    Membro Avatar de NoOne
    Detonators Library
    Detonator 41.09
    Info: http://www.nvidia.com/view.asp?IO=winxp-2k_41.09
    OS: Windows XP / 2000
    Version: 41.09
    File Size: 16.3 MB
    Release Date: December 3, 2002
    WHQL Candidate
    Downloads: http://download.nvidia.com/Windows/4...09_win2kxp.exe
    Mirror 1: ftp://download.nvidia.com/Windows/41...09_win2kxp.exe
    Mirror 2: http://download1.nvidia.com/Windows/...09_win2kxp.exe
    Mirror 3: ftp://download1.nvidia.com/Windows/4...09_win2kxp.exe
    Release Highlights:
    • Compatibility and performance enhancements for Windows XP Media Center Edition
    • Up to a 25% increase in performance
    • nView™ 2.0 multi-display technology increases productivity and provides the necessary tools to control the way users access and view applications.
    • NVRotate™ enabling image rotation on today’s advanced flat panel displays.
    • NVKeystone™ allows for real-time image correction on portable projectors and heads-up displays.
    • Digital Vibrance Control™ allows users to adjust color controls to achieve accurate, bright colors under all conditions.
    • New control panel streamlines user interface and enables faster and easier access to all video settings
    • Robust Channels enables higher faster performance and better stability for all applications through fail-safe paths in the drivers
    • CineFX™ Simulator allows developers to use Cg—“C for graphics”—to write complex shaders in a high level language faster and more easily than before.
    • NVIDIA’s patented Unified Driver Architecture (UDA) – supports all products in a single driver binary
    Pra galerinha que curte os detonator..
    Segue abaixo um URL da própria NVIDIA com todos os Detonators..
    Detonator Library
    http://www.nvidia.pl/download.html?NVIDIA_Referencyjne
    NoOne
    NEO
    NEO está offline
    Membro Avatar de NEO
    Dec 2000
    Mto bom
    Membro Avatar de edsonmassao
    +15 anos de hardMOB
    bom bom bom! mais fácil de pegar do q no guru3d...mas putz...q idioma é aquele?
    Originalmente enviada por edsonmassao
    deve ser Polonês
    Isso é o de menos.. AEHHAHAEU
    bookmark this page now!
    bom toke, thnx !
    valeu nune
    Up pra nos
    Detonator 41.09
    Version: 41.09
    File Size: 16.3 MB
    WHQL Candidate
    Release Highlights:
    ALguém já teve algum problema com esse driver? Tipo no FIFA2003, NFS:HP2 e RALLISPORT?
    qual o melhor detonator pra programas de design ?
    exemplo: autocad 2000, 2020design...
    programas que usam modulos...
    UP pra ele!!!
    Naum vai esse link!!!
