Página 2 de 2 Primeira 1 2
    Meu jovem provavelmente o seu problema esta na fonte, pode ser que tenha queimado o fusivel interno na mesma ja que a CPU nao da sinal de vida, troque a fonte ou o fusivel e faça novamente o teste.
    SiSoftware Sandra 2003
    Processor(s)
    Model : AMD Athlon(tm) XP 2100+
    Speed : 1.77GHz
    Model Number : 2100 (estimated)
    Performance Rating : PR2565 (estimated)
    Type : Standard
    L2 On-board Cache : 256kB ECC synchronous write-back
    Temperature Sensor(s)
    Board Temperature : 35.0°C / 95.0°F
    CPU Temperature : 31.0°C / 87.8°F
    Power / Aux Temperature : 32.0°C / 89.6°F td
    HD / Aux Temperature : 42.0°C / 107.6°F td
    Cooling Device(s)Thermaltake Volcano 9 and Thermaltake Volcano 7
    Auto Fan Speed Control : yes
    Chassis Fan Speed : 4116rpm
    CPU Fan Speed : 1962rpm
    System Mainboard Soltek SL-75DRV5
    Bus(es) : ISA AGP PCI USB SMBus/i2c
    MP Support : No
    System BIOS : Phoenix Technologies, LTD 6.00 PG
    System Mainboard : VT8367-8233
    System Chipset : VIA Technologies Inc VT8366/A,VT8367 Apollo KT266/A,KT333 CPU to PCI Bridge
    Front Side Bus Speed : 2x 142MHz (284MHz data rate)
    Installed Memory : 512MB DDR-SDRAM
    Memory Bus Speed : 2x 142MHz (284MHz data rate)
    Video System
    Monitor/Panel : SyncMaster 703(M)s/ 753(M)s/750(M)s/753(M)v, MagicSyncMaster CM173A(M)
    Adapter : NVIDIA GeForce4 Ti 4200
    Physical Storage Devices
    Removable Drive : Unidade de disquete
    Disk Drive : Maxtor 6Y060L0
    Disk Drive : ST330621A
    CD-ROM/DVD : HL-DT-ST CD-ROM GCR-8521B
    CD-ROM/DVD : PLEXTOR CD-R PX-W8432T
    Logical Storage Devices
    1.44MB 3.5" (A) : N/A
    Hard Disk (C) : 28.0GB (21.9GB, 79% Free) (FAT32)
    Hard Disk (D) : 14.0GB (13.7GB, 98% Free) (NTFS)
    CD-ROM/DVD (E) : N/A
    CD-ROM/DVD (F) : N/A
    Hard Disk (G) : 28.0GB (12.3GB, 44% Free) (FAT32)
    Hard Disk (H) : 14.0GB (10.9GB, 78% Free) (NTFS)
    CD-ROM/DVD (I) : N/A
    Peripherals
    Serial/Parallel Port(s) : 2 COM / 1 LPT
    USB Controller/Hub : Controlador host universal VIA USB
    USB Controller/Hub : USB Root Hub
    Keyboard : ASUS OSD PS/2 Keyboard Filter Driver
    Mouse : Mouse compatível com PS/2
    Human Interface : Dispositivo de porta de jogo genérico
    Human Interface : HID-compliant game controller
    Human Interface : Dispositivo de interface humana USB
    MultiMedia Device(s)
    Device : MPU-401 Compatible MIDI Device
    Device : Porta de jogo padrão
    Device : VIA AC'97 Enhanced Audio Controller (WDM)
    Operating System(s)
    Windows System : Microsoft Windows 2000 Professional Ver 5.00.2195 Service Pack 3
    Network Adapter(s)
    Networking Installed : Yes
    Adapter : TELES.S0/PCI
    SDS.Gilson
    galera eu jah cansei repetir
    A FONTE NAO TA QUEIMADA OIAHEOAIEHAI
    jah testei outra fonte e tbm nao deu sinal de vida
    acho que a mobo foi r.i.p =[
    up !
    alguma ideia antes do velorio ?
    UPZIM
    ok
    vo considera-la R.I.P
    Cara, na minha deu o mesmo problema.
    Do nada parou de funcionar.
    E depois da garantia ter acabado.
    Só que a minha era assim, não funcionava num dia
    mas daí a 2 dias ela funcionava bem, podia
    desligar, ligar e ela funcionava normal
    naquele dia.
    No dia seguinte ela não ligava novamente.
    Daí a 2 dias ela ligava normalmente de novo.
    E assim se sucedia, 1 dia de trabalho e 2
    de folga.
    Mandei prá uma empresa que conserta mobos
    e os caras ficaram quase 1 mês com ela
    e não conseguiram descobrir o problema.
    Sinistro.
    Se vc tiver alguma solução prá esse
    nosso problema me avise, ok?
    Um abraço.
