Página 2 de 2 Primeira 1 2
    May 2000
    bug da epox =]
    normal isso
    como q entra na bios? eu so sei entra no setup!
    Membro Avatar de Megallanic
    fica apertando INSERT desasperadamente ai qnd iniciar o pc....
    Membro Avatar de NIex
    apl525 here
    Below is a reprint of selected portions from the README.TXT file that
    is included with all BIOS downloads from the EPoX USA website. Please
    always refer to the original README.TXT file for details about the
    specific BIOS downloaded.
    !!!WARNING!!!
    Never attempt to Flash your BIOS from a hard disk, DOS Window, DOS
    shell, or in Windows NT. If your system is working without problems
    or conflicts, then it is not recommended that you flash your BIOS.
    Improper flashing procedures may result in a dead system! Follow
    these instructions carefully.
    DO NOT FLASH YOUR SYSTEM IF IT IS BEING OVERCLOCKED - IT MAY RESULT
    IN A CORRUPTED BIOS FLASH.
    Files included in this download:
    README.TXT Text file with BIOS Release & Application Notes.
    UPDATE.BAT Batch file for the Flash BIOS update process.
    RESTORE.BAT Batch file for the Flash BIOS restore process.
    xxxxxxxx.BIN BIOS binary file used by UPDATE.BAT.
    AWDFLASH.EXE Program used to Flash BIOS code to the EEPROM.
    Archives of past BIOS releases (if any) are available on our FTP
    server or by contacing technical support:
    ftp.epox.com/motherboard/support/bios/
    BIOS Update Instructions
    There are two ways in which we recommend to flash the BIOS.
    They will be termed as follows:
    . The ALT+F2 Method
    . The Boot Disk Method
    The ALT+F2 method may not be available on older mainboards with older
    BIOS, in such cases it is necessary to carry out the Boot Disk Method.
    The ALT+F2 Method
    1. Download the required BIOS image file from the EPoX website.
    2. Copy or extract the BIOS image file (named xxxxxxxx.bin) to a blank
    floppy disk with no bad sectors on it.
    3. Restart the machine with the floppy disk in the floppy drive
    When prompted at machine initialization, press ALT+F2 to begin
    performing the flashing of the BIOS.
    4. The BIOS will automatically flash and reboot the machine.
    5. After this, press DEL to enter the BIOS setup and select to "LOAD
    OPTIMIZED DEFAULTS". After doing this select to "SAVE & EXIT."
    6. Please note that this does not create a backup of the BIOS binary file.
    7. This does not require you to have a bootable floppy disk.
    1. Create a bootable floppy disk in accordance with the instructions
    laid out in the manual of your particular operating system. This
    bootable floppy needs to be able to boot to a DOS console capable of
    executing normal MS-DOS batch and executable files.
    2. Download and extract the xxxxxxxx.EXE file corresponding to your
    model from the EPoX website to the floppy. It will self extract into
    the above listed files.
    3. Boot using your DOS floppy disk to the ‘A:\>’ command prompt. At the
    DOS command prompt type: UPDATE
    4. The BIOS will automatically flash.
    5. Reboot the machine.
    6. After this, press DEL to enter the BIOS setup and select to "LOAD
    Note: During the use of UPDATE a backup of your original BIOS
    date/code will be saved in the same directory as the UPDATE file. It
    will be called ‘OLD.BIN’ and can be used with the restore
    instructions below in case you need to revert back to the original
    BIOS date/code.
    BIOS Restore Instructions
    Use of the restore procedure requires the OLD.BIN file created in the
    Boot Disk method procedure above!
    1. Boot using your DOS floppy disk to the ‘A:\>’ command prompt. At
    the DOS command prompt type: RESTORE
    2. The BIOS will automatically flash.
    3. Reboot the machine.
    4. After this, press DEL to enter the BIOS setup and select to "LOAD
    5. The system flash is now completed and should now be reverted back
    to the original BIOS date/code.
    BIOS flash failed
    If you have access to an old un-accelerated ISA video card, you might
    be able to recover your BIOS. Remove all cards and drives from your
    system, except for the ISA video card and the floppy drive. Then try
    to boot from a system disk (a bootable floppy with only the flash
    programs and corresponding BIOS binary). If you are able to boot to
    the floppy, flash your BIOS according to the directions above.
    I get out of memory errors when I flash my BIOS!
    On some system configurations, even with a clean boot disk, you will
    get an out of memory error (insufficient memory) when you try to
    flash your BIOS. The solution is simple: Try bypassing the startup
    files by pressing the following keys during startup using you
    bootable floppy disk. Attempt the FLASH again.
    DOS 6.2x boot disks - press F5 to bypass.
    WINDOWS 95/98 boot disks - press F8 and select "Safe command prompt."
    Lastly try using a MS-DOS 6.x boot disk.
    Manual use of the AWDFLASH Utility
    Most users will find that our UPDATE and RESTORE batch files can
    accomplish the BIOS flash with the majority of configurations. But if
    you wish to manually use the AWDFLASH utility, below are the most
    common command line usages and parameters.
    Awdflash 7.87d (C)Award Software 2000 All Rights Reserved
    Usage: AWDFLASH [FileName1] [FileName2] [/<sw>[/<sw>...]]
    FileName1 : New BIOS Name For Flash Programming
    FileName2 : BIOS File For Backing-up the Original BIOS
    <Swtches>
    ?: Show Help Messages
    py: Program Flash Memory pn: No Flash Programming
    sy: Backup Original BIOS To Disk File sn: No Original BIOS Backup
    Sb: Skip BootBlock programming sd: Save DMI data to file
    cp: Clear PnP(ESCD) Data After Programming
    cd: Clear DMI Data After Programming
    cc: Clear CMOS Data After Programming
    R: RESET System After Programming cks: Show update Bin chksum
    Tiny: Occupy lesser memory
    E: Return to DOS When Programming is done
    F: Use Flash Routines in Original BIOS For Flash Programming
    LD: Destroy CMOS Checksum And No System Halt For First Reboot
    After Programming
    cksXXXX: Compare Binfile CheckSum with XXXX
    Example: AWDFLASH 2a59i000.bin /py/sn/cd/cp/cks2635
    DISCLAIMER
    THE SOFTWARE AND BIOS ARE PROVIDED "AS IS" WITHOUT ANY EXPRESS OR
    IMPLIED WARRANTY OF ANY KIND INCLUDING WARRANTIES OF MERCHANTABILITY,
    NONINFRINGEMENT OF INTELLECTUAL PROPERTY, OR FITNESS FOR ANY
    PARTICULAR PURPOSE. IN NO EVENT SHALL EPOX OR ITS SUPPLIERS BE LIABLE
    FOR ANY DAMAGES WHATSOEVER (INCLUDING, WITHOUT LIMITATION, DAMAGES
    FOR LOSS OF PROFITS, BUSINESS INTERRUPTION, LOSS OF INFORMATION)
    ARISING OUT OF THE USE OF OR INABILITY TO USE THE SOFTWARE AND BIOS,
    EVEN IF EPOX HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
    BECAUSE SOME JURISDICTIONS PROHIBIT THE EXCLUSION OR LIMITATION OF
    LIABILITY FOR CONSEQUENTIAL OR INCIDENTAL DAMAGES, THE ABOVE
    LIMITATION MAY NOT APPLY TO YOU. EPoX and its suppliers further do
    not warrant the accuracy or completeness of the information, text,
    graphics, links or other items contained within these materials.
    EPoX reserves the right to change specifications or discontinue
    products at any time with no prior warning. EPoX makes no commitment
    to update any BIOS.
    v1.2 03082002 JRH
    Faltou ler neh
    Originalmente enviada por PokePlanet
    cassete.....
    eh a msm coisa, ehehehehehheh
    apl525 here
    cassete.....
    hauhauhauhauhuahuauahu
    º×ô®U®ô|}öm¦EÍ
    hehehe q medo
    vo te que atualiza a bios
    com essa qui nao pega fsb 200 =| e com otra pego 230
    Originalmente enviada por ReVeRsE
    hehehe q medo
    Couriosidade: Com qual vc pega 230 ??? hehehe
    ontem, após atualizar a minha bios, nf7-s
    também apresentou isso.. mas era tava 100x10x (e é um 2600+)
    aí entrei lá na bios, configurei e ficou blz..
    acredite se quiser... com a que veio na placa...
    tenho screen
    to com aquela beta 3402 e to muito insatisfeito
    tu tem icq hunterlord ?
    uin
    tenho screen
    uin
    Opa, tenho 170003933
