    Erro do SMART
    Estou tendo erros com um HD FUJITSU MPG3409AT E (VH06T160H0DB).
    Queria entender o que o SMART acusa.
    O erro é
    00 <vendor-specific> 20 1 0 984552 Advisory: Usage or age limit exceeded
    Não entendo. Quer dizer que o HD esta velho? Mas um HD de 40GB? Não concordo. Ele não tem tanto uso assim.
    Será que consigo RMA pra ele? O que tenho que fazer e o que eu preciso? É foda perder um HD de 40GB...
    Aqui está o report completo.
    01 Raw Read Error Rate 60 100 100 0 OK: Value is normal
    02 Throughput Performance 50 100 100 0 OK: Value is normal
    03 Spin Up Time 24 193 193 11010164 OK: Value is normal
    04 Start/Stop Count 0 100 100 225 OK: Always passing
    05 Reallocated Sector Count 5 100 100 0 OK: Value is normal
    07 Seek Error Rate 67 100 100 0 OK: Value is normal
    08 Seek Time Performance 20 100 100 0 OK: Value is normal
    09 Power-On Time Count 0 100 100 1710 OK: Always passing
    0A Spin Retry Count 60 100 100 0 OK: Value is normal
    0C Power Cycle Count 0 100 100 197 OK: Always passing
    C0 Power-Off Retract Count 50 100 100 283 OK: Value is normal
    C1 Load/Unload Cycle Count 50 100 100 283 OK: Value is normal
    C2 Temperature 0 220 220 20, 25 OK: Always passing
    C4 Reallocation Event Count 0 100 100 0 OK: Always passing
    C5 Current Pending Sector Count 0 100 100 0 OK: Always passing
    C6 Off-Line Uncorrectable Sector Count 0 100 100 0 OK: Always passing
    C7 Ultra ATA CRC Error Rate 0 200 200 78 OK: Always passing
    00 <vendor-specific> 32 65 0 139862 OK: Value is normal
    00 <vendor-specific> 25 90 0 3 OK: Value is normal
    00 <vendor-specific> 16 98 0 834 OK: Value is normal
    00 <vendor-specific> 24 100 0 0 OK: Value is normal
    00 <vendor-specific> 20 65 0 19163446 OK: Value is normal
    00 <vendor-specific> 20 100 0 0 OK: Value is normal
    00 <vendor-specific> 20 100 0 46 OK: Value is normal
    00 <vendor-specific> 0 100 0 28 OK: Always passing
    00 <vendor-specific> 20 70 0 3 OK: Value is normal
    00 <vendor-specific> 20 99 0 2 OK: Value is normal
    00 <vendor-specific> 197 200 0 0 OK: Value is normal
    00 <vendor-specific> 20 100 0 1740 OK: Value is normal
    Você terá que usar um programa (talvez do fabricante) que identifique esse "<vendor-specific>". Pode ser qualquer coisa.
    Esqueci de algo.
    No 2000 (que esta no outro hd) nem funciona. Mas ele da boot por conta propria(ele tem o 98).
    Que programa? Da Fujitsu? Eu usei o AIDA pra ver o SMART
