    Reviews Nvidia, GFX 5600 ultra e GFX 5900 Ultra.
    http://www.nordichardware.com/review...e909b6e127992a
    O preço estimado da placa esta na faixa de $ 175,00 ela ainda vem com um bonus: Firewire PCI-card, Firewire cable, ViVo-dongle, DVI-VGA adapter.
    O outro reviews é do pessoal da Guru3D ( www.guru3d.com ). Eles chegaram a essa conclusão.
    " Well people, I think you will all agree with me in saying that nVIDIA is back on track. The GeForceFX 5900 Ultra really is a magnificent piece of technology. The overall impression is without a doubt in my mind awesome, feature rich, DX9, 256 MB, performance, eight pixel pipelines, basically all we want. Right now this card will make your high-end rig smoke .. and that smoke is not originating from heat this time
    The card we received was based on silicon A1,_that means the first build. This build is so good that it actually will be used on the end-product/consumer boards. The card ran extremely stable on our test rig, in fact we have had not one crash and all games simply ran top notch. That's quite amazing considering we used the early beta drivers.. These same drivers where WHQL certified and got the 'official' status mark in week three from May though. Again with time it's likely the product will get even a tad faster due to newer detonator driver releases with better optimisations and fixes. Also as stated, the board we tested will in retail be actually a tad smaller in size. Allow me_to explain:
    When I was at NVIDIA in Santa Clara in May they where working on some design changes in the technology laboratory and the final board size will be the about the same size as you see them right now on the GeForce4, the 8 layer version PCB's (Ti4600). It's true .. I've seen it with my own eyes.
    That said, next to regaining the performance crown from the competition nVIDIA absolutely felt the pressure and took good note of the negative feedback you guys broadcasted on site's like Guru3D.com Therefore they switched to a cooling solution that unfortunately is still somewhat too big (takes up one AGP and PCI slot) yet is by far more silent compared to the FlowFX cooling solution we saw on the 5800 Ultra.
    So nVIDIA is definitely back on track and are performance wise exactly where they should be with this product. I can highly recommend the GeForce FX 5900 Ultra to any high-end user, but not to anyone else though! Let me explain. If you play your games at 1024x768x32 or have an LCD screen then just skip this product .. go for a 5600 Ultra or another less competitive product. You will save a lot of money ! This product is for the true geeks, people that need raw power in the highest resolution with quality settings enabled. That means 1600x1200x32 with Anti Aliasing enabled at 4x and Anisotropic filtering enabled at 8x. That's where this product rocks and if this appeals to you then this product is right for you. Clear and simple. Do you play at lower resolutions and do not care about AA and AF ? Then forget about it as you'd pay a lot of money for performance you'd never see. The card will cost you 499 USD, in Europe even more due to higher taxes.
    Oh and for the users that bought (where able to buy) a GeForce FX 5800 Ultra with FlowFX ... hang on to it. Only a few thousand models where shipped and this 5900 Ultra will completely replace the 5800 Ultra product, its official now it'll be exterminated. Why do I say hang on to it ? The product will become a collector's item in a few years from now. Also let me once again state .. the 5800 Ultra is not a bad product at all !
    Alright, this review is getting too long already, congratulations to nVIDIA for getting back the performance lead. Two thumbs up for listening to the public about FlowFX. This is a product I can recommend by heart. "
    Eu coloquei em bold algumas partes interessantes, no que se refere ao driver que embora fosse beta não apresentou problemas em nenhum dos jogos.
    O que eu achei legal é essa possivel reengenharia do PCB para ficar do tamanho de uma GF 4600...
    O mais forte do universo!
    aonde q eu vo ler isso tudo! resume alguem ae
    Ta rolando um rumor q eles ainda vao acelerar o Nv35 mais ainda pra competir com uma suposta 9800Xt , q por sua vez eh uma 9800 acelerada pra competir com a 5900 q tem sido testada
    BOMsoMITO 2018!
    Vi isso tb
    mas pra mim é BS
    Originalmente enviada por -= Douglaster =
    Vi isso tb
    mas pra mim é BS
    Bom no caso da 9800Xt kem falou isso foi o cabeca da B3D, q inclusive alegou q teve uma reuniao com os caras da Ati.
    Da 5900 ta realmente muito mais vago, no naipe "there is some indication.."
    De qqr forma isso mostra como a concorrencia ta pegando fogo
    A FX5600 Ultra é uma boa substituta para a GF4 Ti4200 e vem com um combo bem interessante.
    A ATI 9800XT vem com um clock maior, 256bit bus, 256Mb DDR-II e com o preço lá nas alturas.
    Re: Reviews Nvidia, GFX 5600 ultra e GFX 5900 Ultra.
    Originalmente enviada por Bastet Mait
    [url]O preço estimado da placa esta na faixa de $ 175,00 ela ainda vem com um bonus: Firewire PCI-card, Firewire cable, ViVo-dongle, DVI-VGA adapter.
    175 dólares a FX5600 Ultra Golden Sample ?
    Old School 2001
    Parece que a FX5600 ULTRA veio pra competir com a 9500 pro e por um preço menor...acho que vale apena pegar uma dessa, pois custa menos do que uma 9500 pro e tem performance semelhante
    tah mto bom esse perço da FX 5600..... vo começa a procura uma .... ia d RADEON 9500 + agora desisti
    Realmente o preço ta muito bom, e se bater a R9500 PRO, porra ta excelente!
    Membro Avatar de duferrari
    http://www.nordichardware.com/review...ltra/index.php
    realmente esse preço ta bom ......
    Membro Avatar de Mirage
    Gold member
    foi essa placa mesmo q me fez desistir da radeon9500 pro...
    sempre usei nvidia...
    estava sendo atraido pelo lado negro da força hahah =P
    mas como naum vou comprar agora mesmo, vou esperar a poeira acentar...
    Old School 2001
    Acho que vou pegar uma GFX 5600 ULTRA mais tarde tmb...vou voltar de NVIDIA novamente! Essa modelo 5600 ULTRA ainda não esta realmente acima da 9500 pro mas quem sabe melhore o desempenho com drivers novos...
    é aquela, preços aproximados sao uma coisa mas na pratica é outra coisa hehe
    lançamento de r9500pro tb era around 179 mas quando lançou era mais de 200 hehe
    mesmo assim bela placa a fx 5600ultra
    Gold member
    mas depois todos os preços caem...
    soh estou esperando para lancar, mas naum vou pegar essas todas equipadas... vou pegar uma mais simples...
    soh com tv out mesmo...
    tb vo pega uma 5600
    qual a diferença da 5600 normal pra ultrA?
    soh os clocks?
    up pra esse tópico
    obs: eta plaquinha ruim pra over ..
    Membro Avatar de Fabdall
    Mesmo com esse bla bla bla e tal, as nvidia tão com a imagem melhor que as Radeons (ou igual)nessas placas novas???
