    BOMsoMITO 2018!
    Catalisty 3.3 Canceled !
    Meu deus ! Cancelaram o 3.3 pra lancar o 3.4 nas proximas semanas , entre os dias 14 e 15 !
    fonte www.rage3d.com
    Membro Avatar de Tcool
    Jan 2001
    Afffff pqpqppq
    Releasing of Catalyst Drivers 3.3 to be cancelled! - 3:21 pm EST - G.I.Bro
    Sorry for getting this info out to you a little late, I've been suffering from major ISP problems today. But anyways... Yes this is correct. Today ATi has officially canned the release of the Catalyst 3.3 Driver set!! Don’t be too worried though... The 3.4's Cats are soon to be here.
    CATALYST 3.3 has been cancelled and will not be posted. We will jump over to CATALYST 3.4 this time and the time frame we are looking at right now is May 12th-15th (now do NOT hold me to that) Its not a promise just that is what the schedules are looking like at the current time. These drivers are currently in the hands of our beta testers and going through the final run through. If all goes well you guys will get them in the time frame I mentioned above and you will be very happy with them. They will have performance boosts across the boards, some bug fixes, some new features, and of course the best image quality in the business!
    That message was directly from Terry Makedon (CATALYST maker) himself.
    Be sure to drop by our forums, seeing that Terry is holding a Q/A session about this outcome.
    []'z
    Jan 2001
    Andei lendo e o Catalyst Maker disse q o bug do cs com a smoke é um bug do proprio cs pois ate as geforcesFX estao apresentando esse problema... Diz ele q o problema dos fps com as 8500 nao existe ( cara se faz de troxa ) e que nada foi arrumado nesse sentido.. agora eh esperar e ver se melhora alguma coisa.. diz ele que a 9700 sera a mais beneficiada com esse driver...
    []'z
    Membro Avatar de *=-Tênis AR-=*
    Rly?!
    Tomara q eles tenham cancelado por causa dos bugs no CS principalmente, pq o q tem de gente enchendo o saco da ATI por causa disso heheheh
    se for por isso, vale a pena esperar mais um pouquinho pra ter um negócio bom do que ter uma porcaria que talvez fosse o 3.3
    Rly?!
    Originalmente enviada por Tcool
    []'z
    Aff, ou esse cara é idiota ou tá se fazendo, porque se ele quiser eu esfrego na cara dele uma Geforce 4 mx 440 sem problemas de fps
    e a minha radeon 8500 275/275 com problemas.
    []'z
    haahah bug com as 8500 nao existe? bahhhhhhhhh
    isso eh o q eu mais esperava desse novo catalyst, q vacilo
    eu tenho nojo de CS, mas instalei pra testar aki, e funfo normal com 99 fps, acho q vcs q naum sabem configurar suas makinas
    Originalmente enviada por F*Ck YoU
    I agree with that,
    minha R9100 no CS 99fps com direito a varios efeitos....
    Jan 2001
    Eu consigo 99 de fps cravado tb.. mas muita gente reclama, mesmo fazendo todos os procedimentos descritos pelo pessoal la do forum.. aqui so resolveu o problemas do cs apos ter instalado o windows 2000 e o omega driver...
    []'z
    aki tb fica trankilo apesar q eu n instalo cs a seculos
    Bla bla bla, to jogando DoD 1.0 aki cravando 99fps...
    uhuuuuuuu
    A placa mais beneficiada será a 9700!!!
    uhuuu
    Beleza!!!!!!
    e eu que achava que o bug do cs era o bug da minha vga, ehehehehehh
    BOMsoMITO 2018!
    Originalmente enviada por Radeon-Man
    uhuuuuuuu
    uhuuu
    Beleza!!!!!!
    é nois na fita no CD e no DVD
