    Membro Avatar de Pr0x
    Meu Agp não passa de 2x. Help!
    Por que será?
    Li quase todos os topicos sobre isso e nao achei a resolução.
    Peguei o rivatuner e ele me disse o seguinte sobre meu sistema:
    $ffffffffff ---------------------------------------------------
    $ffffffffff Northbridge information
    $0400000000 Description : VIA Apollo PRO series
    $0400000001 Vendor ID : 1106 (VIA)
    $0400000002 Device ID : 0691
    $0400000003 AGP bus : revision 1.0
    $0400000004 AGP status : enabled
    $0400000005 AGP rate : 1x 2x supported, 2x selected
    $0400000006 AGP SBA : supported, disabled
    $0400000007 AGP FW : not supported
    $ffffffffff Display adapter information
    $0000000000 Description : NVIDIA GeForce2 MX/MX 400
    $0000000001 Vendor ID : 10de (NVIDIA)
    $0000000002 Device ID : 0110
    $0000000003 Location : bus 1, device 0, function 0
    $0000000004 Bus type : AGP revision 2.0
    $0000000005 AGP status : enabled
    $0000000006 AGP rate : 1x 2x 4x supported, 2x selected
    $0000000007 AGP SBA : not supported
    $0000000008 AGP FW : not supported
    $0000000009 Base address 0 : d6000000 (memory range)
    $000000000a Base address 1 : d8000000 (memory range)
    $000000000b Base address 2 : none
    $000000000c Base address 3 : none
    $000000000d Base address 4 : none
    $000000000e Base address 5 : none
    $ffffffffff NVIDIA specific display adapter information
    $0100000000 Graphics core : NV11 revision B2
    $0100000001 Hardwired ID : 0110
    $0100000002 Memory bus : 64-bit
    $0100000003 Memory type : SDR (RAM configuration 06)
    $0100000004 Memory amount : 65536KB
    $0100000005 Core clock : 199.656MHz
    $0100000006 Memory clock : 167.043MHz (MPLL doubling detected)
    $0100000007 Reference clock : 14.318MHz
    $0100000008 Maximum Fvco : 500.000MHz
    $0100000009 Core PLL Fvco : 399.313MHz
    $010000000a Memory PLL Fvco : 334.086MHz
    Help por favor
    Re: Meu Agp não passa de 2x. Help!
    Originalmente enviada por Pro0Oximus
    Entendeu ou vai precisar que desenhe?
    PS: Seu chipset não suporta
    qual sua mobo?
    isso que eu tmb quero saber, QUAL SUA MOBO?!
    Originalmente enviada por guismarquesrj
    Pra que tanto curiosidade!?
    Daki a poko soh suporta 2x mesmo
    Daki a poko eh veio e soh suporta 2x mesmo
    Putz
    Voce REALMENTE quer que eu DESENHE!!?!?!?!
    Olha lá em cima, presta atenção...afff
    Manjo poko de hardware....q akilo quer dizer?
    Acontece
    Mas olha minha msg lá em cima
    Atah......$0400000005 AGP rate : 1x 2x supported, 2x selected
    Intaum soh suporta 2x mesmo neh?
    Puxaaa, imprecionamteeeee!!!!
    Help!
    Minha mobo (bem eu nao sabia) mas de acordo com o 3dmark2001se é:
    Manufacturer: ASUSTeK Computer INC.
    Model: P3V133 <---- Essa merda
    Version: REV 1.xx
    BIOS Vendor: Award Software, Inc.
    BIOS Version: ASUS - 30303031
    BIOS Release Date: 13/03/00
    BIOS Properties: Plug and Play, Flash, AGP
    Será q ela não suporta 4x mesmo?
    Re: Help!
    Version: REV 1.xx
    Será?
    Eu tenho CERTEZA
    merda
    1479 PONTOS NO 3DMARK!!!
    M-E-R-D-A
    E overclock....
    Sabe...so Novo nisso...heheh...
    Então como faço um overclock e quanto que eu coloco nessa MoBo com um p3 700?
    Re: merda
    M-E-R-D-A
    TA Otimo pra Pentio3 com MX fedida!
    Re: E overclock....
    Cara esquece... Nem tenta fazer overclock em P3 porque é praticamente inútil...
    Oi Pro0Oximus,
    Liga não pois pobre neste fórum pobre não tem muita vez. Se você falasse que tinha uma Radeon num-sei-o-que, rodando numa Abit-plus-ultra talvez nego ajudasse (lógico que há algumas exceções).
    Vamos lá: minha mobo é igual a sua mas o m/ processador é de 600MHZ. Consegui fazer um oc para 744 MHz alterando os jumpers da placa mãe da seguinte forma:
    Nos jumpers CPU Bus Frequency Selection (FS0, FS1, FS2, FS3) : setei para CPU 124 MHz / PCI 31 MHz
    Nos jumpers CPU:PCI Bus Frequency Multiple Selection (MS0, MS1): setei para X4
    Como o processador é travado não adianta mexer no multiplicador.
    Se você não tiver o manual baixe em : http://www.asus.com.tw/support/downl...delName=P3V133
    Resumindo, obtive 6x124 = 744 MHz e PCI = 31 MHz
    No seu caso, você vai chegar em 868 MHz. Não vai resolver o problema mas dá uma ajudazinha....
