    Vale a pena comprar essa mobo?
    MSI
    KM2M Combo-L
    MS-6738
    • Supports Socket A for AMD® Athlon™/Athlon™ XP
    /Duron™ processor
    • Supports 1GHz to 2600+ processor.
    • VIA® ProSavageDDR™ KM266 Chipset
    - FSB @200/266MHz
    - Integrated ProSavage8™ 2D/3D Graphic Controller.
    - AGP 4x and high bandwidth V-link host controller.
    - Advanced memory controller supports DDR266 technology.
    • VIA® VT8235 Chipset
    - 533MB/sec Vlink client controller.
    - Direct sound ready AC97 digital audio controller.
    - Ultra DMA 66/100/133 master mode EIDE controller.
    - Supports both ACPI and legacy APM power management.
    - 6 ports USB 2.0 controller.
    - Integrated Ethernet MAC.
    FSB
    100/133MHz (200/266MHz) clocks are supported.
    Main Memory
    • Supports four memory banks using two 184-pin DDR DIMMs
    or two 168-pin SDRAM DIMMs.
    • Supports a maximum memory size of 2GB.
    • Supports 2.5v DDR SDRAM DIMM.
    Slots
    • One AGP (Accelerated Graphics Port) slot. (Optional)
    - AGP specification compliant.
    - Supports AGP 2.0 2x/4x
    • Three PCI 2.2 32-bit Master PCI Bus slots.
    - supporting 3.3v/5v PCI bus Interface.
    On-Board IDE
    • An IDE controller on the VT8235 chipset provides IDE HDD/
    CDROM with PIO, Bus Master and Ultra DMA 66/100/133
    operation modes.
    • Can connect up to four IDE devices.
    Audio
    • Front Audio supported.
    • Chip Integrated.
    - Realtek ALC 650 codec.
    - 5.1 channel AC'97 software Audio.
    Video
    LAN
    • VIA® VT8235 integrated MAC + VIA 6103 PHY.
    - RJ45 connector.
    On-Board Peripherals
    On-Board Peripherals include:
    - 1 floppy port supports 2 FDDs with 360K, 720K, 1.2M, 1.44M
    and 2.88Mbytes
    - 1 serial port (COM1), 1 Intel-spec serial port (JCOM2, Optional) and 1 VGA port
    - 1 parallel port supports SPP/EPP/ECP mode
    - 6 USB ports (Rear x 4 / Front x 2)
    - 1 Line-In/Line-Out/Mic-In port
    - 1 LAN RJ45 connector
    - 1 IrDA connector for SIR/CIR/ASKIR/HPSIR
    BIOS
    • The mainboard BIOS provides "Plug & Play" BIOS which detects
    the peripheral devices and expansion cards of the board
    automatically.
    • The mainboard provides a Desktop Management Interface(DMI)
    function which records your mainboard specifications.
    Dimension
    24.5 cm(L) x 23.8 cm(W) MicroATX Form Factor
    Qual o preço?
    300 reais. eu sei que é o mesmo preço de uma A7N, mas ela oferece suporte a memos SDR, alem das DDR. E como no momento estou impossibilitado de me desfazer das minhas memos SDR pensei na possibilidade da compra desta mobo.
    Originalmente enviada por Aderson1
    Eu particularmente optaria pela A7N266 mesmo, mas se vc precisa pra agora, com SDR e vídeo onboard, essa mobo serve...
    (Embora se não me engano Savage não tem T&L, mas blz...)
    Membro Avatar de Netto-19
    PRENDAM O NINE FINGERS!!!
    chuta que é macumba
    Quando eu vejo essa palavra mágica "Savage", eu me arrepio
    foge disso mizifi
    Originalmente enviada por Netto-19
    chuta que é macumba
    foge disso mizifi
    Mas ela não serve nem pra rodar show do milhão 4, jogos de master system, office e internet? A maquina não é pra jogos pesados. É pra funções simples. Não quero ter que usar pcchips & cia, tô fugindo de chipset sis.
    Pra isso serve. Pega uma A7N266-VM (acho que é essa) tem uma MX200 on-board, pelo menos não tem problema de drivers.
    Se não der pra pegar essa...
    O ideal seria a A7N266, mas a grana tá tão curta que eu não vou poder comprar as DDR pra essa placa , o problema é encontrar quem venda essa MSI, só encontrei um que vendia no Mercado Livre mas fico com um pé atrás pra comprar lá, mas se não tiver outro jeito...Deus me ajude.
    Se tah faltando grana leva uma K7s5a memo, q custa uns 250 paus no max. e com a sobra vc pega um video de baixo custo melhor q Mx200
    dcli 101
    vende as suas SDR e pega DDR que a diferença é mto pequena
