    Membro Avatar de Gung@
    Gunga
    Catalyst 3.2
    Vamos lá cambada, peguem antes q a ATI lance o 3.3
    http://www.ati.com/support/drivers/winxp/radeon-ml.html
    Re: Catalyst 3.2
    Oloko! Nem pegay o 3.1 ainda, quais as vantagens?
    Gunga
    Before you start, please read these installation tips.
    Fixed in this driver:
    Display Driver
    Playing a video using the RealOne Player no longer results in display corruption and an error message being displayed by the RealOne Player
    Running the game Combat Flight Simulator 3 with 4x Anti-Aliasing enable no longer results in texture corruption being displayed.
    Running the demo ATI-9700-NPRHatching with Anti-Aliasing enabled at 2x and the display set to 1024x768 32bpp no longer results in corruption being displayed on screen
    Selecting D3D 8.1 renderer in Nascar 2003 followed by selecting Replay Studio in the main menu no longer results in the car having missing textures.
    Setting the display to 1024x768 32bpp followed by changing the AGP speed from 8x to 4x no longer results in the AGP speed not retaining its setting
    Setting the Hardware Acceleration slider to None no longer results in a reboot of the system and the settings not being retained
    A reboot is no longer required when making changes to the Wait for Vertical Sync under the ATI Direct3D Tab
    Running the game Myth 3 with the display set to 1600x1200 and Full Screen Anti-Aliasing set to 2x no longer results in corruption being displayed when entering the Save game screen window
    Running the application There no longer results in segmentation violation occurring when Pbuffer is enabled in the application
    Selecting a Daytona single race in the game Nascar 2003 beta with OpenGL enabled no longer results in the system not responding.
    Running the OpenGl test found in Nascar 2003 Beta no longer results in the system not responding.
    Running the 3D Winbench 2000 v1.1 Quality test for Anisotropic and Linear Mipmap Anisotropic no longer reports the tests as Not Capable.
    The Windows 2000 display driver no longer requires two reboots of the system to load
    Connecting a TV and enabling the TV as a secondary CRT with the display set to 1024x768 16bpp no longer results in the DVD overlay not being displayed on either the CRT or the LCD
    The 3D Pipes (OpenGL) screen saver no longer renders incorrectly in preview mode when the display is set to 16bpp and FSAA is enabled
    Setting the display to 1024x768 32bpp and setting the TRUFORM option to Application Preference in the ATI OpenGL tab no longer results in the game Myth III not responding
    Switching between OTM Theatre Mode Settings in Clone Mode Options no longer results in the apply button not becoming active
    Setting the display to 1024x768 32bpp and enabling Anti-aliasing to 4x and running the game Harry Potter II no longer results in the system not responding
    Hmmm nao aumenta performance nao...
    Vo ficar com o 3.0 ainda, qndo eu formatar eu boto o 3.2 logo ou o 3.3 se sair até la
    Dec 2000
    Beleza hein! Chegar em casa eu vou pegar pra testar...
    Vc quer mais performance? Pqp! hehe
    No 3.1 tem uns erro doido com o TV-OUT, vou pegar este pra ver se conserta!
    Originalmente enviada por Mastermind
    Qnto mais melhor, quero ver ATi Rage batendo GeForceFX
    Membro Avatar de Elrond
    Eh nois!
    uaeaeuhuhuheuahe vai c foda
    Testei aki na R8500. Pela primeira x eu tive perda de performance.
    Eh, chego num ponto que jah tiraram tudo que dava dela pelo jeito, agora eh soh melhoria da R9700 em diante.
    Cat 3.1 por enquanto continua sendo o melhor p/ as R8500.
    Membro Avatar de edsonmassao
    +15 anos de hardMOB
    ops, ainda bem q vc postou sua experiência aqui...tava quase indo baixar...
    Membro Avatar de NoOne
    Originalmente enviada por edsonmassao
    Experimenta voce tambem!
    CATALYST maker writes Yup, they are out everyone, go grab em. First place I have announced it is here at Driver Heaven
    Zardon will be providing them on the DH mirror as well. Make sure you read the release notes for what is new in these drivers.
    Off to work on version 3.3 no2
    If you have a Mirror? post your link in the comments section and I will added them to the post.
    Performance Improvements
    As with most CATALYST™ releases, the performance has increased in many various situations. Here are some examples observed in CATALYST™ version 3.2.
    CATALYST™ 3.2 corrects a problem with 2D applications running in the background that can cause a momentary reduction in framerate (i.e."stuttering") in fullscreen Direct3D and OpenGL games. Specific instances of "stuttering" have also been addressed (e.g. Rallisport Challenge when the sun enters or exits the scene).
    Dungeon Siege framerates are improved as much as 24% across multiple products, especially when running at higher resolutions.
    Framebuffer read-back performance has improved dramatically (500% or more) in CATALYST™3.2. This feature allows an application to retrieve a fully rendered frame from the graphics adapter and manipulate it or store it in the system RAM or on the hard disk.
    Vertex Shader performance has improved dramatically (as much as 100% in some situations) for our DX8.1-class products such as RADEON™ 8500, 9000 and 9100. This brings significant gains to Vertex Shader intensive scenes such as the Battle of Proxycon and the Troll's Lair (both up 15-25% on RADEON™ 9000 PRO).
    "chego os 42.xx pras gf4" na versao radeon :/
