Página 1 de 6 1 2 3 ... Última
    Membro Avatar de Gung@
    Gunga
    Gunga
    Aliás, o link da versao internacional está quebrado
    http://www2.ati.com/wxp-w2k-radeon-7...5m-009438c.exe
    dcli 101
    baixando
    já vou fazer uns testes aqui e posto os resultados
    Chandler
    esse ja eh a versao final?
    Membro Avatar de NoOne
    Downloading...
    dcli 101
    Aqui fico na mesma..
    Quem tem 9500 diz aí se melhorou
    Driver Contents:
    The CATALYST™ software suite 3.5 contains the following:
    • RADEON™ display driver 7.90
    • MultimediaCenter™ 8.5
    • HydraVision™ 3.21
    • Remote Wonder1.5
    Operating systems supported:
    The latest version of the CATALYST™ software suite is designed to support the following Microsoft Windows platforms:
    • Windows XP
    • Windows 2000
    • Windows Millennium Edition (ME)
    • Windows 98/98SE through the ME driver
    Performance Improvements:
    As with most CATALYST™ releases, the performance has increased in numerous situations. Here are some examples observed in CATALYST™ version 3.5.
    Improvements in the ATI OpenGL drivers have experienced performance gains such as:
    • GL Excess performance improves 12-14% on the RADEON™ 9700 PRO and 9800 PRO. Modest benefits are noticed on our other graphic products as well
    • Unigraphics performance (ViewPerf Ugs-03) improves 27% on the RADEON™ 9800 PRO, 52% on the RADEON™ 9700 PRO, and 79% on the RADEON™ 9500 PRO
    • Data Explorer performance (ViewPerf DV-08) improves 9% on RADEON™ 9800 PRO, and the RADEON™9700 PRO. The RADEON™ 9500 PRO improves by 14.5%
    Some compatibility/stability fixes include:
    • Playing the game Nascar Racing 2003 in OpenGL mode no longer results in the display going black.
    • Playing the game Serious Sam 2 with the display resolution set to 1024x768 32bpp no longer results in the wrong OpenGL renderer being listed when setting the graphics to OpenGL.
    • Enabling Pixel Shaders in the game Asheron's Call 2 no longer results in display corruption appearing as the game is played.
    • Playing the game Project IGI2: Covert Strike with a RADEON(tm) 9700 series card installed in the system results in the ground terrain disappearing and re-appearing as the character is moved.
    •Running the ATI Tranquility screen saver found at DriverHeaven, on an ATI RADEON(tm) 9000 series card, no longer results in the system not responding under Windows XP.
    Nossa, o que eles consertaram de coisas!!
    Membro Avatar de NIex
    apl525 here
    ATi Catalyst v3.5 para Windows 2k/XP (6.48 Mb) / Direto da Adrenaline
    http://www.adrenaline.com.br/downloa...09437c-efg.exe
    ATi Catalyst v3.5 para Windows 9x/ME (7.03 Mb) / Direto da Adrenaline
    ATi Catalyst v3.5 Control Panel (4.95 Mb) / Direto da Adrenaline
    Como anda esse 3.5 no CS hein, alguem pode me dizer?????
    Aqui tive problema com o CS..
    Ele diz que o MODO NÂO É SUPORTADO, no caso o OpenGL..
    Estranho
    vo testar mais umas coisas!
    NoOne
    muito massa 8400 pontos numa 9100 250/200
    antes meu record era 8376 com catalixo 3.1
    USUARIOS DE RADEON 8500/9100
    Quem tiver problema com OPENGL Games pode substituir o ATIOGLXX.DLL pelo arquivo do BETA 5 que funciona..
    NOOne
    dcli 101
    Fiquei com preguiça de instalar o CS e instalei só o HL - Entrei em OpenGL com Aniso16x e AA4x e fico normal, sem bug chato (Aqui nunca teve tb, nem com o 3.3).
    May 1999
    só rindo mesmo, pq eu não acredito que acabei de instalar o Cat3.5 e o meu opengl não funciona... comédia.
    xô fazer oque NoOne falou.
    May 1999
    Desci a lenha neles.... VTNMDODCD....
    Quem quiser meter a boca...
    http://apps.ati.com/driverfeedback/index.asp
    Vou tirar esse 3.5 e voltar pro 3.4
    VTNMDODCD = vai toma no meio do olho do ** deles.
    hahahaahAhAHAHAHAHAHAHAHAHAH
    ESSA ATI EH COMÉDIA, PUTA QUE PARIU...
    A Nvidia pode ser uma merda em tudo os aspectos, mas em questão de Driver ela simplesmente humilha ATI..
    Baxei esse catalixo novo mas nem vo arrisca instalar.. por enquanto o 3.4 ta guentando bem..
    Cade? posta ai os cara que fala q ATI nunca deu bug.. AHWhawawha
    Membro Avatar de Fabdall
    Aqui não fedeu e nem cheirou!!
    nossa aqui instalei e melhorou.
    no cs a melhora foi gigante.
    Membro Avatar de edsonmassao
    +15 anos de hardMOB
    melhorou poka coisa no 3dmark2k1...mas é pq tb tava usando oemga driver antes...
    pow, num tenho nenhum jogo q usa opengl...procurei na net algum teste disso mas naum achei, alguém aí sabe como posso testar meu opengl?
    depois q o noone e o worlock postaram fiquei preocupado
    Originalmente enviada por edsonmassao
    Pega o Soldier of Fortune 2 ou Medal of Honor. Todos esses jogos rodam em OpenGL.
    Instala o HL e testa o OpenGL..
    Feb 1999
    Originalmente enviada por BlackOmega
    Cara, na boa, esse tipo de post só incita flame wars. Pega leve aí.
    dcli 101
    Então, aqui tá normal, testei com HL e rodo normal.
    rodei DOD (ogl) americas army, BF1942 e UT2003......
    tudo rodando filé e sem problemas.....
    assim como rodava com o 3.4
    Zed
    Zed está offline
    Membro Avatar de Zed
    WAT?!?! WTF !?!?!
    como q troca o opengl, me desculpem a newbice !
