    Carmack On Nv30-finalmente alguem q entende:)
    Tae, esse entende do q ta falando, inclusive o obvio:
    nao compre Vga's agora
    I am using an NV30 in my primary work system now, largely so I can test more of the rendering paths on one system, and because I feel Nvidia still has somewhat better driver quality (ATI continues to improve, though). For a typical consumer, I don't think the decision is at all clear cut at the moment.
    For developers doing forward looking work, there is a different tradeoff -- the NV30 runs fragment programs much slower, but it has a huge maximum instruction count. I have bumped into program limits on the R300 already.
    As always, better cards are coming soon.
    http://www.shacknews.com/onearticle.x/24751
    link direto pro .plan dele:
    http://www.shacknews.com/finger/?fid...idsoftware.com
    ah esse kra fala demais
    se acha pra caramba, e doom3 mesmo que eh bom nada
    desde a epoca das r8500/gf3 ainda tava essa mesma lenga lenga
    Membro Avatar de Guniz
    aff
    se ele fala demais
    tu fala nada com nada
    O mais forte do universo!
    JA SAKEI QUAL É A DESSE CARMACK
    ja entendi pq ele inrrola tanto com o DOOM 3..... ja imaginaram o tanto de "EXTRA" q ele recebe pra babar o ovo das marcas de VGA???
    a very long time ago, ele chegou a dizer e botar a mao no fogo por isso:
    "A Radeon 8500 é a melhor escolha rpa jogar Doom3, melhor do que a GF4, pq a Radeon possui recursos mais a propriados e bla bla bla"
    uau!!! bela bolada da ATI ele recebeu ne???
    agora é O CONTRARIO!!!!!
    "I am using an NV30 in my primary work system now, largely so I can test more of the rendering paths on one system, and because I feel Nvidia still has somewhat better driver quality (ATI continues to improve, though)."
    nossa a nVidia deve ter enchido o ** dele de dinheiro.....
    parece q esse DOOM 3 ainda vai demorar MUUUUITO pra sair.... la pra GeForce FX3 / Radeon 12.700 ele deve sair
    Re: JA SAKEI QUAL É A DESSE CARMACK
    "The current NV30 cards do have some other disadvantages: They take up two
    slots, and when the cooling fan fires up they are VERY LOUD. I'm not usually
    one to care about fan noise, but the NV30 does annoy me."
    nao custa nada ler o texto do cara antes de falar...
    Ps. Pra kem nao ta com saco de ler o tijolo do carmack, basicamente o cara falou:
    As 2 placas (r300/nv30) sao mais ou menos a mesma merda, a Fx ainda melhora muito, mas sao 2 placas "dead generation" nao devem servir pra porra nenhuma pois quando rolar progs pra elas ja vai estar rolando coisa melhor.
    A mensagem mais "clara" eh:
    nao compre Vga's agora ou :"As always, better cards are coming soon." em carmakianes..
    Diesel.....amigaum.....
    valeu pelo link...
    legal mesmo as explicações....
    o interessante é q se a gf fx nao serve para os jogos futuros entao ela nao serve pra nada, pq pros jogos presentes as placas da ati valem mto mais apena
    n0x
    n0x está offline
    Cold shower. It helps.
    Re: Re: JA SAKEI QUAL É A DESSE CARMACK
    Originalmente enviada por DecoTheDiesel
    Não compra VGAs top neh...
    Membro Avatar de SparkS
    Se for pra esperar chegar uma placa melhor vc vai acabar esperando pra sempre
    Membro Avatar de NoOne
    Bom, como disseram, então ela não serve pra coisa nenhuma
    Mas olha só.. como pucham o saco desse carmack..
    Não confio nada nesses fabricantes de software, todos pucham para um lado porque sempre tem dinheiro por tras.
    Bom, agora pensem comigo.. se a NV30/R300 nao existissem.. não existiria evolução concordam? Então elas não são placas lixos.. e sim são placa que possuem a chave para abrir novas fronteiras.
    Pensem bem, com a utilização das rotinas DX9+OGL2.0.. etc.. mesmo rodando de forma ruim.. teremos a capacidade de pelo menos aprender com os erros.
    Eu concordo que fiquei decepcionado com a GFFX, mas falar que ela é melhor que uma R9700 no final das contas é comédia. Porque? Simplesmente porque ela não conseguiu reunir em uma placa.. inovação com itens basicos. Garanto que 50% dos que pretendiam comprar essa placa ja desistiram.. porque? porque na minha opinião.. uma placa muuuito barulhenta.. com preço tremendamente grande.. e ocupando 2 slots.. é comédia neh.. sem falar que tudo isso para ganhar em média 10% de performace (e olha la porque em jogos atuais ela perde em muitos).
    Do outro lado.. se tu pegar uma GFFX e overclocka e pegar uma R9700 e overclockar.. tu pode praticamente imparelhar as placas..
    e tem gente que ainda pensa que o Carmack é de confiança...
    é o cara que mais fala merda na face da terra, nao tem a minima credibilidade pra mim oq ele fala... Na minha classificação ele está na mesma lista do Para efeito de direitos autorais o nome que você digitou esta sendo substituído por este texto, pra vc ver o tanto que eu ligo pro que ele fala...
    tipo, eu ia esperar pela GF FX pra ver qual placa eu vo comprar... Acho que já me decidi. Vô optar por uma 9500 e fazer akeles trambique pra virar 9700
    E tu Deco ? Vai comprar uma FX ??? Vai resistir ????????
    O tabacooler pode ter sido um golpe do destino
    Bom, primeiro, dizer q o carmack nao eh de confianca eh sacanagem ate pq ele eh um dos unicos caras na industria q tem coragem pra dizer exatamente o q pensa...
    quando a Nvidia lancou a G4Mx ele foi o primeiro a vir a publico dizer q a placa era uma merda.
    quando a Ati tava no auge do driver porco ele tbm meteu o pau
    agora ta ae falando mal da Fx...
    Quem acompanha o .plan do cara sabe q ele eh totalmante imparcial alem de ser "o cara" mais interado sobre tecnologia de placas de video e drivers da atualidade e o resto do mercado inteiro vai pelo q ele fala.
    Ja eu vo continuar feliz e contente com a minha G4 e aconselho a kem tem de g3/8500 pra cima a ficar relax pois ninguem precisa mais do q isso pra rodar nada hj em dia.
    Como o proprio JC falou, ta vindo mais novidade por ae, minha opniao eh a seguinte:
    kem comprou qqr placa de video acima de ti4200/radeon8500 fez mal negocio pq:
    4600 eh demais , eh desnecessaria, nao precisa de tudo isso pra rodar nada hj em dia..nao suporta novas tecnologias, mas tbm as novas tecnologias ainda nao existem e eh cara...
    4400 idem
    9500- saiu tarde demais, com tecnologia de dx9 e tra la la q nao tem uso, e eh cara..
    9700- cara, desnecessaria, vai ser engolida pela serie r350..
    Fx- mais cara ainda, mais desnecessaria ainda, ta sendo classificada como Dead On Arrival...
    enfim, todas essas placas da lista vao alem do q se precisa pra rodar bem os jogos da atualidade.
    As mais recentes da lista serao atropeladas pelas novas series , ate a S3 ta kerendo entrar nessa briga entao eh besteira gastar los tubetes em qqr placa dessas.
    o lance eh esperar , ate pq as ferias de verao la fora tao pra chegar e eh claro q vao aparecer vaaaarias novidades ate la..
    eu sei eh q enquanto a Fx nao aparecer com uns drivers definitivos e nao arrancarem uns 30db dakele cooler ridiculo ela nao entra aki em casa...
    Mesmo q a Fx tivesse uma mega hiper performance e suportasse directx 20 e opengl5 q q alguem vai fazer com ela?? jogar Ut??? fazer 3dMark??
    o foda eh isso..nao tem programa pra rodar nem nas Ati nem nas Nvidia....portanto....
    G4ti4200 na minha opniao eh a the best right now, com otimo custo beneficio e com toda a tecnologia necessaria pra rodar o q existe no momento.
    ainda bem q eu nao vendi minha g4
    Ps.tenho quase certeza q a Nv30 ainda deve mudar muito, principalmente no soft/drivers mas tbm fisicamente.
    G4ti4200 na minha opniao eh a the best right now, com otimo custo beneficio e com toda a tecnologia necessaria pra rodar o q existe no momento.[]'s
    100+... pena q a minha queimo o circuito... shitz... ae, deco, ta semm icq?
    Concordo com o que tu falou deco..
    mas so tenho algo a acrecentar..
    O Carmack pode muito bem falar mal/bem de tudo.. mas sempre tem um empurrãozinho por tras Nvidia ou ATI.
    Sobre o melhor custo benefício eu ficaria com a 9500.. porque é a UNICA que segura AA+AF sem muita perda e isso com um preço compativel com a placa.
    So acho que ela podia ser uns 100R$ mais barto.. em torno de 600.. seria a melhor placa custo/beneficio
    com certeza a melhor opção agora, eh a R9500Pro... quando ela abaixar um pouco de preço eh a que vou pegar!
    Originalmente enviada por EXTREMiST
    aff
    se ele fala demais
    'aff' pra vc kra... te perguntei algo?
    deco, quem tem uma radeon 9700 pode ser uma pessoa q goste de jogar com anti aliasing e filtro anisotropico ligado, coisa q uma gf4 nao consegue fazer
    entao eu axo tudo uma questao de dinheiro
    quem pode compra, quem nao pode fica com a gf3 q nem eu
    Membro Avatar de Elrond
    Carmack eh um idiota...
    Ele falando e uma vaca cagando dah no msm p/ mim...
    Lembra quando a Nvidia lanço a primeira GF? Lembra do T&L? Quando tempo levaram pra implementar esse merda nos jogos, o mesmo se aplica hj.
    Tipo e quem tem GF, Radeon 7500, GF2 faz o que espera mais um pouco D
    não é querendo tirar ninguem não.....
    mas é pq o pessoal parece ter lido só a primeira frase onde fala que o NV30 esta geralmente melhor no doom III e o R300 na frente em algumas situações.......
    acho que se alguem ler tudo e conseguir entender vai ver que ele ta falando mal do NV30 em várias ocasiões.......e elojiando MUITO o R300.........
    pra manter o NV30 rodando rapido ele ta tendo que ficar alternando a renderização em 16bit, 24bit e 32bit FP.....
    o R300 esta rodando em 24bit constante ARB2....com a performance boa....
    se o NV30 usar 32bit fica com metade da velocidade do R300......então ele tem q usar as chamadas especificas da nvidia e ficar variando com 16bit.....
    como fica claro nesse .plan o R300 ta renderizando com melhor qualidade de imagem.....infelizmente essa diferença não é perceptivel por um ser humano.....
    melhor ainda foi os comentários do R200 renderizando tudo em 1 ciclo...ps PS 1.4 vão fazer diferença contra as placas GF4 e GF3 que usam PS 1.0 ou 1.3
    pra mim o que ele falar vale pq os jogos da ID arrebentam em grafico e diversão , são os melhores , eu não acho que ele seja totalmente imparcial , deve ter uma mãozinha da nvidia por tras
