    May 2000
    Grvador MSI, SAMSUNG, LG - Alguem sabe se prestam?
    Ae, pessoal , eu tava olhando numa loja ae pra comprar um gravador de CD ..
    me deram alguma opcoes ...
    Gravador MSI 40X12X48 (CR40-A2 MS-8340S) - BOX
    Características
    BURN-ProofT
    40x Writing, 12x Re-writing, 48x Reading E-IDE / ATAPI Interface
    Flash Memory Upgrade Enable System
    2MB Built-in Buffer Size
    Anti-Vibration System
    Front-panel Playback/Skip function button
    Emergency Eject
    Noise-reduced function
    Power Saving Function
    Dust protection design
    Popular CD burning Software Package
    EXACT-Rec monitors accuracy of writing
    AWSS technology reduce vibration & noise
    ROPC technology boosts recording reliability
    MMC 3 compliant (Write)
    ATAPI SFF8020 v2.6 compliant (Read)
    Motorized easy touch loading tray
    Windows® XP WHQL cerfificated
    ISO 9660 compliant
    Gravador CD-RW Samsung 40X12X48
    Características
    Record: 40X (6,000 KB/sec) Rewrite: 12X (1,800 KB/sec) Read: 40X (6,000KB/sec) Burst Transfer Rate PIO Mode 4 (16.6 MB/sec) DMA Mode 2 (16.6 MB/sec) Recording Capacity CD-RW Disc 700/650MB (type 80/74) CD-R disc 800/700/650/550MB (Type 90/80/74/63) Interface EIDE/ATAPI Buffer Memory 2MB Flash Memory 1MB Drive Mounting Horizontal/Vertical Average Access Time 110ms Supported Disc CD-R,CD-RW,CD-DA, CD-ROM/XA,CD-ROM Video-CD, CD-I, Photo CD,CD-Extra,CD-TEXT Audio S/N Ratio >75dB Channel Separation >65dB Writing Method DAO(Disc At Once), TAO(Track At Once) SAO(Session At Once), Multisession, Packet Writing (Variable, Fixed Packet) Physical Specification Dimensions (WxHxD mm) : 148.2 x 42 x 184 Weight (kg) : 0.75
    Gravador de CD RW LG 40X12X40
    Características
    Capacidade do Buffer de 8 Mbytes
    Interface E-IDE, ATAPI, Ultra
    Formatos de discos aceitos CD-R/CD-RW, CD-ROM, CD-DA, CD-ROM XA
    Sistema operacional compativel: Windows98/95/ME/XP /NT /2000, OS2Warp
    8MB Buffer Memory with Exaclink buffer underrun proof technology
    Qual desses é melhor ?
    e porque é melhor ?
    alguem indica / contra-indica????
    Valeussssssssss
    May 2000
    alguem que entenda , me ajudaaaaaaaaaaa!!!!
    cereteza q esse LG tem 8mb de buffer?achu q nao
    deve ter soh 2mb
    www.lge.com
    v ai no site
    se tiver 8mb mesmo pega o LG
    pq os otros são 2mb
    e gravador da MSI nunca ouvi falar
    compra eh baum s
    tenhu LG , mt bom
    11!
    Seguinte
    As 3 são marcas boas, mas a MSI não tem tradição em gravadores de CD não (pelo menos eu nunca tinha visto um gravador MSI até hj).
    A LG é a marca mais conhecida do público em geral. Faz excelentes gravadoras, mas por ser mais conhecida acaba sendo mais cara.
    Samsung é uma marca boa também.
    Mas hj em dia vc tem que se preocupar com uma coisa: As tecnologias que não deixam vc perder um cd por falta de dados no buffer. Chamas das de Burnproof.
    Dos gravadores que vc postou ae, somente o da samsung não tem essa tecnologia, e por isso deve ser descartado da sua escolha. O MSI tem a tecnologia Burnproof e o LG a Exaclink.
    Tamanho de buffer já não é importante hoje em dia, justamente por causa dessas tecnologias.
    No resto, o LG e o MSI são praticamente iguais. Aí é com vc: Eu compraria o que tivesse mais barato.
    Mas eu vou te aconselhar a olhar uma outra marca: CyberDrive. É uma marca muito boa, e justamente por ser desconhecida do grande público ela vende seus drives por um preço mais em conta. Se eu não me engano, a Cyber já tem uma gravadora que grava em 48x/16x/48x
    mais informações sobre a marca vc acha em www.cyberusa.com
    Eu tenho o modelo 32x/12x/48x, comprado a mais de um ano. Até hj foram mais de 80 cds gravados e nenhum perdido. E olha que eu uso só midias "boas" ehhehe (Smartbuy, prodisc, ou seja as que custam 85c ).
    Consigo gravar tranquilamente em 32x, um cd de 700 megas demrora uns 3 minutos e meio
    O cara q divide quarto comigo tem um de uma marca mto estranha TDK, alguma coisa assim, mas ele vai comprar um da Samsung no dia 15, dia em q a gente vai pra miami, de 48x12x48. Eu vou comprar um igual a esse, mas da LG, mas so em Janeiro.
    May 2000
    Bom , o gravador LG eu jah tive um de 24x10x40 ... era muito bom, mas tive que vende-lo pra um cliente que precisava urgentemente , e como o meu era novo , acabei vendendo ele mesmo.
    Eu coloquei esse topico , foi mais pra saber as experiencias do pessoal , e acabei obtendo uma outra informação muito importante: o tamanho do buffer nao faz tanta diferença... mas sim a tecnologia utilizada no mesmo!
    Bacana! por isso que eu sempre consulta com os conhecedores de plantao do hardmob! :-)
    Eu estava na grande duvida em relação ao gravador MSI , pois a marca fabrica muitas peças ótimas!!! agora , em relação a gravadores de CD , desconheço completamente.
    Como eu acabei de ligar pra loja , e acabaram todos os gravadores MSI, ( datelhe que a vendedora façlou que ele é muito bom , e que todos os clientes gostaram muito tb , além tb de ter sido comentado na INFOEXAME desse mês ou do mes passado , nao sei) devo comprar um LG mesmo ...
    Obrigaduuuuu
