    MOB MSI 648 MAX L Presta?
    Gostaria de saber se presa a placa..
    li altos reviews e so falaram bem e tals
    mas nao custa perguntar...
    CPU
    Supports Intel® Pentium® 4 processor in the 478 pin package.
    Supports FSB at 400/533 MHz (100/133 MHz QDR)
    Core frequency from 1.3 GHz to 2.8 GHz and up
    Chipset
    SiS® 648 (839 pin BGA)
    - Supports Intel Pentium 4 processors with data transfer rate
    up to 533 MHz
    - Supports 64-bit high performance DDR 333+ / DDR 333 /
    DDR 266 memory controller
    - Supports AGP 8X/4X interface at 0.8v or 4x at 1.5v with fast
    write transaction
    - Supports bi-directional 16-bit data bus with 1GHz bandwidth
    MuTIOL
    SiS® 963 (371 pin BGA)
    - Supports Dual-IDE ATA 66/100/133
    - Integrated audio controller with AC'97 interface
    - Low pin count interface for SIO
    - Advanced power management and PC2001 compliance
    FSB
    FSB @ 400/533 MHz (100/133 MHz QDR)
    Main Memory
    • Supports three memory banks using two 184-pin
    unbuffered DDR DIMM.
    • Supports up to 3GB memory size without EEC.
    • Supports DDR200/266/333/400 MHz and up.
    MSI Certified Memory Modules
    (648 Max PC3200 DDR 400 SDRAM)
    Slots
    • One 8x/4x AGP universal slot.
    • Six PCI v2.2 32-bit master PCI bus slots.
    On-Board IDE
    • Dual IDE controllers integrated in SiS® 963.
    • Support P/O, Bus Master, Ultra DMA66/100/133 operation.
    • Can connect up to four IDE devices.
    Audio
    • AC97 link controller integrated in SiS® 963.
    • 6 channels software audio codec RealTek ALC650.
    - Compliance with AC'97 v2.2 Spec.
    - Meet PC2001 audio performance requirement.
    - Can support SPDIF Out via S-Bracket only.
    Network (Optional)
    • Broadcom 4401
    - Integrated 10/100 Ethernet MAC and PHY in one chip.
    - Supports 10Mb/s and 100Mb/s auto-negotiation operation.
    - Compliance with PCI v2.2, mini PCI 1.0 and LAN on
    Motherboard (LOM) standard.
    • Broadcom 5702
    - Integrated Gigabit Ethernet MAC and PHY transceiver, auto-
    - Supports single-port 10MB/s, 100MB/s and 1000MB/s BAST-T
    application.
    On-Board Peripherals
    On-Board Peripherals include:
    - 1 floppy port supports 2 FDDs with 360K, 720K, 1.2M, 1.44M
    and 2.88Mbytes.
    - 2 serial ports (COM A + COM B).
    - 1 parallel port supports SPP/EPP/ECP mode.
    - 6 USB ports (Rear * 4/ Front * 2).
    - 1 IrDA connector for SIR.
    - 1 RJ-45 LAN jack (optional).
    - 1 audio port.
    - 1 Bluetooth pin header
    - 1 S-Bracket™ pin header.
    - 1 D-Bracket™ 2 pin header.
    BIOS
    • 2MB AMI BIOS w/ PnP, ACPI, SMBIOS 2.3, Green and Boot
    Block
    • Provides DMI2.0, WfM2.0, WOR and SMBus for system
    tem mais coisa mas ate ai ta bom...
    Valeu!
    n0x
    n0x está offline
    Cold shower. It helps.
    Presta mas não é boa pra o/c, como qquer MSI
    então tirando esse detalhe vale a pena?
    n0x
    n0x está offline
    Sisi
