    May 1999
    Faça sua Dragon Plus 266A aceitar TBred !!
    Não sei se já postaram isso mais lá vai.
    Um maluco sei lá de onde consegue isso e disse que é fácil, outros já fizeram e deu certo, estou com uma desta excelente placa parada aqui e vou fazer o que o gringo disse.
    http://groups.google.com/groups?dq=&...3cd04d9e92b778
    Não deixem de ver as fotos que tem aqui e os comentários..
    http://www.forumpcs.com.br/viewtopic...r=asc&start=10
    Yes, removing cap C130 is the part that will allow the newer Tbred chips
    to function properly. Also you need to add a cap (1000mfd-10v) to the
    vacant location ELC28. I have performed these mods on many D+ boards and all
    have worked fine.
    Andy
    ELC28 is located at the right rear corner of DIMM socket #3 next to the
    right hand locking clip. There is a white outline on the topside of the
    board labeled ELC28.
    Must use 2BA7 or the cpu will not be IDed correctly. Also, after every cpu
    change, you must clear the cmos so the bios can pickup the cpuid string
    from the new cpu chip, otherwise the board will not even post.
    I use a 2600+/266 Tbred B in 1 of my units at home. Thats as fast as possible
    with the D+ board; the 2600+ is the last 266fsb cpu chip AMD will offer.
    First, locate ELC28 as C130 is nearby. Just about in line with cap
    ELC28 and about 1 inch further back towards the PS2 connectors, you will
    find 1 of the 4 holes used to mount a large hs/fan unit. This is on the
    right hand side of the cpu socket. About 1/2 inch in front of and directly
    in the centerline of this mounting hole is where C130 is mounted. It has
    only 2 surface mounted points. The next component in front of C130 is a
    transistor which has 3 solder mounting points, 2 on the left on 1 on the
    right. To the left of C130 is an eight contact resistor network. All the
    left-right designations assume the board is in hand and is positioned so
    the drive ribbon cable connectors are closest to you and all the onboard
    O/I ports are furthest away from you. These parts are very small so a
    magnifying glass helps.
    Digi-Key Electronics
    1-800-344-4539
    Part # P10228-ND Panasonic 1500mfd-10v FC 105c price is about $1.00
    This cap fits D+ board perfectly and the added mfd may help in high speed
    overclocking.
    Apr 2000
    Ate que enfim... eu era revoltado com minha dragon por causa disso.
    Vo ver se faco isso... vo falar com um amigo meu tecnico em eletronica pra fazer tudo certinho...
    noticia antiga
    mas eh bom relembrar
    c kiserem da search no forum q acha melhor explicado
    May 1999
    Up que é interessante o que nego descobre !!!
