    DESTRAVANDO um XP em 5 segundos?
    The mainboard in question is an ASUS A7N8X but it could be any other mainboard as well as long as the orientation of the socket is matched with the golden triangle at the CPU corner. The red line connects the two pins that are usually shorted with the "wiretrick". The same pins connect in the Socket to the pins that are sticking out in the back of the mainboard inside the solder points. We actually ohmed it out to be on the safe side and there is no remapping involved, not that we expected one either.
    Alguém já tentou fazer esse mod?
    EDITEI ... pois vi que não rola com XP Palomino!
    PS: desculpa se for flood!
