    Membro Avatar de CoachCarter
    Captura da deluxe num tá funfando aki
    Tentei altos drivers, sempre da
    THIS device cannot start code 10
    Win xp pro SP1
    k7s5a
    V7700 deluxe
    up
    Tá com os drivers WDM instalados?
    To sim, eles instala todos, só que o wdm capture driver(universal) fica com uma exclamação e na propriedades tá escrito "This device cannot start (code 10)"
    UP que num funcionou ainda aki, eu andei lendo que é problema do XP
    Alguem que tá usando uma placa da nvidia com captura qq me diz que detonator e que driver de captura tá usando
    Afe Maria!!!!!
    É Impossivel num ter dado esse problema com ninguem!!!!
    Escrevi no google this device cannot start code 10 nvidia capture e milhões de pessoas tiveram o mesmo problema!!!!
    G4 TI 4400 MSI VIVO 128Mb
    Driver: Sei lá, sempre usei trocentos e nunca influenciou
    WDM: 1.27
    Funciona legal aki
    Olha uma das soluções que eu encontrei....
    Putz, num testo agora pq to no trabalho
    God I've had that problem some many times in XP it makes me sick. It doesn't matter how well you root out old drivers and such, it WILL happen. I tried everything from chipset drivers to BIOS flashes. Nothing. Yet another reason why I want to go back to 2000. Well the last time this happened to me (a few days ago) I went looking through every forum I could find. Someone posted how he fixed his and I didn't think it would do anything but it did indeed fix mine too. Go into your System Properties and go to the Advanced tab. Hit Settings for Performance Options and go to the Advanced tab. Change Memory Usage from System Cache to Programs. Reboot
