    Placa Mae e a placa de som Echo Layla
    to afim de montar um computador pra botar uma placa de som profissional chamada echo layla, mas saca so o que o suporte diz
    AMD CHIPSET GUIDE
    AMD Athlon processors work well with Echo Digital Audio hardware. You will need a motherboard with one of the following chipsets:
    AMD 760 (761,762 or 766) - Note: the AMD 560 series is not compatible with Echo Hardware
    AMD760MP (Multi Processor)
    VIA KX-133
    VIA KT-133 & 133A
    VIA KT266 & KT266, 266a
    VIA KT333
    VIA KT400
    These recommended chipsets are now available on motherboards from numerous manufacturers. Follow the link below to get more information on VIA chipsets (http://www.via.com.tw/en/index/index.jsp). There are many motherboards that support AMD processors. ASUS, TYAN, Gigabyte, and others have been tested and work with Echo hardware. MSI (Micro Star International) and ABIT boards may not work well, and are not recommended at this time.
    AMD K6 processors and Intel processors with a non-Intel chipsets are not supported.
    This may or may not work. Officially, AMD K6 processors and Pentiums with non-Intel chipets are not supported. Some users have enjoyed success while others experience lockups or other problems.
    eu gostaria de saber os melhores modelos dessas mobos VIA, que tenham usb 2.0 e ultra ata ou sata
    obrigado
    ahh , e tambem pra nao fazer overclock
    principalmente isso, o fabricante nao recomenda overclock e eu tambem nao estou interessado, vou tentar montar o melhor possivel com as melhores peças nao preparadas pra overclock
