ati(opção performance) quanto o Aniso padrão da GF4(opção quality, faz aniso em qualquer ângulo, em conjunto com o filtro trilinear)...
    E ainda pra completar, na Anandtech tem os benchs da R9700 com AA + Aniso no UT2K3, que é um jogo com uma engine atual, BEM PROGRAMADA, e a R9700 espanca as GF4 por uma diferença abismal... e olha que UT2k3 tem até o logo da Nvidia no jogo... não acho que Ati seja tão ruim assim... Leiam com atenção... e o aniso é similar, por favor, não confundam R8500 com R9700... aliás, tem um monte de carinha aí que se diz o entendido e tal, mas que é cego e não sabe interpretar nada... aff...
    Fanáticos SUX...
    flw
  6. #105
    AGO
    AGO está offline
    calma meninada!
  7. #106
    o único bug q tem nesse jogo com a minha V3 é q as rodas ficam cinzas,
    com o desenho certinho, mas sem a cor
    mt sinistro
  8. #107
    A grande vantagem do r300 e futuramente do nv30 nao eh a capacidade d mostrar 64 bits de cores, mas a capacidade de usar cores com valores de ponto flutuante. 32 bits sao mais q suficientes, ja sao suficientes pra fazer um (desculpem a palavra gay) degrade dos tons mais escuros pros mais claros sem os steps q se ve em 16 bits. sendo 0 o preto total e 255 o branco puro, nao ha mais o q se adicionar, a vantagem d ter mais bits seria aumentar a quantidade de semitons inteiros, mas com ponto flutuante vc pode dividir os tons quase q infinitamente, sem ter q pra isso aumentar o tamanho dos arquivos em quatro vezes
  9. #108
    Originalmente enviada por J.Quest
    E isso com esses efeitos de luz do Doom3 e dos jogos da nova geracao, vai ser indispensavel, pq conforme o power das placas for melhorando, mais detalhados os cenerios vao ficar, e mais cores sombras vao rolar, e por mais q sejam suficientes os 32 bits pra cor/sombra, com 64 ou 128 bits serao usados pra fazer refracao em materias, ambientes etc...Imagina o q da pra fazer debaixo dagua, ou com fumaca em 64 bits...euhaeuhaeuh eh esperar pra ver..., dia 18 tamos ae.
  10. #109
    Originalmente enviada por motherfucker
    dia 18 tamos ae.
    heuahuea, tô com preguiça de procurar...
    Sai dia 18 de novembro?
  11. #110
    BOMsolmito 2018!
    Como eu sempre digo , as radeons esmagam as geforces ! Quem fala o contrario é prq tem uma nvdia e transa com ela todo dia !
    E vem postar fotos de sites em q a nvidia da suporte ! ! fala sério
    eu jogo jogos em 1600 ! A minha placa permite !
    e eu nao perco nem 1 fps por causa disso
    A imagem da Radeon é 4x melhor !
    A Perfomance entao ! Pfii !
  12. #111
    Originalmente enviada por SqS.Vulture
    Dia 18 vai ser o lancamento do chip em Las Vegas, eles entram no mercado americano antes do natal e em janeiro comecam as vendas em larga escala.Ou seja daki a uma semana vai ser divulgado o potencial do nv30, por isso o topic chama "saindo do forno", e por isso os fans da Ati tao todos aki xorando
  13. #112
    Membro Avatar de Elrond
    Xorando de tanto dar risada...
    Pq ateh agora ng viu nada...
  14. #113
    Membro Avatar de SparkS
    Viram o emulador pow
  15. #114
    Segunda feira q vem nois conversa!
  16. #115
    Esse chorando nao foi pra mim, ja q eu nao tenho placa da ATI, engraçado q o Voodooman e mais uns 3dfx zombies ja me chamaram de amante da nVidia, isso so confirma q eu nao puxo o saco de nenhuma empresa, so da AMD, mas isso é outra historia
    Concorrencia rlz, sem ela os preços estaria muito altos. Por isso ninguem ira chorar, com isso o preço das outras placas abaixara, so vc q é doente pela nVidia q pensa desse jeito.
  17. #116
    O mais forte do universo!
    e vcs ainda insistem em discutir com esse cara!
  18. #117
    Old School 2001
    Vão se ferra todos vc´s, ficam brigando por coisa inuteis! Bom... minha opinião sobre placas da NVIDIA e ATI...A NVIDIA procura melhorar as performances da sua placas depois de lançadas,atraves de seus otimos drivers... o seu projeto físico em si não é tão bem elaborado quanto a da ATI..digamos se formos compararmos placas da mesma geração ou semelhantes...mas a ATI ainda peca no seu drivers que não são tão bons quanto a NVIDIA....Falei simples e objetivo!
  19. #118
  20. #119
    32 bits não são mais do que suficientes em muitos casos. Olhe esse exemplo:
    "ATi shows a demo of a low polygon car that is visually enhanced with dot3 bump mapping using a 64-bit precision normal map. This kind of effect was impossible with 32-bit integer normal maps, as you can see in the demo pictures below."
    Fonte: http://www17.tomshardware.com/graphic/02q3/020718/
  21. #120
    Membro Avatar de NoOne
    O motherfucker.. se o NV30 não for 2x uma GF4.. vai ser desilusão total.. hehehe
    sobre os drivers da ati.. ela melhora tanto os drivers que só diminuindo a qualidade das imagems pra conseguir melhor resultado.
  22. #121
    uheauaeh tao prometendo + q o dobro, e os japinhas(koreanos ne?3:15 da matina..) da Nvidia (ao contrario duns canadenses ae) nao sao de brincar em servico nao.
  23. #122
    Novamente um
    Em Ação
  24. #123
    Duvido q seja o dobro.
    Se for tão fácil eu quero o 8x em 3 semestres, ou seja, um ano e meio...
  25. #124
    uepa! do jeito q vc ta falando parece q so lancaram o g4 6 meses atras!
  26. #125
    o motherfucker
    quanto tu pago na tua ti quando comprou?
