    Membro Avatar de Lestat Dane
    Qual diferença entre chipset 875P e 865PE? O q eh Prescott?
    Alguem tira essas minhas duvidas?
    Re: Qual diferença entre chipset 875P e 865PE? O q eh Prescott?
    Originalmente enviada por Lestat Dane
    Prescott é o novo núcleo do P4
    Tipo NorthWood...
    Quanto aos chipsets, pow
    Sei lá, procura
    Re: Re: Qual diferença entre chipset 875P e 865PE? O q eh Prescott?
    Tipo NorthWood...
    Sei lá, procura
    Procurei, mas pelo o q eu vi são a msm coisa: Suporte 800fsb, dual channel, etc, etc...
    Vlw ae!
    Intel Prescott 3.x-5Ghz 0.09µ 1MB L2 800mhz FSB
    http://www.xbitlabs.com/articles/cpu...scott-sse.html
    sobre os chipsets:
    http://www.xbitlabs.com/articles/cpu...ay/p4-800.html
    Canterwood a.k.a. 875P
    • Intel 875P. Intel targets this chipset for the High-End market segment and for use in the fastest PCs. That is why it will have no integrated graphics core, which is always replaced with a high-performance graphics cards in any high-end PC. All other new features, including PAT, are fully supported. Also we would like to point out that this chipset is the only one of all newcomers with ECC support.
    Springdale a.k.a. 865xx
    • Intel 865PE. This is the younger brother of i875P, which is targeted for the mass market. It boasts all the same features, except PAT and ECC support.
      Intel 865G. This is a modification of i865PE with an integrated graphics core aka Intel Extreme Graphics 2.
      Intel 865P. This is a “lite” version of i865PE, which doesn’t support 800MHz processor bus.
    ALguem pode me explicar melhor como funciona o PAT?
    PAT (Performance Acceleration Technology). This technology is intended to improve the chipsets performance. It speeds up the system by taking advantage of the “internal reserves”. Namely, this technology reduces the latencies when the CPU works with the system memory via the chipset. You don’t need any specific memory modules to make this technology work: all the necessary optimization is made inside the chipset North Bridge and in the BIOS. When the CPU addresses the system memory, the chipset omits some operations typical of other core logic sets and performs certain operations faster.
    Saberia me dizer c essas placas 875P suportam o Prescott?
    vlw
    vlw
    Acho que sim..olha o desenho que eu postei acima...
