    MHz
    MHz está offline
    Nova versão do MBM 5.0.3
    to postando isso aki e no PROGRAMAS pq acho q eh de interesse de todos
    Mother Board Monitor 5.0.3
    Added:
    - Plugins support (see /plugin/readme)
    - Intel ICH5 support
    - W83L785TS-S support
    - W83L785TR support
    - W83L785R support
    - W83627HF/ADM1027 Combo support as used on Tyan s2665UANF
    - ADM1030/ADM1025 Combo support as used on the Intel D850GB
    - AMD1030 dual support re-coded
    - Several Voltages added, thank you to all the users sending them in
    - $PCNAME will be replace with your PC's name in email subject line
    - Installer will by default enabled E and E scanning if you do a new install, but you can say no if you don't want to
    Changes:
    - higher compensation possible
    - reset of the high/low list should now work better with 3rd party tools that push values into the sharedmemory (all values are set to current and the counter to 1 for "custom" sensors)
    - you can now show up to 16 voltages, see the help file for more info
    fixes:
    - typo in the ITE/SIS -12 voltage
    - crash with GL520SM sensor chip
    - LM85 fan error
    - GL5xxxSM voltage wrong
    - in the misc directory is a batch file named "uninstall problems.bat" which should help out those users who have issues where unwise.exe does not find INSTALL.LOG (I sure hope this finally fixes it)
    DOWNLOAD: http://mbm.livewiredev.com/download.html
    Boa...
    Esse corrige o -12.00 na K7S5A, A7S333. Aparecia errado há mais de 6 meses.
