    Kx7-raid 333r X Athon 2.4+ Tbred
    Cara nao estou conseguindo colocar meu provessador novo para rodas na minha kx7. Ja fiz eu acho de tudo e nao vai. Toda vez que eu pego e mudo o clock e mando salvar a configuracao a placa nao inicia, como nao tivesse reconhecendo o processador. A bios que tenho aqui e a mais nova a B6 que tem no site da ABIT, por favor como faço pra essa beleza rodar meu processador em 2.4+ em vez de 1,8 como ele esta reconhecendo???
    SiSoftware Sandra
    Computer System
    User Name : cristiano
    Logon Domain : JASONN
    Processor(s)
    Model : AMD Athlon(tm) XP 1800+
    Speed : 1.51GHz
    Model Number : 1800 (estimated)
    Performance Rating : PR2184 (estimated)
    Type : Standard
    L2 On-board Cache : 256kB ECC synchronous write-back
    System Mainboard
    Bus(es) : ISA AGP PCI IMB USB SMBus/i2c
    MP Support : No
    System BIOS : Phoenix Technologies, LTD 6.00 PG
    System Mainboard : ABIT <http://www.abit.com.tw> VT8367-8233A (KX7-333[R])
    System Chipset : Abit Computer Corp VT8366/A,VT8367 Apollo KT266/A,KT333 CPU to PCI Bridge
    Front Side Bus Speed : 2x 100MHz (200MHz data rate)
    Installed Memory : 512MB DDR-SDRAM
    Memory Bus Speed : 2x 167MHz (334MHz data rate)
    Video System
    Monitor/Panel : Philips 107S (107S2)
    Adapter : RADEON 9600 SERIES
    Adapter : RADEON 9600 SERIES - Secondary
    Physical Storage Devices
    Removable Drive : Unidade de disquete
    Disk Drive : Maxtor 6Y120L0 (114.5GB)
    CD-ROM/DVD : SAMSUNG CD-R/RW SW-248F (CD 48X Rd, 4X Wr)
    CD-ROM/DVD : Generic STEALTH DVD SCSI CdRom Device (CD 32X Rd) (DVD 4X Rd)
    Logical Storage Devices
    1.44MB 3.5" (A : N/A
    Hard Disk (C : 15.0GB (6.0GB, 40% Free) (NTFS)
    Hard Disk (D : 99.5GB (395MB, 0% Free) (NTFS)
    CD-ROM/DVD (E : 1MB (0MB, 0% Free) (CDFS)
    CD-ROM/DVD (F : N/A
    CD-ROM/DVD (G : N/A
    CD-ROM/DVD (H : N/A
    CD-ROM/DVD (I : N/A
    Peripherals
    Serial/Parallel Port(s) : 2 COM / 1 LPT
    USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller
    USB Controller/Hub : USB Root Hub
    Keyboard : Teclado padrão com 101/102 teclas ou Microsoft Natural PS/2 Keyboard
    Mouse : Mouse compatível com HID
    Human Interface : Dispositivo de interface humana USB
    MultiMedia Device(s)
    Device : Creative SB Live! series
    Device : Creative Game Port
    Operating System(s)
    Windows System : Microsoft Windows XP Professional Ver 5.01.2600 Service Pack 1
    Network Adapter(s)
    Networking Installed : Yes
    Adapter : 3Com EtherLink XL 10/100 PCI For Complete PC Management NIC (3C905C-TX) #2
    Adapter : Realtek RTL8139 Family PCI Fast Ethernet NIC
    SiSoftware Sandra
    Computer System
    Manufacturer : VIA Technologies, Inc.
    Model : VT8367-8233A
    Unique ID : FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
    System Mainboard
    Manufacturer : ABIT <http://www.abit.com.tw>
    MP Support : No
    Model : VT8367-8233A (KX7-333[R])
    Version : v1.0~
    BIOS ID : 08/22/2002-VT8367-8233A-6A6LVA1BC-B6
    System Chipset : VIA KT266/A,KT333 Chipset
    System Memory Controller
    Error Correction Capability : None
    Number of Memory Slots : 3
    Maximum Installable Memory : 768MB
    Bank0/1 - A0 : Empty
    Bank2/3 - A1 : Empty
    Bank4/5 - A2 : Empty
    System Chipset
    Model : Abit Computer Corp VT8366/A,VT8367 Apollo KT266/A,KT333 CPU to PCI Bridge
    Max FSB Speed / Max Memory Speed : 2x 166MHz / 2x 166MHz
    In Order Queue Depth : 4 req(s)
    Chipset Hub Interface
    Type : V-Link
    Width : 8-bit
    Full Duplex : Yes
    Multiplier : 1x
    Speed : 4x 66MHz (264MHz data rate)
    Down / Up In Order Queue Depth : 9 / 9 req(s)
    APIC 1
    Version : 0.02
    Speed : 17MHz
    Multiplier : 1/2x
    Max Interrupts : 24
    IRQ Handler Engaged : Yes
    Enhanced Support : No
    Logical/Chipset Memory Banks
    Bank 6 Setting : 256MB DDR-SDRAM 8-1-1-1R 4-1-1-1W 2.5-3-3CL 2CMD
    Bank 7 Setting : 256MB DDR-SDRAM 8-1-1-1R 4-1-1-1W 2.5-3-3CL 2CMD
    Bank Interleave : 4-way
    Multiplier : 1.66x
    Power Down Mode : No
    Fixed Hole Present : No
    Memory Module(s)
    Memory Module 4 : SpecTek 0F00EEEF 512MB 16x(32Mx8) DDR-SDRAM PC2700U-2533-700 (CL2.5 upto 167MHz) (CL2 upto 100MHz)
    System Clock Generator
    Model : Realtek RTM560-266R
    Software Programmable : Yes
    Read-Back Support : Yes
    Environment Monitor 1
    Model : Winbond W83697HF ISA
    Version : 6.00
    Mainboard Specific Support : No
    Temperature Sensor(s)
    Board Temperature : 38.0°C / 100.4°F
    CPU Temperature : 50.5°C / 122.9°F
    Cooling Device(s)
    Auto Fan Speed Control : No
    CPU Fan Speed : 4441rpm
    Voltage Sensor(s)
    CPU Core Voltage : 1.70V
    +3.3V Voltage : 3.46V
    +5V Voltage : 4.84V
    +12V Voltage : 12.22V
    Standby Voltage : 4.87V
    Battery Voltage : 2.98V
    AGP Bus
    Version : 2.00
    Speed : 66MHz
    Current Data Transfer Rate : 4x 66MHz (264MHz data rate)
    Side Band Enabled : Yes
    Fast-Writes Enabled : No
    Aperture Size : 64MB
    PCI Bus(es)
    Version : 2.10
    No Bridges : 1
    PCI Bus 0 : PCI (33MHz)
    Multiplier : 1/3x
    LPC Hub Controller 1
    Model : VIA Technologies Inc VT8233A PCI to ISA Bridge
    ACPI PM Enabled : Yes
    Random Number Generator Enabled : No
    Multiplier : 1/4x
    Speed : 8MHz
    DMA Multiplier : 1/2x
    DMA Speed : 4MHz
    USB Controller 1
    Model : Abit Computer Corp VT8233A USB Controller
    Version : 1.10
    UHCI Interface : Yes
    Channels : 2
    Speed : 48MHz
    Legacy Emulation Enabled : No
    USB Controller 2
    Version : 1.10
    Channels : 2
    Speed : 48MHz
    System SMBus Controller 1
    Model : VIA VT823x SMBus
    Speed : 16kHz
    Expansion Slot(s)
    PCI0 (1h) : PCI 32-bit 5V PME FullLength Available (VIA Technologies Inc VT8366/A,VT8367 Apollo KT266/A,KT333 PCI to AGP Bridge)
    PCI1 (2h) : PCI 32-bit 5V PME FullLength Available
    PCI2 (3h) : PCI 32-bit 5V PME FullLength InUse
    PCI3 (4h) : PCI 32-bit 5V PME FullLength InUse
    AGP (8h) : AGP 32-bit 5V FullLength Available (ATI Technologies Unknown (4150))
    Port Connector(s)
    PRIMARY IDE : None - ATA / None
    SECONDARY IDE : None - ATA / None
    FDD : 8251 FIFO Compatible - Floppy / None
    COM1 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
    COM2 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
    LPT1 : Parallel Port ECP/EPP - DB25 pin female / DB25 pin female
    Keyboard : Keyboard Port - PS/2 / PS/2
    PS/2 Mouse : Mouse Port - PS/2 / PS/2
    USB : USB - None / None
    Performance Tips
    Notice 224 : SMBIOS/DMI information may be inaccurate.
    Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
    Warning 2545 : Large memory modules should be Registered/Buffered.
    Tip 2546 : Large memory modules should be ECC/Parity.
    Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
    CARAS ALGUEM ME AJUDA AEEEEEEEEE
    Velhos fiz testes como me pediram via email, e descobri o problema, de alguma forma a minha bios so esta reconhecendo o CPU FSB CLOCK DE 100 E NAO 133 E 166 como deveria.
    como ficou:
    CPU FSB CLOCK : 100
    RATION FSB:AGP:PCI 5:2:1
    MULTIPLIER FACTOR X13
    CORE VOLTAGE 1.70V
    assim o que aconteceu recocheceu o processador como 1500MHZ e nao 1.5+ certo. no Windows XP esta reconhecendo ele como 1.8+.
    O modelo do meu processador e AXDA2400DKV3C
    AIUCA 0310XPAC
    a memoria esta funcionando em normal e nao em FAST.
    A LATENCY DRAM CAS esta em 2.5
    DRAM ACESS 3T
    O meu processador e cor terra e nao verde ok?? como me perguntaram.
    Caras por favor, quem tem esperiencia ai na onda por favor da uma ideia, pois nao consigo faze-lo passar de 1.8 acima trava mesmo. Agora estranho que tenho aqui um prcessador de 1.8+ e ja coloquei ele aqui em 2000+ e rolou. E ai quem pode por favor me ajudar????
    Velhos como farei para resolver isso. meu email é
    email: [email protected]
    MSN: [email protected]
    ICQ: 114268108
    A a minha memoria e a:
    Memory Module(s)
    Fácil coloca fsb em 133
    onde eu mudaria essa opcao, pois nao muda pra nada, se eu colocar o se eu colocar o CPU FSB CLOCK em 133 ou 166 o pc trava, ele nao inicia. Ele so inicia se estiver em 100 no maximo em 110 como testei.
    ve so, vi que minha CPU FSB nao esta passando de 100, ela nao deveria ser 133 ou 166?? diz ai?? isso aque vc falou eu ja fiz, mais quando vou no default de 2100 que tem la trava o pc, descobri que ele trava quando esta com o CPU FSB CLOCK em 133. e ai o que me aconselha?? minha memoria e a Memory Module(s)
    Memory Module 4 : SpecTek 0F00EEEF 512MB 16x(32Mx8) DDR-SDRAM PC2700U-2533-700 (CL2.5 upto 167MHz) (CL2 upto 100MHz) ela e generica, sera que isso pode estar influindo??? vale ae
