    ABIT: **** NF7-S 2.0 **** AMD XP 400MHz FSB ****
    Boas notícias da ABIT, tirado do Xbitlabs:
    "ABIT Computer notified its customers over its forums here that its NF7-S mainboard revision 2.0 which went from the fab just days ago supports 400MHz EV-7 FSB for the new AMD Athlon XP processors reportedly due next month.
    NF7-S mainboard was announced quite long ago, so, I will remind you its technical specifications:
    Supports Socket A Athlon XP processors with 200/266/333/400MHz FSB;
    NVIDIA nForce2 SPP chipset, including MCP2 I/O controller with Dolby Digital support;
    3 DIMM slots for up to 3GB of PC2100, PC2700 or even DDR400 memory; Note that for dual-channel configurations you have to install a pair of identical memory modules;
    5 PCI slots and 1 AGP 8x slot;
    2-channel ATA-133/100/66/33 integrated controller;
    Two Serial ATA-150 ports;
    10/100Mb/s Ethernet;
    6 USB 2.0 ports;
    FireWire (IEEE1394);
    6-channel NVIDIA audio solution with hardware Dolby Digital;
    Overclocking functions, including Vcore, Vmem and Vagp adjusting, FSB Setting and Multiplier Setting;
    ATX Form Factor.
    The mainboard does not bring anything really new to us, except official support for the upcoming Athlon XP CPUs with 400MHz EV-6 PSB. We cannot state for sure, but it is possible that even present-generation nForce2-based solutions from ABIT are able to work with the forthcoming processors after BIOS re-flashing. There is also a possibility that the NF7-S 2.0 carries a new nForce2 North Bridge revision, as a result, all older products are not supposed to be really stable when 400MHz FSB is set.
    Pricing and availability information was not touched upon."
    hehe Old news
    alguem ja tinha postado o link pro forum mostrando isso
    Eu
    será?/
    será q a epox 8rda com o chip nforce2 suporta
    os futuros athlon de 400???
    Membro Avatar de Elrond
    Esses XP vão ficar rápidos d+, vai dar até medo...
    alguem podeira me responder se a epox nforce2
    tb suporta os futuros athlon de 400fsb!???
    plz!!
    to querendo pegar uma!
    foda..
    logo agora que chegou a minha 1.2 = ~
    foda!!!
    Membro Avatar de Seu Madruga
    Originalmente enviada por freeh
    foda..
    foda!!!
    compro com skol?
    antes de lguem perguntar a7n8x deluxe jah vem com esse suporte :P
    acho q nao deluxe tb
    asus r0x :P
    seu madruga,
    não.. ninguem me mandou emial ;(
    comprei na LM por 730 reais
    ASUS rlz?
    to com a minha parada.. já regravei bios e nada.. (asus a7n8x deluxe)
    Na boa alguem q compra uma placa desses q eh top, ate lancerem os athlon 400 ja comprou outra placa mae
    seu madruga,
    ASUS rlz?
    a minha tah boa por enquanto
    espero q continue assim
    boa sorte com sua abit
    Originalmente enviada por S1lv3r
    asus r0x :P
    Com certeza não... nao deve xegar nem a 366MHz de FSB
    E Asus não é r0x...
    Ae, alguém sabe se atualizando a bios esse atlhon 400 vai rodar na minha v1,1 ?
    OFICIALMENTE, não. Foi respondido lá em coima, preste mais atenção
    PS: Puta sacanage, fecharam o do Trem sendo q ele posto primeiro
    Membro Avatar de NoOne
    Muito boa sorte para sua ASUS
    Obs.: Não tente algo de extremo nela, heim!
    NoOne
    Feb 1999
    Desculpa, não resisti.
    po é mesmo, ñ entendi nada...quase dois dias antes de post... :/
    o que é FSB ?
    Originalmente enviada por Hiperurano
    o que é FSB ?
    Front Side Bus
    como vou te explicar?? vai assim: eh a frequencia base que o processador trabalha
    por exemplo um duron 1000 ele eh 10 x 100mhz (esse 100mhz eh o fsb)
    outro exemplo um athlon XP2000+ que eh 1666mhz eh 12.5 x 133mhz (esse 133 eh o fsb)
    mas podem existir diferentes FSB para um mesmo clock
    exemplo : 2 giga hertz ?
    isso influi em desempenho e compatibilidade ?
    pode sim, tem cpu q o normal eh 100, 133 e 166
    influi, quanto mais alto o fsb, mais rapido fica
    sim, vc pode ter 2 fsb a 133, mas um dos pc ta com multiplicador mais atlo, entao tem mais megahertz!
    obs: axo ke a 8rda+ vai cata 400mhz com up na bios!
    Ex:
    CPU @ 2ghz, de 2 maneiras:
    1)FSB 200mhz x 10 mult = 2ghz
    2)FSB 150mhz x 13.5 mult = 2ghz
    Sendo que o primeiro eh bem mais rápido que o segundo...
