    MX700 Perde ou não a precisão para jogos já que ele é sem fio? Eis a questao!!!!!!!!!
    Minha irma vai trazer para mim ou um MX500 ou um MX700 dos EUA
    Provavelmente ela vai trazer MX700 porque só ta achando dele.
    Mas agora tem uma coisa que ta me deixando com muita curiosidade aqui!!!!!!!!!!!
    o MX700 perde ou não perde a precisão já que ele é sem fio??????????????
    Ele perde a precisão e passa a ser pior que o MX500??????????
    Eis a questao!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    n0x
    n0x está offline
    Cold shower. It helps.
    a logitech afirma q não buga...
    agora faltam relatos da vida real
    bom, leia as duas ultimas linhas, o comentario do gamer
    The really new feature of the MX 700 is its new cordless transmission technology, called Fast RF. This is still radio frequency, but the number of mouse-receiver exchanges per second has gone up a lot as it is now 125 instead of the average 50 on an ordinary cordless mouse. And as Logitech says, this is also the top limit of exchanges possible with USB. So, in theory, the lack of a cord is no longer a source of lag in fast movements. This should be the first cordless mouse to suit players of first person shooter-style games. While we are on the subject, compared to PS2, USB is a step backward for the mouse, because PS2 can handle twice as many exchanges per second. That said, quite frankly, and even though the sticklers will criticize, the speed of exchange in USB is quite adequate for a mouse. To make their cordless system even more efficient, Logitech have ensured that the data prepared for the PC is as short as possible between capture by the sensor and sending. This means there will never be a bottleneck of data, so no data will be lost. And in use, this definite improvement is really noticeable. You won't detect any lag in relation to a wired model. We got our fragger pro to play and he corroborated: "This mouse deserves the label 'Approved by hardcore gamers.'"
    sei la, da meio medo de comprar esse mx 700, mas pelo comentario do cara deve ser bom.
    n0x
    n0x está offline
    Pois eh, com base nesse texto não buga mesmo...
    Mas era mais garantido a opinião de alguém daqui q tenha ele...
    Originalmente enviada por NoxiTz
    Nunca vi alguém aqui do forum que tenha o MX700
    Membro Avatar de Thomazini
    Pelo menos os mouses mais antigos e de bolinha (como o meu) naum tem nenhum problema com relação ao wireless..
    Meu mouse e meu teclado eu naum dou naum vendo e naum troco por nada no mundo.. e acho mto dificil terem piorado a qualidade em relação a isso... se seu medo for qto ao sensor optico daí jah nem posso dizer nada mas em relação ao sistema wireless da logitech pode confiar cara! vc naum vai se arrepender naum
    n0x
    n0x está offline
    A minha duvida eh c ele tem alguma deficiencia comparado ao mx500 mesmo...
    Caso o mx700 seja simplesmente um mx500 sem fio, desempenho identico e tal, eu corro atras de 1, senão fico com o mx500
    Axo q a duvida do Mech eh essa tbem (ou parecida )
    Eita duvida
    eheh como ele eh sem fio... vc nao vai poder jogar 13412312 horas a fio.. tem q recarregar a bateria.. =[
    n0x
    n0x está offline
    Isso ai não eh problema...
    Parece q a logitech pensou em tudo hehe
    Without battery changes, ecology lives! Considering the rate at which you change the batteries on an ordinary cordless mouse, the environment will obviously be grateful for these rechargeable ones. You put the mouse on the receiver, which acts as a charger. The only complaint about this system is that the receiver is not exactly elegant and discreet. Putting the mouse on it is no great hassle because you don't need to do so very often. If you leave it on overnight, it will last a good week before running down.
    http://www6.tomshardware.com/consume...110/index.html
    hhmm...
    Olha deixa eu colocar a seguinte questão...
    Uma vez participei de uma discussão parecida no fórum da unigames em que alguns jogadores de FPS como CS e Quake disseram que devido ao mouse ser wireless ele tinha um pequeno delay entre a movimentação e a ação na tela, coisa imperceptível de milesegundos só que dae já pode fazer a diferença...
    Detalhe: eu não tenho mouse wireless só estou deixando a questão para o pessoal investigar e fazer a melhor compra...
    Eita duvida
    minha duvida é essa
    exatamente
    n0x
    n0x está offline
    Re: hhmm...
    Pois eh, mas isso eh fato comprovado, mouse wireless tinha (e ainda tem) um delay
    Só q a gente ta falando do mx700, ou seja, teoricamente a ultima tecnologia em assunto de mouses, além de ser de uma marca de renome...
    De acordo com a review do Toms, mas precisamente na parte q o Mech postou, eles falam q não tem esse lag. Se alguém confia 100% no site deles, então não restaria duvidas... Mas eu ainda prefiro a opinião de alguém daqui
    Po, ninguem tem o mouse ai ?
    Nem os mouses antigos tem delay....
    quem fala isso está mentindo ou naum sabe o q está falando..
    a única coisa q pode acontecer (e já aconteceu comigo hehe) é acabar a pilha no meio do jogo.. daí bate mó desespero hauhauahuahuh mas naum é nada q naum faça vc morrer de rir depois
    Membro Avatar de SparkS
    Pelo menos qnd eu usava um da logitech sem fio antigasso eu usava ele normal e não via os delays e olha que usava uma sensitivity meio absurda :P
    O MX700 tem pilha recarregavel... vc deixa ele no berço quando nao ta usando... e mesmo assim, o site diz que a pilha dura uma semana
    May 2000
    eu tenho 1 mx 700 e nao buga + é pesado pra porra
    é tao pesado assim?
    da pra diminuir o peso dele abrindo e tirando alguns daqueles ferrinhos?
    Pela leitura do review a transferência de informação é de 125Hz no wireless. Para quem usa USB pelo jeito é o máximo possível. Eu continuo preferindo usar meu mouse com fio na PS2 a 200Hz. Tô satisfeito assim.
    up
    n0x
    n0x está offline
    Originalmente enviada por Thomazini
    Então vários sites de reviews mentiram?
    Vale levar em conta q eles testam os mouses ao extremo, vc fez isso?
    Eh normal vir alguém dizer "meu mouse da troni não buga nem fodendo"... da nada
    Sobre o Wireless IE 3.0 da Microsoft...
    Furthermore, like the Logitech models, the cordless mouse does not convince me as being the best device available for playing FPS and other high-speed games such as Quake or Red Faction. I find the response time to be slower than with a conventional mouse.
    http://www6.tomshardware.com/consume...almice-09.html
    Ou seja, um review do mesmo site falando q um mouse sem fio especifico não eh bom pra jogos. Considerando q eh o "concorrente" do mx700, vale a pena prestar atenção...
    Mesmo site, Logitech Cordless Optical Mouse:
    Unfortunately, the radio link reaction time is not fast enough for this type of game. When you are moving very quickly and stop suddenly in order to aim, you may find that you are not that accurate. This only applies to Quake enthusiasts and Red Faction players. In the case of a slower FPS and other strategy games, it is absolutely no problem.
    http://www6.tomshardware.com/consume...almice-05.html
    Isso q eu citei 2 mouses de renome, imagina pegando um qualquer por ai...
    n0x
    n0x está offline
    Reviews do mx700:
    http://www.fragtopia.com/reviews/mx700/mx700-1.htm
    One of the other huge flaws in optical mice is the fact that they have an extremely annoying habit of losing their tracking from time to time. This generally only happens in games when you are moving the mouse too rapidly for the optical sensor to keep up with you. It's actually pretty funny to see from the other side. You can always tell when someone's mouse loses it's tracking, as their character in the game starts spinning in place like a top. Needless to say once your opponent finishes laughing, he generally kills you and moves on, leaving you cursing your optical mouse and the fate that just befell you. The OW was pretty good for this, it only happened occasionally during the most frantic action. In the week that I've been using the MX700 it's never occurred, and I've been trying my damnedest to get it to happen. No matter how frantically I wave the mouse around (and yes, I look like an idiot in game no doubt.) I just can't get the thing to screw up or lose it's tracking at all. Very nice.
    http://www.hardwarecentral.com/hardw...eviews/4488/1/
    Unless your name is Schilling or Clemens, you may have trouble moving your arm that fast, but you'll have no trouble with the MX700 skipping or freezing -- we couldn't cause a glitch even when whipping the Windows Paint pencil back and forth with all our might.
    Outro review, mas o cara não da detalhes especificos sobre jogos, mas diz q não buga
    http://www.gamershell.com/reviews/Lo...seReview.shtml
    Hempp, vc joga oq?
    hummmmmmmmmmmmmmmmmmmmmmmmmm
    ta me convencendo
    Tá certo amigo... desculpa aí hein...
    mas ae mech.. se vc comprar vc naum vai se arrepender naum.. a unica coisa eh q eh pesado msm mas deois q vc acostuma jah era
    Membro Avatar de Eagle Bill
    pow, eu tenho um intellimouse explorer wireless, e eh bom pra kct...
    eu não sinto delay nenhum dele e modestia a parte no CS eu acerto um bocado de headshots... se ele tem delay ou não, não me prejudica em nada e eu tenho reflexos muito rapidos....
    ah, a pilha dura um mes, cravadinho, pq eu uso dia e noite o pc
    =P
    Jan 2000
    a pilha do MX700 dura NO MÍNIMO 1 semana, ou seja, uso DIRETASSO do mouse e em 1 semana a pilha PODE acabar... veja q nenhum dado eh oficial, pq ninguem vai fica usando xx horas por dia certinho ate acabar a pilha neh ? aheiuheia
    tipo, o problema do mx700 eh o preço... mas eu axo q vale a pena, pq afinal, a taxa q o sensor a radio dele pega eh ACIMA (sim, ACIMA) do maximo por segundo q a propria porta USB pega.. entao em kestao de resoluçao ou algo assim nao terá problema algum... o unico possivel problema eh um delay de qdo o dado sai do mouse e vai pro receptor de radio... o q realmente, kerendo ou nao, GERA SIM um delay... felizmente, pelo q ouvi dizer, ja no IM Explorer Wireless (q jah tah BEM véio) ja era bom, com delay quase imperceptivel, no Logitech o delay eh coisa de 0,00001s haeiuheuieahia
    q tem, TEM, mas eh imperceptivel (afinal, ate um mouse com fio tem o delay dos dados percorrendo o fio nao tem!??! AHEUIEHIEHAEHAUIE)
    bom o mx700 eh meio caro, mas vem com carregador e pilha das boa... meu pai compro um jogo de carregador Rayovac, com 2 pilhas de NiMh (nickel metal-hidride, algo assim) de 1600mAh (notem q pilhas recarregaveis e outras normais tem cerca de 500~700mAh!!!), pagou 100 reais no jogo... se o mouse vem com carregador e esse tipo de pilha (q eh se nao me engano), realmente o preço dele TEM q ser alto...
    o peso provavelmente eh por causa das pilhas... portanto, akele "ferrinho" dentro do mouse ja deve ter sido tirado, mas nao adiantou mto... mas axo q isso nao eh um problema... acostuma...
