    NF7-S e SEUS RATIOS
    AE...
    The NF7-S BIOS version we received contained an AGP lock set at 66MHz, but we were unable to find any PCI lock set at 33MHz in this BIOS. We asked ABIT why the AGP lock was included in the NF7-S BIOS but not the PCI lock, and we were basically told that the only reason you don't see a PCI lock in the BIOS is because ABIT doesn't want users fooling around with PCI frequency, especially since it offers virtually no performance gain. We don't have any way of independently verifying ABIT's PCI lock claim ourselves, so take this piece of information as you will.
    FONTE: Anandtech
    Se o PCI eh TRavado Pq as opções de RATIO 3/3 4/4 5/5 e 6/6 ??????
    te mais
    NEO
    NEO está offline
    Membro Avatar de NEO
    Dec 2000
    Não saquei....
    Vc naum estaria falando do Ratio da memória q tem na Bios ?? =P
    Re: Não saquei....
    Originalmente enviada por NEO
    Sim
    Mas qual a diferença de 3/3 pra 6/6 ?
    te mais
    NEO
    NEO está offline
    Dec 2000
    Re: Re: Não saquei....
    Originalmente enviada por Jj - Sc
    Sim
    te mais
    Isso eh o Ratio da memória po....
    Diferença, sinceramente nenhuma... mas dá uma olhada lá na Bios mesmo q vc vai ver as diferenças conforme estiver usando(naum estou falando de benchmark, okay? ).
    Re: Re: Re: Não saquei....
    Poiseh num muda nda heuaehau...
    porem tava lendo o forun na NforceHQ e vi isso..
    http://www.nforcershq.com/forum/view...ighlight=ratio
    "200divide by 6/6 lock, ok. so 200 divide by 6 is 33.333333. 33mhz is were you want the pci locked at. so know take 33 times 6 = 200mhz ram. the ram and cpu are know synced and the pci is locked at 33.33333 which is good.
    If you set the the lock to 5/5 you have,
    200 divide by 5= 40mhz pci bus, this is overclocked. so 40 times the 5/5 lock = 200. Since the pci bus is overclocked and you want to be as close to 33mhz youd use the 6/6 lock if i understand what ive read. It doesnt matter what cpu u have its the fsb its running at."
    E agOra joSÉ ?
    ehaueahu
    aBracos
    te mais
    Sobe !
    Membro Avatar de Cara-de-pau
    Me expliquem ai esse lance de PCI/AGP travado:
    1- independente do FSB o PCI/AGP fica 33/66?
    2- TODA mobo com Nforce2 é assim?
    t+
    Jan 2001
    esse ratio eh do fsb para a ddr ...
    Vamos dizer q o seu fsb esteja a 200, suas memos sao 133, mas vc ker fazer 1 oc nas memorias, para 166 ... vc coloca o ratio em 5/6 ..
    200 (fsb) x 6/6 = 200 ddr (sync)
    200 (fsb) x 5/6 = 166 ddr
    200 (fsb) x 4/6 = 133 ddr
    200 (fsb) x 3/6 = 100 ddr
    a outra opcao eh By Sped, que vai usar o valor da ddr mesmo, sem essas contas do fsb ... eu tenho quase certeza q eh isso :P
    Originalmente enviada por insect-by
    Sim Mas na ultima bios APARECE as opções 3/3 5/5 e 6/6 ... e agora ? Nào eh a mesma coisa ?
    kwkw
    fui ligar 6/3 ... ou sei la
    pc3200 corsair
    tinha ido pra 433mhz
    e o pc não ligou.. ficou apitando.. hehe foda!
    aí deixei by fbs (400mhz)
    Re: Re: Re: Re: Não saquei....
    E agOra joSÉ ?
    ehaueahu
    aBracos
    te mais
    Já tinha te falado, esses caras ae falaram merda.
    Agora não sei porque colocaram 3/3, 4/4, 5/5 e 6/6, afinal, é a mesma coisa.
    Mas que isso é o rate da memória em relação ao FSB isso não tenho duvida. Deixa de ser teimoso!
    Flávio
