    Membro Avatar de Gung@
    Gunga
    Novo Catalyst 3.0
    Versão revisada do 6255
    Fixed in this driver:
    Display Driver
    RADEON™ 9700 / RADEON™ 9500 Series - OpenGL based games stutter after installing wxp-w2k-r9700-7-81-021213a-006924C.exe driver download package.
    Running the games Zanzarah or Star Trek-Amada II at 1024x767 32bpp with Anti Aliasing enabled at 6x no longer results in a black screen display
    Selecting single player mode in Heavy Gear 2 has no longer results in display corruption when using the RADEON™ 9700 under Windows XP
    Display corruption is no longer seen around the start button when using the RADEON™ 8500 under Windows XP
    Running the game Serious Sam Second Encounter when using the RADEON™ 7000 under Windows XP, no longer results in a system hang when the display is set to a resolution of 1024x768 or higher
    Playing Quake3 at high quality setting would result in display corruption when firing a weapon. This issue occurred when using the RADEON™ 7500 under Windows XP
    After installing the display driver, the system no longer detects a standard TV instead of an HDTV
    Running the CyberLink PowerDVD application and moving the display window around either the Windows XP or 2000 desktop no longer results in a system hang
    Playing a DVD under the ATI MultiMedia centre in a Windows XP operating system with the All-in-Wonder™ 9700 PRO no longer results in low audio output
    http://www.ati.com/support/drivers/w...e&cmdNext=Next
    Membro Avatar de Elrond
    E nada de NFS eheheh...
