    Membro Avatar de NoOne
    Geforce FX 5200 Go vs. Radeon 9200M
    vs.
    Artigo
    A major OEM has both the Geforce FX 5200 Go and Radeon 9200M up and running. We managed to slip in a side door to get a sneak look at the performance of these chips. The main advantage of the FX 5200 is DirectX 9 support and "cinematic rendering" but, as always, people like to see how this affects real life applications and games.
    The test machine had a P4 3.06 GHz and 1 GB of PC 1066 memory and all the tests were run at 1024x768. That's all we had time for. Both chips were running at 250 MHz for the core and 200 MHz for memory.
    In 3dmark 2001 the Geforce FX 5200 Go scored 6579 marks while Radeon 9200M scored 7534, almost a thousand more. In "Nvidia do not recommend" 3dmark03, Geforce FX 5200 GO got 871 while Radeon 9200M managed 1222 marks. In UT 2003 Asbestos the Geforce FX 5200 Go you will get about 62 FPS while Radeon 9200M will get you about 87 FPS.
    DirectX9 but at what performance cost? We leave the conclusion to you.
    source | the inquirer
    Novamente a nVidia pisa na bola?
    Desenvolvem uma placa identica a uma MX460, com um desempenho muito baixo em DX9 se comparado com sua concorrente direta, a Radeon 9200M..
    Radeon 9200M em relação a GFFX 5200 Go
    3DMark2001 - 15% mais rápida
    3DMark2003 - 30% mais rápida
    UT 2003 _ - 40% mais rápida
    Realmente decepcionante..
    NoOne
    Aug 2001
    to achando q a gente vai ter uma nova marca de PONTA no mercado de placas de video!!
    ACHO COM MESMO JA Q TIVEMOS Q ENGOLIR A NVIDIA, E VER A MORTE DA 3DFX!!!
    ...CHUUUUUUUUUUUPAAAAAAAA........NVIDIA!!!!
    Competência é a alma neste negócio!!!
    acho q deveria ter uma outra fabricante de vgas pra aumentar essa concorrencia ai.... ia cair pra caralho os preços das vgas =/
    Feb 1999
    Originalmente enviada por F*Ck YoU
    Tá difícil, com a competência equivalente às duas... SiS, Matrox e Trident são piadas de mau-gosto.
    ----In "Nvidia do not recommend" 3dmark03, Geforce FX 5200 GO got 871 while Radeon 9200M managed 1222 marks.----
    Então é por isso que a nVidia não recomenda o 3D mark 2003.
