    Membro Avatar de hadock
    DiamondMax Plus 9 - garantia pequenininha...
    Isso foi retirado da TomhsHardware nas notícias que vem por e-mail. O que vc's acham dessa garatia de somente um ano para o DiamondMax Plus 9 da Maxtor? Depois do número de "mortes" de HD's Maxtor que eu vi no fórum e dessa garantia de só 1 ano eu passei a ver os HD's Maxtor com um pé atrás em termos de durabilidade e confiança.
    Summary: Extremely High Performance, Excessively Short Warranty Period
    The DiamondMax Plus 9 leaves the rest of the field behind in two of the benchmark disciplines in particular, namely application performance and the minimal data transfer rate when reading and writing. In practical terms, this makes it ideally suited for all types of sequential data retrieval/ storage, such as video editing, due to the high minimal transfer rates. It also means that you can work on your computer with no delays resulting from today's high application performance (WinBench 99 2.0).
    Reaching well over 100 MB/s, even the burst transfer rate attains a new all-time best for individual hard drives. Until now, achieving such a maximum bandwidth required at least two hard drives in one RAID system.
    The DiamondMax Plus 9 also achieves a rating in the top third with regard to CPU load and access time measurement.
    This good set of results is marred, however, by the excessively short warranty period of just one year (even though two-year warranty periods have been obligatory in the EU since 2002). Ultimately, someone has to vouch for this warranty, and in many cases, this is the dealer.
    Particularly with a product for which reliability and/ or data security count more than anything else, short warranty periods do not necessarily inspire confidence.
    Asy
    Asy está offline
    Membro Avatar de Asy
    NinaAgdal>All
    pois é
    um morreu aqui!
    NEO
    NEO está offline
    Membro Avatar de NEO
    Dec 2000
    Poizeh... por isso q eu prefiro WD
    Jun 2000
    um plus 8 de 30 gb morreu aqui
    Membro Avatar de NoOne
    O DiamondMax9 que eu to usando ta firme e forte,.. pelo menos até agora e espero que por um otimo tempo!
    NoOne
    Jun 2000
    ah eu esqueci de falar
    tenho mais 2 plus 9 de 60 gb e 2 dx740 de 60 gb q nunca deram pau
    Se nao me engano a maioria dos fabricantes de HDs estao dando so 1 ano de garantia.
    garantia pra nos aqui é foda
    tem que ta pagando importacao.. coisa tosca demais
    Meu D740X completa 8000h de uso nos próximos dias.
    Membro Avatar de Hyu Park
    Pastel de flango?
    HD de 7200 rpm tem 1.5x mais probrabilidade de dar pau comparado aos de 5400... maior velocidade = maior desgaste do HD... e HD eh a unica parte fisica que gasta com o tempo (tirando cooler, disquete e drive de CD)
    Membro Avatar de BIGX333
    Originalmente enviada por NEO
    Yen
    Yen está offline
    o meu Diamond 9 ta morrendo, tem q trocar (garantia rox)....é foda...
    QUal a diferneça entre um 7200 e um de 5400 rpm no quesito perfonamenc eou o que tem de diferença?
    Yen
    Yen está offline
    Originalmente enviada por Ponce
    mta performance...
    vc transfere arquivos entre hds mto rapido, além do q da load nos jogos rapido tb (se proc. e ram ajudarem claro)
    porra, eu to desesperado pra trocar meu hd de 20gb, pq depois que assinei adsl o max que eu consigo ter no meu hd de espaço é 3gb, pra instalar jogo tem que fazer roleta hehe.
    Mais do jeito que nego ta falando mal dos últimos hds de 7200RPM, da até calafrio,
    ainda mais essas garantias de 3meses no brasil...
    acho que vo continuar comprando tubo de 100cds/mes mermo :P
    Tem um diamond 8 aqui e ta firme e forte
    Con
    Con está offline
    tenho um d740x da a1 aki
    se zuar to [email protected]@#[email protected]# ?D
    NoOne
    Originalmente enviada por Sargador
    WD eh Lifetime se não me engano
    Pastel de flango?
    Na boa... se tratando de HD, rpm nao eh tudo...
    no caso do LCT 20 da Quantum... os 5400 rpm eram bem interessantes na epoca do lancamento... mas o problema foi percebido depois... pq HDs Scsi tinham 4800 rpm (menos rpm que um HD comum) mas tinha 2 megas de buffer enquanto o HD IDE da Quantum soh tinha 128k... ta ai a diferenca...
    Originalmente enviada por Connelk
    VC ainda tá bem na fita, o máximo que acontece é vc esperar 1 mês pelo RMA.
    Pior é o meu D740X de 60Gb adquirido na extinta TeclaDigital.
    Valew ae
    Valew ae
    O meu também foi com eles. Qualquer coisa compro um novo, envio esse para a Maxtor, e chegando vendo como novo.
    Originalmente enviada por Hyu Park
    Esse lct 20 pelo que eu saiba tem 4400rpm ou 4800 alguma coisa assim. Eu tenho um lct15 e ele é 4400rpm eu tenho quase certeza.
    Membro Avatar de OnYourTail
    Originalmente enviada por hadock
    LCT20 tem 4500 rpm , eu tive um... Extremamente lerdo pra tudo. Buffer de 128k é ridículo.
    Agora to com esse WD 400BB (7200 rpm , igual aos JB , mas com cache de 2 mb) e é um avião.
    Pastel de flango?
    eita... LCT20 nao tem 5400 rpm nao?
    vendedor disgramado... vo pega ele e da uma HDezada na cabeca...
    eh o Plus que tem 5400 rpm entao? ou eh 7200?
