  1. #76
    Originalmente enviada por freeh
    po,
    soh comprei esse pc pq a minha avoh ta me dando ;P
    refiz o pedido...
    ficou assim:
    1 HD MAXTOR 80GB 7200rpm - US$ 122.00
    1 AMD ATHLON XP 2600+ BOX - US$ 344.00
    1 ATI RADEON 9700 PRO 128MB DDR TV/DVI - US$ 409.00
    2 DDR PC3200 CORSAIR 256MB CAS2 - US$ 218.00
    1 ASUS A7N8X DELUXE - US$ 172.00
    1 COOLER FAN THERMALTAKE VOLCANO 9 - US$ 41.00
    Valor do pedido: 1,306.00
    Valor do frete: 100.00
    Total Geral: 1,406.00
    c/ o desconto: U$ 1,335.70
    vai da uns R$4,500...
    Especificaçoes:
    Peso: 200 gr
    AMD ATHLON XP 2600+ 2.133Ghz 333FSB - Retail Box
    "Thoroughbred" core! - 1 Year Warranty
    Peso: 50 gr
    CORSAIR CMX256A-3200 256MB PC3200 400Mhz 32Mx64 184 DIMM Unbuffered Cas2. Memory w/ heat spreader. Lifetime warranty.
    Peso: 500 gr
    NEW Application for AMD Athlon XP up to 2600+ and Intel Socket 370 & AMD Socket 462, 3 Fan Functions in V9, With Smart Case Fan II, SPECIFICATION: P/N A1365, Cooler Dimension 80x80x77.3mm, Fan Dimension 80x80x25mm, Rated Voltage 12VDC, Started Voltage 6VDC, Rated Current 0.20AMP ~ 0.70AMP, Power Input 2.40W ~ 8.40W, Max. Air Flow 20.55 CFM at 1300 rpm, 75.7 CFM at 4800 rpm, Air Pressure 1.45mmH2O at 1300rpm, 8.43mmH2O at 4800rpm, Noise 17 dB at 1300 rpm, 48 dB at 4800 rpm, Bearing Type: Two Ball Bearing, Life Time 50,000 hours, Connector: 3 PIN, Tt Fan grille TR=0.38C/W.
    Peso: 800 gr
    NEW ATI RADEON 9700 PRO 128MB DDR DVI/TV AGP 8X - Retail Box - Powered by the revolutionary RADEON 9700 PRO graphics processing unit (GPU) with core engine at 325Mhz clock speed / 620Mhz DDR memory clock speeds. Supports ATI TRUFORM, SMARTSHADER, SMOOTHVISION, and HYPER Z II technologies. Supports DirectX 9.0 and OpenGL 1.3 features. Manufacturer: ATI. Display configuration supports CRT, DVI-I & TV-Out. Accessories included: 1 set A/V cable / S-Video Cable, S-Video to AV Converter, DVI to CRT Dongle, Cool Color Classic Hard Casing, Manual, CD Driver with S/W DVD.
    ASUS A7N8X DELUXE
    Peso: 1500 gr
    NEW ASUS A7N8X DELUXE nForce2 Motherboard Retail - Supports Socket A AMD Athlon/XP/Duron (support AMD XP2800) Throughbred core CPU ready, Chipset NVIDIA nForce2 SPP, nForce2 MCP-T, FSB 333/266/200MHz, 2xIDE ATA133, 3x184-pin DIMM, PC3200/PC2700/PC2100 non-ECC DDR Ram), 1xAGP (Pro/8X), 5xPCI, 6xUSB(2.0), Onboard Serial ATA Silicon Image Sil 3112A Controller with 2 ports, support RAID 0/1, Onboard Audio Realtek ALC650 6-ch w/built in amplifier, integrated APU (Audio Processor Unit), Soundstorm Encoder, Onboard LAN MCP integrated 3Com MAC + Broadcom AC101L PHY, Onboard Firewire 1394 2 Ports MCP-T integrated IEEE 1394a + Realtek PHY 8801B
    po, realmente saiu "caro"...
    nãõ vejo a hora de chegar... acho que a a1 soh manda as remessas nas sextas...
    então, agora, soh na proxima sexta + 10 dias uteis =p
    ainda preciso escolher o gabinete.. to na puta duvida.. pois aqui, nao achei mais que fonte 350w (merda de cidade)
    bem, espero que esse pc seja legal, nao pra jogo, mas sim pra aplicacoes graficas
    webdesign rulz!
    agora sim.. ta mto boa essa config...
    so falto mudar o cooler.. pq nao pegou o v7+ q eh melhor?
    vjm
    vjm está offline
    tu não gosta do hd western digital?????????
