Sobre problemas na inicializaçao do Minecraft
    Padrão Sobre problemas na inicializaçao do Minecraft
    Pois entao amigo,estava um tempo sem jogar minecraft e resolvi jogar hoje,pra minha surpresa surgiu um erro bizarro:
    # A fatal error has been detected by the Java Runtime Environment:
    # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x4ccc374d, pid=3516, tid=7516
    # JRE version: 6.0_30-b12
    # Java VM: Java HotSpot(TM) Client VM (20.5-b03 mixed mode windows-x86 )
    # Problematic frame:
    # C [ig4dev32.dll+0x374d]
    # If you would like to submit a bug report, please visit:
    # http://java.sun.com/webapps/bugreport/crash.jsp
    # The crash happened outside the Java Virtual Machine in native code.
    # See problematic frame for where to report the bug.
    --------------- T H R E A D ---------------
    Current thread (0x4c06f800): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=7516, stack(0x4ac80000,0x4acd0000)]
    siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
    Registers:
    EAX=0x00000000, EBX=0x00000000, ECX=0x00000000, EDX=0x4accf5ac
    ESP=0x4accf598, EBP=0x001c3d40, ESI=0x4c590e14, EDI=0x4accf5e4
    EIP=0x4ccc374d, EFLAGS=0x00010246
    Top of Stack: (sp=0x4accf598)
    0x4accf598: 4accf5ac 4c540048 4c590e14 4c540048
    0x4accf5a8: 001bc768 4000ff80 00000000 00000000
    0x4accf5b8: 00000000 00000000 00000000 00000001
    0x4accf5c8: 00000000 00000000 00000000 00000000
    0x4accf5d8: 00000000 00000000 00000000 4cccb4dc
    0x4accf5e8: 00000dbc 4c590e14 b8011973 4c545ff8
    0x4accf5f8: 4cb2b104 4cb496e4 4c9322d3 b8011973
    0x4accf608: 4c591820 001ae8a8 4accf764 b8011973
    Instructions: (pc=0x4ccc374d)
    0x4ccc372d: 03 00 00 8d 54 24 10 52 89 5c 24 1c 89 5c 24 24
    0x4ccc373d: 89 5c 24 28 89 5c 24 18 c7 44 24 2c 01 00 00 00
    0x4ccc374d: 8b 08 50 33 f6 ff 51 4c 85 c0 0f 85 bd 00 00 00
    0x4ccc375d: 6a 34 53 ff 15 40 90 e9 4c 3b c3 8b 4c 24 54 74
    Register to memory mapping:
    EAX=0x00000000 is an unknown value
    EBX=0x00000000 is an unknown value
    ECX=0x00000000 is an unknown value
    EDX=0x4accf5ac is pointing into the stack for thread: 0x4c06f800
    ESP=0x4accf598 is pointing into the stack for thread: 0x4c06f800
    EBP=0x001c3d40 is an unknown value
    ESI=0x4c590e14 is an unknown value
    EDI=0x4accf5e4 is pointing into the stack for thread: 0x4c06f800
    Stack: [0x4ac80000,0x4acd0000], sp=0x4accf598, free space=317k
    Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
    Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
    j org.lwjgl.opengl.WindowsContextImplementation.nCre ate(Ljava/nio/ByteBuffer;Ljava/nio/IntBuffer;Ljava/nio/ByteBufferLjava/nio/ByteBuffer;+0
    j org.lwjgl.opengl.WindowsContextImplementation.crea te(Lorg/lwjgl/opengl/PeerInfo;Ljava/nio/IntBuffer;Ljava/nio/ByteBufferLjava/nio/ByteBuffer;+10
    j org.lwjgl.opengl.Context.<init>(Lorg/lwjgl/opengl/PeerInfo;Lorg/lwjgl/opengl/ContextAttribs;Lorg/lwjgl/opengl/ContextV+104
    j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/Drawable;Lorg/lwjgl/opengl/ContextAttribsV+88
    j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormatV+9
    j org.lwjgl.opengl.Display.create()V+13
    j net.minecraft.client.Minecraft.a()V+172
    j net.minecraft.client.Minecraft.run()V+6
    j java.lang.Thread.run()V+11
    v ~StubRoutines::call_stub
    --------------- P R O C E S S ---------------
    Java Threads: ( => current thread )
    =>0x4c06f800 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=7516, stack(0x4ac80000,0x4acd0000)]
    0x4c06f400 JavaThread "Timer hack thread" daemon [_thread_blocked, id=7076, stack(0x4ac30000,0x4ac80000)]
    0x4a68e800 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=392, stack(0x4ab90000,0x4abe0000)]
    0x4a74f800 JavaThread "TimerQueue" daemon [_thread_blocked, id=7884, stack(0x4ab40000,0x4ab90000)]
    0x02211c00 JavaThread "DestroyJavaVM" [_thread_blocked, id=7848, stack(0x00110000,0x00160000)]
    0x4a646400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=6932, stack(0x4af60000,0x4afb0000)]
    0x4a61d000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=7804, stack(0x4aa10000,0x4aa60000)]
    0x4a61c800 JavaThread "AWT-Shutdown" [_thread_blocked, id=7108, stack(0x4a890000,0x4a8e0000)]
    0x4a61a000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=7256, stack(0x4a840000,0x4a890000)]
    0x022cdc00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=7236, stack(0x4a4e0000,0x4a530000)]
    0x022c3800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=6172, stack(0x4a490000,0x4a4e0000)]
    0x022be000 JavaThread "Attach Listener" daemon [_thread_blocked, id=7752, stack(0x01bb0000,0x01c00000)]
    0x022bd400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3112, stack(0x01b60000,0x01bb0000)]
    0x0228fc00 JavaThread "Finalizer" daemon [_thread_blocked, id=6892, stack(0x01b10000,0x01b60000)]
    0x0228b000 JavaThread "Reference Handler" daemon [_thread_blocked, id=6280, stack(0x01970000,0x019c0000)]
    Other Threads:
    0x02286c00 VMThread [stack: 0x018d0000,0x01920000] [id=6616]
    0x022d6800 WatcherThread [stack: 0x4a530000,0x4a580000] [id=7344]
    VM state:not at safepoint (normal execution)
    VM Mutex/Monitor currently owned by a thread: None
    Heap
    def new generation total 157248K, used 129206K [0x04300000, 0x0eda0000, 0x19850000)
    eden space 139776K, 92% used [0x04300000, 0x0c12d918, 0x0cb80000)
    from space 17472K, 0% used [0x0cb80000, 0x0cb80000, 0x0dc90000)
    to space 17472K, 0% used [0x0dc90000, 0x0dc90000, 0x0eda0000)
    tenured generation total 349568K, used 0K [0x19850000, 0x2edb0000, 0x44300000)
    the space 349568K, 0% used [0x19850000, 0x19850000, 0x19850200, 0x2edb0000)
    compacting perm gen total 13824K, used 13668K [0x44300000, 0x45080000, 0x48300000)
    the space 13824K, 98% used [0x44300000, 0x450592d0, 0x45059400, 0x45080000)
    No shared spaces configured.
    Code Cache [0x02300000, 0x02528000, 0x04300000)
    total_blobs=1340 nmethods=1099 adapters=175 free_code_cache=31320064 largest_free_block=192
    Dynamic libraries:
    0x00400000 - 0x00425000 C:\Program Files\Java\jre6\bin\javaw.exe
    0x76eb0000 - 0x76fd8000 C:\Windows\system32\ntdll.dll
    0x75900000 - 0x759dc000 C:\Windows\system32\kernel32.dll
    0x753e0000 - 0x75414000 C:\Program Files\AVAST Software\Avast\snxhk.dll
    0x77010000 - 0x770d6000 C:\Windows\system32\ADVAPI32.dll
    0x75ca0000 - 0x75d63000 C:\Windows\system32\RPCRT4.dll
    0x759e0000 - 0x75a7d000 C:\Windows\system32\USER32.dll
    0x769d0000 - 0x76a1b000 C:\Windows\system32\GDI32.dll
    0x76b60000 - 0x76b7e000 C:\Windows\system32\IMM32.DLL
    0x76c10000 - 0x76cd8000 C:\Windows\system32\MSCTF.dll
    0x75d70000 - 0x75e1a000 C:\Windows\system32\msvcrt.dll
    0x77000000 - 0x77009000 C:\Windows\system32\LPK.DLL
    0x76d40000 - 0x76dbd000 C:\Windows\system32\USP10.dll
    0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll
    0x6d7f0000 - 0x6da9f000 C:\Program Files\Java\jre6\bin\client\jvm.dll
    0x73ed0000 - 0x73f02000 C:\Windows\system32\WINMM.dll
    0x75a80000 - 0x75bc5000 C:\Windows\system32\ole32.dll
    0x76b80000 - 0x76c0d000 C:\Windows\system32\OLEAUT32.dll
    0x73e90000 - 0x73ece000 C:\Windows\system32\OLEACC.dll
    0x752c0000 - 0x752ec000 C:\Windows\system32\apphelp.dll
    0x6d7a0000 - 0x6d7ac000 C:\Program Files\Java\jre6\bin\verify.dll
    0x6d320000 - 0x6d33f000 C:\Program Files\Java\jre6\bin\java.dll
    0x6d7e0000 - 0x6d7ef000 C:\Program Files\Java\jre6\bin\zip.dll
    0x6d000000 - 0x6d14c000 C:\Program Files\Java\jre6\bin\awt.dll
    0x6f630000 - 0x6f672000 C:\Windows\system32\WINSPOOL.DRV
    0x74260000 - 0x743fe000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb7 2f2a088b0ed3\COMCTL32.dll
    0x76ce0000 - 0x76d39000 C:\Windows\system32\SHLWAPI.dll
    0x729e0000 - 0x729ec000 C:\Windows\system32\DWMAPI.DLL
    0x74560000 - 0x7459f000 C:\Windows\system32\uxtheme.dll
    0x75eb0000 - 0x769c1000 C:\Windows\system32\shell32.dll
    0x6d230000 - 0x6d27f000 C:\Program Files\Java\jre6\bin\fontmanager.dll
    0x6d600000 - 0x6d613000 C:\Program Files\Java\jre6\bin\net.dll
    0x758d0000 - 0x758fd000 C:\Windows\system32\WS2_32.dll
    0x76fe0000 - 0x76fe6000 C:\Windows\system32\NSI.dll
    0x74b30000 - 0x74b6b000 C:\Windows\system32\mswsock.dll
    0x74b90000 - 0x74b95000 C:\Windows\System32\wship6.dll
    0x6d620000 - 0x6d629000 C:\Program Files\Java\jre6\bin\nio.dll
    0x747f0000 - 0x747f5000 C:\Windows\System32\wshtcpip.dll
    0x73dc0000 - 0x73dcf000 C:\Windows\system32\NLAapi.dll
    0x74da0000 - 0x74db9000 C:\Windows\system32\IPHLPAPI.DLL
    0x74d60000 - 0x74d95000 C:\Windows\system32\dhcpcsvc.DLL
    0x752f0000 - 0x7531c000 C:\Windows\system32\DNSAPI.dll
    0x753a0000 - 0x753b4000 C:\Windows\system32\Secur32.dll
    0x74d50000 - 0x74d57000 C:\Windows\system32\WINNSI.DLL
    0x74d20000 - 0x74d42000 C:\Windows\system32\dhcpcsvc6.DLL
    0x71f80000 - 0x71f8f000 C:\Windows\system32\napinsp.dll
    0x71f00000 - 0x71f12000 C:\Windows\system32\pnrpnsp.dll
    0x71f70000 - 0x71f78000 C:\Windows\System32\winrnr.dll
    0x75c50000 - 0x75c99000 C:\Windows\system32\WLDAP32.dll
    0x75540000 - 0x75547000 C:\Windows\system32\PSAPI.DLL
    0x72940000 - 0x72946000 C:\Windows\system32\rasadhlp.dll
    0x748b0000 - 0x748eb000 C:\Windows\system32\rsaenh.dll
    0x753c0000 - 0x753de000 C:\Windows\system32\USERENV.dll
    0x6d780000 - 0x6d788000 C:\Program Files\Java\jre6\bin\sunmscapi.dll
    0x74e90000 - 0x74f82000 C:\Windows\system32\CRYPT32.dll
    0x75040000 - 0x75052000 C:\Windows\system32\MSASN1.dll
    0x4c4d0000 - 0x4c53b000 C:\Users\extra\AppData\Roaming\.minecraft\bin\nati ves\lwjgl.dll
    0x65fd0000 - 0x6609b000 C:\Windows\system32\OPENGL32.dll
    0x6acc0000 - 0x6ace3000 C:\Windows\system32\GLU32.dll
    0x68fe0000 - 0x690c5000 C:\Windows\system32\DDRAW.dll
    0x73910000 - 0x73916000 C:\Windows\system32\DCIMAN32.dll
    0x75550000 - 0x756da000 C:\Windows\system32\SETUPAPI.dll
    0x74ba0000 - 0x74ba8000 C:\Windows\system32\VERSION.dll
    0x6d350000 - 0x6d356000 C:\Program Files\Java\jre6\bin\jawt.dll
    0x4c910000 - 0x4cb63000 C:\Windows\system32\ig4icd32.dll
    0x4ccc0000 - 0x4cedc000 C:\Windows\system32\ig4dev32.dll
    VM Arguments:
    jvm_args: -Xms512m -Xmx1024m
    java_command: C:\Users\extra\Desktop\Minecraft.exe
    Launcher Type: SUN_STANDARD
    Environment Variables:
    PATH=C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\sys tem32\wbem;C:\hp\bin\Python;C:\Program Files\Windows Live\Shared;C:\Windows\System32\WindowsPowerShell\ v1.0\;C:\Program Files\Java\jre6\bin
    USERNAME=extra
    OS=Windows_NT
    PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
    --------------- S Y S T E M ---------------
    OS: Windows Vista Build 6002 Service Pack 2
    CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 11, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
    Memory: 4k page, physical 2085328k(424652k free), swap 4415660k(554628k free)
    vm_info: Java HotSpot(TM) Client VM (20.5-b03) for windows-x86 JRE (1.6.0_30-b12), built on Nov 10 2011 01:51:00 by "java_re" with MS VC++ 7.1 (VS2003)
    time: Tue Dec 20 17:21:02 2011
    elapsed time: 65 seconds"
    E nao esta chegando nem na interface do jogo,ja tentei excluir a pasta bin e dar force update,e nada,ja exclui a pasta .minecraft e reinstalei o jogo,e nada,sempre antes de entrar na interface a tela fica preta,o jogo fecha e aparece um log de erro em arquivo de texto no meu dektop.
    Reparei que quando ele trava na instalaçao ele nao cria o restante das pastas a nao ser a pasta bin,vi isso quando fui na pasta .minecraft apos o erro na instalaçao.E quando tento jogar pelo meu navegador doz que falta um determinado plugin que eu desconheço qual seja.
    Porfavor,ajudem um desesperado.
    Obrigado.
    Com amor,Eminqua (a.k.a sinceeminqua)
  1. [AJUDA] Problemas no Minecraft
    Por Unfaithfull em Jogos PC
    Resp: 1
    Última mensagem: 03-09-2011, 21:05
  2. Problemas de inicialização
    Por awarken em hardWHAT!!?
    Resp: 0
    Última mensagem: 01-10-2004, 14:55
  3. Problemas com a inicialização do pc
    Por RYUDO em hardWHAT!!?
    Resp: 5
    Última mensagem: 17-09-2003, 7:16
  4. problemas na inicialização,,,
    Por Terry Bogard em softWHERE!!?
    Resp: 0
    Última mensagem: 20-07-2003, 13:04
  5. Problemas na Inicialização, Help !!!!
    Por Death.&.Thrash em Jogos PC
    Resp: 3
    Última mensagem: 03-07-2003, 4:08
