    Fim do drama GeforceFX x 3dmark03
    http://www.anandtech.com/news/shownews.html?i=19622
    FutureMark and Nvidia Statement
    Video | Kiran Venkatesh on Jun 2nd, 2003 7:34 PM from Email
    FutureMark and NVIDIA have released a joint statement on the earlier snafu concerning Nvidia bungling 3DMark03 scores:
    Futuremark Statement
    For the first time in 6 months, as a result of Futuremark's White Paper on May 23rd, 2003, Futuremark and NVIDIA have had detailed discussions regarding NVIDIA GPUs and Futuremark's 3DMark03 benchmark.
    Futuremark now has a deeper understanding of the situation and NVIDIA's optimization strategy. In the light of this, Futuremark now states that NVIDIA's driver design is an application specific optimization and not a cheat.
    The world of 3D Graphics has changed dramatically with the latest generation of highly programmable GPUs. Much like the world of CPUs, each GPU has a different architecture and a unique optimal code path. For example, Futuremark's PCMark2002 has different CPU test compilations for AMD's AthlonXP and Intel's Pentium4 CPUs.
    3DMark03 is designed as an un-optimized DirectX test and it provides performance comparisons accordingly. It does not contain manufacturer specific optimized code paths. Because all modifications that change the workload in 3DMark03 are forbidden, we were obliged to update the product to eliminate the effect of optimizations identified in different drivers so that 3DMark03 continued to produce comparable results.
    However, recent developments in the graphics industry and game development suggest that a different approach for game performance benchmarking might be needed, where manufacturer-specific code path optimization is directly in the code source. Futuremark will consider whether this approach is needed in its future benchmarks.
    NVIDIA Statement
    NVIDIA works closely with developers to optimize games for GeForceFX. These optimizations (including shader optimizations) are the result of the co-development process. This is the approach NVIDIA would have preferred also for 3DMark03.
    Joint NVIDIA-Futuremark Statement
    Both NVIDIA and Futuremark want to define clear rules with the industry about how benchmarks should be developed and how they should be used. We believe that common rules will prevent these types of unfortunate situations moving forward.
    fonte, anandtech
    Bom, eu até já sei quem vai ficar feliz com essa notícia... pra mim tanto faz...
    fui
    O mais forte do universo!
    na boa, pra mim isso é algum marketing, ou algo do tipo, ou entao a nvidia deu uma enorme quantia para a futuremark dar esta declaração..
    a gente deve sempre desconfiar de escandalos que aparecem e "desaparecem" derepente como se nada tivesse acontecido
