    SDRAM= PC 133, DDR = PC 266;300, Rambus =???
    alguem sabe????
    pc800 = 400
    pc1066 = 533
    ah?
    Originalmente enviada por Holocaustous
    ah?
    ah o q?
    o cara ja t e falou
    mas irei explicar melhor
    SDR:
    PC66 = 66mhz
    PC100 = 100mhz
    PC133 = 133mhz
    DDR:
    PC1600 = 200mhz (2x 100mhz)
    PC2100 = 266mhz (2x 133mhz)
    PC2400 = 300mhz (2x 150mhz)
    PC2700 = 333mhz (2x 166mhz)
    PC3200 = 400mhz (2x 200mhz)
    PC3500 = 433mhz (2x 216mhz)
    PC3700 = 466mhz (2x 233mhz)
    Rambus:
    PC800 = 400mhz (4x 100mhz)
    PC1066 = 533mhz (4x 133mhz)
    Bom acho que é isso.
    Se esqueci ou errei algo me avisem.
    Rambus:
    tah errado.
    rambus trabalha em pares..
    e nao em 2 pares..
    pc800 = 400mhz (2x200)
    pc1066 = 533mhz (2x266)
    vale mais a pena comprar 256 rambus ou 2 pentes de 256 ddr pc 2100??
    otra coisa bem mongol, mas nunca se sabe
    rambus eh compativel com athlon xp?
    Membro Avatar de Seu Madruga
    1- second option
    2- i dont think so
    Originalmente enviada por gancho
    tah errado.
    e nao em 2 pares..
    Editado: essa informaçao nao esta completamente correta, o motivo da memoria ser chamada de PC800 ou PC1066 nao esta relacionado com o dual channel e sim pq a Rambus tb é DDR(Double Data Rate) 2 x 400MHz = 800MHz.
    "The most popular form of RDRAM that we are familiar with now is what is known as PC800 RDRAM. This naming system is unfortunately a bit misleading, because the maximum operating frequency of the current RDRAM is 400MHz but, as we mentioned earlier, operates in a double pumped fashion, meaning that twice as much data is transferred every clock cycle (à la DDR), which is where the PC800 name comes from (400MHz x 2 = 800MHz). And since the Rambus channel is 2-bytes wide, we get an effective 1.6GB/s transfer rate for a single RDRAM channel."
    tah errado.
    e nao em 2 pares..
    acho que em 4x100 e 4x133 mesmo hein
    e faltou HSDR PC150
    RamBUM = Intel only
