    Membro Avatar de *=-Tênis AR-=*
    Rly?!
    Placa mãe GA-7VAXP (AJUDA)
    Eu tava vendo por aí... essa placa pelas specs eh umas das melhores e com melhor custo / benefício. tou querendo comprar um combo e gostaria de saber o q vcs acham dessa placa, se é boa pra OC o preço e se tem opções melhores do que essa :-p
    Placa Mãe GA-7VAXP
    PROCESSOR
    Socket A for AMD Athlon™ XP / Athlon™ / Duron™ processor
    CHIPSET
    Northbridge : VIA KT400
    Southbridge : VIA 8235
    VIA 8X V-Link architecture (533MB/s)
    VIA VT6306 IEEE1394 controller
    Super I/O : ITE IT8705F
    Smart I/O : Winbond [email protected]
    Promise PDC20276 ATA 133 RAID controller
    Raeltek 8100BL Ethernet 10/100Mb LAN controller
    AC97 Realtek ALC650 6-channel sound Chip
    Dual BIOS
    MEMORY
    Type : DDR400(PC3200) / DDR333 (PC2700) / DDR266 (PC2100) / DDR200 (PC1600) -184pin
    Max capacity : Up to 3GB by 3 DIMM slots
    CONNECTOR
    1 x AGP universal slot (8X/4X/2X-AGP 2.0 compliant)
    5 x PCI slots (PCI 2.2 compliant)
    1 x FDD port
    4 x UDMA ATA133/100/66 Bus Master IDE ports
    3 x IEEE 1394 connectors
    2 x 2ports USB 2.0 connector (by front USB ports)
    1 x 2ports USB 2.0 connector (by cable with rear USB bracket)
    Memory Stick / Security Digital (MMC) / Smart Card Reader connectors
    2 x cooling fan pin header
    REAR PANEL
    PS/2 Keyboard / Mouse
    2 x USB 2.0 ports
    2 x COM ports
    1 x RJ45 LAN port
    Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
    1 x joystick
    CPU SETTING
    CPU FSB adjustable via BIOS (1MHz-linear)
    CPU multiplier by DIP Switch
    CPU Vcore Voltage adjustable via BIOS
    AGP Voltage : N/A
    Memory Voltage : N/A
    BUNDLE SOFTWARE
    @BIOS™, EasyTune™ 4, Q-Flash™, GMC™
    Symantec Norton AntiVirus (Internet Security 2002) OEM Ver.
    Symantec Norton Personal Firewall OEM Ver.
    H/W MONITORING
    System health status auto-detect and report by BIOS
    H/W detect and report power-in voltage, CPU voltage, and Fan Speed Support auto detect temperature thermal shutdown function.
    POWER
    ATX power connector
    Power-off by Windows 95/ 98/ Me/ 2000/ NT/ XP shut down and Switch
    BIOS
    2Mbit flash RAM
    AMI BIOS with enhanced ACPI feature for PC98/Win98/Win2000/WinMe/XP compliance, Green, PnP, DMI, INT13 (>8.4GB) and Anti-Virus functions
    IDE#1~#4, SCSI, LS120, ZIP and CD-ROM bootable
    AC recovery ON/OFF control
    FORM FACTOR
    ATX, Dimension : ( 23.5 x 30.4 cm )
    OTHER FEATURES
    GIGABYTE patented DualBIOS™
    Suspend-To-RAM (STR)
    Supports USB KB/MS Wake up from S3
    Poly fuse for keyboard over-current protection
    DRIVER
    VIA 4 in 1 service pack utility
    Promise RAID controller driver ( includes pure ATA133 driver )
    Realtek LAN driver
    Realtek sound driver
    VIA USB 2.0 driver
    Winbond Smart IO driver
    Free software
    Preço: Entre R$ 600 e 650
    E então?
    Se tem uma melhor CUSTO-BENEFÍCIO não sei (mesmo pq nem sei o preço dessa placa) mas tem uma melhor sim
    ASUS A7N8X
    Rly?!
    Re: Placa mãe GA-7VAXP (AJUDA)
    Originalmente enviada por *=-Tênis AR-=*
