    Membro Avatar de Sherman
    Ajuda ai negada :) URGENTISSIMO!Sobre Spywares
    seguinte passei o Ad-Ware no meu micro, firmza?entao detectou alguns "spywares", axo q eh por isso q nao consigo abrir meu icq, tenho q usar o lite, no entanto apareceu arkivos aki q nao se se posso deletar, vow postar o log e voces me ajudam firmeza?por favor sejam sincero. meu pc ta em jogo
    Scan initialized on 28/12/2002 12:57:07.
    (AAW release 5.83, referencefile 029-15.06.2002)
    Started memory scan
    Running processes:
    #:1 : smss.exe
    #:2 : winlogon.exe
    #:3 : services.exe
    #:4 : lsass.exe
    #:5 : svchost.exe
    #:6 : spoolsv.exe
    #:7 : svchost.exe
    #:8 : navapsvc.exe
    #:9 : npssvc.exe
    #:10 : nvsvc32.exe
    #:11 : regsvc.exe
    #:12 : mstask.exe
    #:13 : winmgmt.exe
    #:14 : alertsvc.exe
    #:15 : explorer.exe
    #:16 : mixer.exe
    #:17 : icqlite.exe
    #:18 : ndetect.exe
    #:19 : navapw32.exe
    #:20 : iexplore.exe
    #:21 : mscstat2.exe
    #:22 : ad-aware.exe
    Memory scan result:
    Total modules found:22
    Suspicious modules found:0
    Started registry scan
    Gator key:HKEY_CLASSES_ROOT\clsid\{21ffb6c0-0da1-11d5-a9d5-00500413153c}\
    WurldMedia key:HKEY_CLASSES_ROOT\interface\{3cb6def9-1db2-4b5d-9a70-9bf8345ed73c}\
    WurldMedia key:HKEY_CLASSES_ROOT\mbho.iehlprobj\
    WurldMedia key:HKEY_CLASSES_ROOT\mbho.iehlprobj.1\
    Gator key:HKEY_LOCAL_MACHINE\software\gator.com\
    Alexa key:HKEY_LOCAL_MACHINE\software\microsoft\internet explorer\extensions\{c95fe080-8f5d-11d2-a20b-00aa003c157a}\
    WurldMedia key:HKEY_CLASSES_ROOT\typelib\{4769dd43-4045-405c-945f-752516445e89}\
    Web3000 key:HKEY_LOCAL_MACHINE\software\microsoft\windows\ currentversion\run\trickler
    Started extended registry scan
    Registry scan result:
    Suspicious keys found : 8
    Started folder scan
    Warning, no disk in drive (A)
    Gator folder:C:\Documents and Settings\Administrador\Configurações locais\Temp\fsg_tmp
    Folder scan result:
    Folders processed:1216
    Suspicious folders found:1
    Started file scan
    WurldMedia file:C:\WINNT\system32\mbho.dll
    Other file:C:\Documents and Settings\Administrador\Cookies\[email protected] dby.advertising[2].txt
    Doubleclick file:C:\Documents and Settings\Administrador\Cookies\[email protected] eclick[1].txt
    Other file:C:\Documents and Settings\Administrador\Cookies\[email protected] lick[2].txt
    Other file:C:\Documents and Settings\Administrador\Cookies\[email protected] st[2].txt
    Other file:C:\Documents and Settings\Administrador\Cookies\[email protected] er14.sextracker[1].txt
    Other file:C:\Documents and Settings\Administrador\Cookies\[email protected] acker[1].txt
    Other file:C:\Documents and Settings\Administrador\Cookies\[email protected] er1.sextracker[1].txt
    Other file:C:\Documents and Settings\Administrador\Cookies\[email protected] click[1].txt
    File scan result:
    Suspicious files found:9
    Scanning finished
    Components ignored:0
    Total components found:1
    ajuda ai UP!
    Po cara so pra avisar é no Programas isso..
    E tipo não sei te ajudar não
    O único q é meio arriscado de deletar é o dll, o resto pode deletar. Vc tem q fazer o update desse reference file pq ele tá meio antigo...
