    Membro Avatar de Nabucodonossor
    Ati Radeon 7500 Agp 64mb
    Ae gente essa placa de vídeo é boa?
    ATI RADEON 7500 AGP 64MB
    With DVI+TV
    So quero jogar uns joguinhos como CS, GP3, Vampiro Redemption e outros.
    Ai vai a info dela:
    overview
    RADEON™ 7500 is a powerful and versatile graphic solution.64MB of powerful DDR memory along with the RADEON™ 7500 GPU provides high performance acceleration of today's demanding 3D graphic applications. Industry leading DVD playback, support for dual independent displays, and support for digital flat panel (DVI-I) monitors meet the needs of a wide range of home and business graphic users.
    At-a-glance
    Dual monitor and video output support
    64MB DDR memory accelerates the latest 3D and 2D games and applications
    HYPERZ™ increases graphics memory bandwidth
    VIDEO IMMERSION™ for industry-leading DVD playback
    High-resolution 32-bit 3D graphics up to 2048x1536
    Designed and manufactured by ATI
    Featuring CATALYST™ - ATI's industry-leading software suite with frequently scheduled free updates providing additional features and performance over the product's lifetime
    features
    Powerful 3D graphics performance
    Powered by the RADEON™ 7500 GPU and 64MB DDR memory for advanced 3D graphics
    Delivers immersive, realistic 32-bit color graphics without PC performance decline
    High-resolution 32-bit 3D gaming up to 2048x1536
    Full support of DirectX® and OpenGL® applications
    CHARISMA ENGINE™ supports full Transformation, Clipping and Lighting (T&L) at 45 million triangles/second peak processing capability
    PIXEL TAPESTRY™, the RADEON™ 7500 rendering engine, powers an incredible 1.74 gigatexels/second for the highest fill rates in 32-bit at high resolutions
    Flexible dual monitor support
    Supports combinations of traditional CRT monitors, flat panel displays and TV
    HYDRAVISION™ software provides the most flexible and user-friendly interface for multiple display settings:
    Multi-task with MultiDesk - create, name and organize up to nine active multi-monitor desktops
    Assign 'Hot Key' shortcuts for the functions used most often, like moving active windows or applications, accessing controls on the fly or opening applications
    Set applications to automatically open in preferred position on the monitor and eliminate the need to reset computer settings every time the computer is turned on
    Industry-leading DVD playback
    VIDEO IMMERSION™ technology allows for adaptive de-interlacing for best quality motion video and text
    Process full-frame rate, full-screen DVD or MPEG-2 video
    Hardware DVD saves the expense of buying a separate MPEG-2/DVD decoder card
    Motion compensation and iDCT allow for DVD decoding with minimum CPU usage
    Products designed and built by ATI offer:
    ATI warranty coverage
    Reliable customer service
    Driver updates from ATI.com
    Exclusive ATI software for optimized performance
    É uma placa de vídeo para um PIII somente provisória pois estarei montando até o ano que vem um pc mais elaborado, esse eh so pra jogar e entrar na net, e de vez em quando fazer um trabalho pra facul.
    A Placa ta saindu 250 com frete, ta bom o preço tb?
    Vlw, Eduardo
    Up ae ninguem sabe?
    sei la mas com 330 vc pega uma radeon 9100 64mb ou uma gf fx 5200 128mb .
    è mais ai ja ficou 80 conto mais caro, mais 20 de frete 100 reais mais caro ai ja passa do ke posso pagar heheheh, o maiscaro seria essa aki mesmo
    a placa eh legalzinha sim e vc vai rodar seus games legal se seu processador e memo cooperarem...
    mas no lugar dessa ae, pq naum uma gf2 Ti?
    acho que eh poco mais barata e eh mais popular
    Tipo curti essa pelo Tv OUt e o DVI e pelo nome da ATI tb o process vai seum PIII 600 memo 3 NEC de 128 PC 133 e ai sera ke fica legal? so ke o process vo da um over nele pra uns 800
