    Series (codinomes) dos T-breds (HELP)
    Olá pessoal,
    como estou pra comprar meu processador que será T-bred, gostaria de saber mais sobre suas series. Sei que tem uns que sao AIRCA, etc..
    Gostaria de saber quais as "series" que existem e se há diferenca entre as mesmas.
    Luk
    nao eh boa =)
    Asy
    Asy está offline
    Membro Avatar de Asy
    NinaAgdal>All
    Duron Spitfire Stepping/Revision Codes (in order of highest average overclock to lowest):
    code:
    600-800 AKBA (10) AKCA (9) AKAA (8)
    800-950 ANDA (10) AMCA/ANCA (9) ALCA (8) AKCA (7)
    Duron Morgan Stepping/Revision Codes (in order of highest average overclock to lowest):
    code:
    ALL Speeds AHLDA (10) AHLCA (9) AHHAA (8)
    Version Codes Y (10) Z (9) 9 (8)
    Athlon Thunderbird Stepping/Revision Codes (in order of highest average overclock to lowest):
    code:
    ALL Speeds AYHJAR (10) AYHJA/EYHJA (9) AVHA/BVHA (8) AXIA/BXIA/AVIA/AXIAR (7) AJFA/ARGA (6) ADFA (5) AQGA/AGGA/ASHHA (4) AXHA/ALUM (3)
    Version Codes Y (10) K (9) 9 (8)
    AMD Athlon XP Stepping/Revision Codes (in order of highest average overclock to lowest):
    code:
    XP1500+ AGKGA (10) AGOGA (8) AGKFA (7) AGNGA (6)
    XP1600+ AGOIA (10) AROIA (9) AGKGA (8) AGOGA (7) ARKGA (6) AGNGA (5) AGLHA (4) AROGA (3) ARNGA (2)
    XP1700+ AGOIA (10) AROIA (9) AGKGA (8) AGOGA (7) ANGKA (6) ARKGA (5) AGNGA (4) ARNGA (3)
    XP1800+ AGOIA (10) AROIA (9) AGKGA (8) AGOGA (7) AKYGA (6) AGLHA (5) ARKGA (4) AGNGA (3)
    XP1900+ AGNGA (10) AROIA (9) AGKGA (8) AGOGA (7) AGLHA (6) AGOIA (5) AGKGA (4)
    XP2000+ AGOIA (10) AROIA (9) AGOGA (8) AGNGA (7)
    XP2100+ AGOIA (10) AGOGA (9)
    Version Codes Y (10) F (9) K (8) 4 (7) 9 (6)
    AMD T Bred A & B Stepping/Revision Codes (in order of highest average overclock to lowest):
    code:
    T Bred A's AJUGA (10) AIUGA (9) RIWGA (8) RIRGA (7) AIRGA (6) AIRDA (5) AIRCA (4)
    T Bred B's JIUHB (10) JIUGB (9) JIUCB (8) AIUHB (7) AIUGB (6) AIUCB (5) AIUAB (4)
    T-BRED AMD ATHLON XP FAQ
    XP1700+ tbred 'A' core 1.50v default 1466mhz/266mhz bus
    XP1700+ tbred 'B' core 1.60v default 1466mhz/266mhz bus
    XP1800+ tbred 'A' core 1.50v default 1533mhz/266mhz bus
    XP1800+ tbred 'B' core 1.60v default 1533mhz/266mhz bus (yet to be seen in the wild)
    XP1900+ tbred 'A' core 1.50v default 1600mhz/266mhz bus (yet to be seen in the wild)
    XP2000+ tbred 'A' core 1.60v default 1666mhz/266mhz bus (yet to be seen in the wild)
    XP2000+ tbred 'A' core 1.65v default 1666mhz/266mhz bus (yet to be seen in the wild)
    XP2000+ tbred 'B' core 1.60v default 1666mhz/266mhz bus (yet to be seen in the wild)
    XP2100+ tbred 'A' core 1.60v default 1733mhz/266mhz bus (yet to be seen in the wild)
    XP2100+ tbred 'B' core 1.60v default 1733mhz/266mhz bus
    XP2200+ tbred 'A' core 1.65v default 1800mhz/266mhz bus
    XP2200+ tbred 'B' core 1.60v default 1800mhz/266mhz bus (yet to be seen in the wild)
    XP2400+ tbred 'B' core 1.65v default 2000mhz/266mhz bus
    XP2600+ tbred 'B' core 1.65v default 2133mhz/266mhz bus
    XP2600+ tbred 'B' core 1.65v default 2083mhz/333mhz bus*
    XP2700+ tbred 'B' core 1.65v default 2166mhz/333mhz bus
    XP2800+ tbred 'B' core 1.65v default 2250mhz/333mhz bus
    1700+ 1800+ 1900+ e 2000+ são destravados de fabrica, e vc pode usar os multiplicadores de 5 a 12.5 x
    Os 2100+ pra cima, pra destravar é facil, apenas ligando uma ponte L3!
    Aqui tem um guia legal tbm!
    http://www.overclockers.com/tips00173/
    Valeu pela ajuda ! muito esclarecedora !
    To pegando um
    AMD XP 2100 T-Bred B HIGH END = AIUCB
    Abraços,
    Luk
    Membro Avatar de Thomazini
    Originalmente enviada por DrLuk
    To pegando um
    Abraços,
    Luk
    onde vc achou esse tbred cara?
    tem um amigo meu simplesmente desesperado correndo atras de um tbred B 2100+
    vlw
    Originalmente enviada por Thomazini
    vlw
    Achei com o Skoll mas era o ultimo dele pra pronta entrega..
    mas vc pode encomendar com ele
    Hugz
    Luk
    Hugz
    Luk
    Vou dar um toke no meu camarada. Nem sabia q o Skoll tinha
    vlw hehe
    Pensei que os tbred fossem todos bus 333, mas parece que nem é não! Nem existe tbred 2100 bus 333, né?
    Membro Avatar de *Slicer*
    Feb 2000
    eh soh vc olhar a lista:
    XP2600+ tbred 'B' pra cima que são 333 fsb
    fsn
    fsn está offline
    vo pega um xp1700+ Jiuhb
    To pegando um
    Abraços,
    Luk
    Pq High End se ali tá falando que o JIUHB é melhor pra overclock?
    Pq segundo um excelente tutorial que li, que agora nao me recordo.. todos os steps de Tbreds que comecam com A sao high end e os q comecao com J sao low end.
    Hugz
    Luk
    qual eh a diferença de high end pra low end? tem a ver com o custo de producao ou coisa assim? pelo q eu to vendo o JIUHB nao seria o melhor pra overclock?
    putz faz tempo q eu nem entro em site pra ver hardware to ficando atrasado pqp..
    Originalmente enviada por Chupa-Kabra
    HIGH END eh melhor pra overclock..
    intao pq os low end tao na frente se eh ordem de melhor pra pior??
    Nov 1999
    O Meu é bom pra OC mas não tão bom
    Você sabe ler!??!, Entao leia atentamente o post do brusamarello la em cima.
    HIGH END não eh melhor pra overclock, sao os piores, porisso sao HIGH END. Os melhores sao os LOW END, vo destacar o trecho aki pra vc.
    Originalmente enviada por brusamarello
    code:
    Originalmente enviada por Snaiper
    auehauehaue bem q eu tava estranhando!
