Página 5 de 7 PrimeiraPrimeira ... 456 ... ÚltimaÚltima
GTA V em low config
  1. #101
    A graça do GTA V de pc é poder jogar @60fps e tem gente que prefere aumentar os níveis de detalhe e jogar travando?
    Prefiro diminuir o que for necessário para jogar com vsync ligado com 60fps fixos.
    To com 1 Phenom II X3 720 4GB 800 GTX4601GB e roda bem até, o problema são os crashes e bsods que só acontece com este jogo, alguma solução? É versão jack atualizada
    Benchmark:
    Frames Per Second (Higher is better) Min, Max, Avg
    Pass 0, 25.539591, 55.916771, 43.375511
    Pass 1, 37.270714, 74.762115, 58.629936
    Pass 2, 28.223404, 79.129265, 54.431145
    Pass 3, 37.838131, 61.492649, 51.097832
    Pass 4, 4.518466, 104.048592, 51.805683
    Time in milliseconds(ms). (Lower is better). Min, Max, Avg
    Pass 0, 17.883722, 39.154896, 23.054483
    Pass 1, 13.375758, 26.830717, 17.056133
    Pass 2, 12.637549, 35.431587, 18.371836
    Pass 3, 16.262106, 26.428368, 19.570303
    Pass 4, 9.610894, 221.314041, 19.302902
    Frames under 16ms (for 60fps):
    Pass 0: 0/406 frames (0.00%)
    Pass 1: 169/549 frames (30.78%)
    Pass 2: 88/503 frames (17.50%)
    Pass 3: 0/479 frames (0.00%)
    Pass 4: 1505/5435 frames (27.69%)
    Frames under 33ms (for 30fps):
    Pass 0: 404/406 frames (99.51%)
    Pass 1: 549/549 frames (100.00%)
    Pass 2: 501/503 frames (99.60%)
    Pass 3: 479/479 frames (100.00%)
    Pass 4: 4901/5435 frames (90.17%)
    Percentiles in ms for pass 0
    50%, 23.00
    75%, 24.00
    80%, 25.00
    85%, 25.00
    90%, 26.00
    91%, 26.00
    92%, 26.00
    93%, 27.00
    94%, 27.00
    95%, 27.00
    96%, 28.00
    97%, 29.00
    98%, 29.00
    99%, 31.00
    Percentiles in ms for pass 1
    50%, 17.00
    75%, 18.00
    80%, 18.00
    85%, 19.00
    90%, 19.00
    91%, 19.00
    92%, 20.00
    93%, 20.00
    94%, 20.00
    95%, 20.00
    96%, 20.00
    97%, 21.00
    98%, 21.00
    99%, 23.00
    Percentiles in ms for pass 2
    50%, 18.00
    75%, 20.00
    80%, 21.00
    85%, 21.00
    90%, 22.00
    91%, 22.00
    92%, 22.00
    93%, 22.00
    94%, 23.00
    95%, 23.00
    96%, 24.00
    97%, 25.00
    98%, 26.00
    99%, 28.00
    Percentiles in ms for pass 3
    50%, 19.00
    75%, 21.00
    80%, 21.00
    85%, 21.00
    90%, 22.00
    91%, 22.00
    92%, 22.00
    93%, 23.00
    94%, 23.00
    95%, 23.00
    96%, 23.00
    97%, 24.00
    98%, 24.00
    99%, 25.00
    Percentiles in ms for pass 4
    50%, 18.00
    75%, 26.00
    80%, 29.00
    85%, 31.00
    90%, 32.00
    91%, 33.00
    92%, 33.00
    93%, 34.00
    94%, 34.00
    95%, 35.00
    96%, 36.00
    97%, 36.00
    98%, 37.00
    99%, 39.00
    === SYSTEM ===
    Windows 7 Home Premium 64-bit (6.1, Build 7601)
    DX Feature Level: 10.0
    AMD Phenom(tm) II X3 720 Processor (3 CPUs), ~2.8GHz
    4096MB RAM
    NVIDIA GeForce GTX 460, 1027MB, Driver Version 350.12
    Graphics Card Vendor Id 0x10de with Device ID 0xe22
    === SETTINGS ===
    Display: 1920x1080 (FullScreen) @ 59Hz VSync OFF
    Tessellation: 0
    LodScale: 1.000000
    PedLodBias: 0.000000
    VehicleLodBias: 0.000000
    ShadowQuality: 1
    ReflectionQuality: 0
    ReflectionMSAA: 0
    SSAO: 0
    AnisotropicFiltering: 2
    MSAA: 0
    MSAAFragments: 0
    MSAAQuality: 0
    TextureQuality: 0
    ParticleQuality: 0
    WaterQuality: 0
    GrassQuality: 0
    ShaderQuality: 0
    Shadow_SoftShadows: 1
    UltraShadows_Enabled: false
    Shadow_ParticleShadows: true
    Shadow_Distance: 1.000000
    Shadow_LongShadows: false
    Shadow_SplitZStart: 0.930000
    Shadow_SplitZEnd: 0.890000
    Shadow_aircraftExpWeight: 0.990000
    Shadow_DisableScreenSizeCheck: false
    Reflection_MipBlur: true
    FXAA_Enabled: true
    TXAA_Enabled: false
    Lighting_FogVolumes: true
    Shader_SSA: false
    DX_Version: 0
    CityDensity: 1.000000
    PedVarietyMultiplier: 0.000000
    VehicleVarietyMultiplier: 0.000000
    PostFX: 0
    DoF: false
    HdStreamingInFlight: false
    MaxLodScale: 0.000000
    MotionBlurStrength: 0.000000
  4. #103
    Membro Avatar de Proper
    Citação Citando Mexilhaozinho Ver mensagem
    Aí fica complicado, fera.
    Por mais atualizada que seja, o crack tem alterações no código do original, não tem como saber se a origem das instabilidades são culpa dele ou não.
    Última edição por Proper : 26-05-2015 às 17:36
    .: Nintendo Switch [SXOS] / Nintendo Wii U Deluxe [Haxchi] / Nintendo New 3DS XL [Luma3DS] / Nintendo Wii [BootMii] :.
    .: Sony PS4 Pro / Sony PS3 Super Slim / Sony PS2 Slim / Sony PSVita OLED / Microsoft Xbox One S :.
    .: Apple iPhone XR RED / Apple MacBook Air 2017 / Apple iPad 4 :.
  5. #104
    Gta 5 em uma config Gtx titan sli, melhor placa gaming atual. Fico abismado com a nitidez de detalhes.
    Última edição por Demented : 25-05-2015 às 19:47
    It's easier to fool people than to convince them that they have been fooled.Mark Twain
  6. #105
    Minha configuração é parecida com a sua (phenon x4, gtx 460 1gb, 16gb ram) e rodo sem problemas a versão original do game.
    Dá uma olhada para ver se está havendo superaquecimento, tenta limpar a placa de vídeo.
    - Conan, what is best in life?
    - To crush your enemies, see them driven before you... and to hear the lamentation of their women!
  7. #106
    Benchmark:
    existe um bug nesse jogo q eh a funcao "cover" (tecla Q)
    NAO use-a.
    dentro de veiculos ela muda o radio, e nao tem problema
    se eu uso ela, sai do jogo
    isso tanto faz se eh pirata ou nao
    do resto aqui roda liso, cai no minimo pruns 57, 58fps
    isso com textura e shadows no maximo e refletion no high (do high pro ultra nao tem diferença alguma)
    "The supreme misfortune is when theory outstrips performance." - Leonardo da Vinci
    "A hipocrisia é a homenagem que o vício presta à virtude" - François duc de la Rochefoucauld
    The devil is in the details
    "Be beer, my friend" - Bruse Leer
  8. #107
    Jan 2015
    Citação Citando Baskiat Ver mensagem
    NAO use-a.
    Aqui tá 100%, uso muito o cover, principalmente na missão do cemitério.
  9. #108
    Citação Citando Madefh Ver mensagem
    vc ta confundindo a tecla de agaixar com cover
  10. #109
    Jan 2015
    Agachar é no control, cover no Q. No cover o personagem corre e fica na parede, e só bota a cabeça pro lado se tu mirar, não?
  11. #110
    sim
    mas essa função na realidade eh bem inutil, pq nem precisa: só de ficar parado no canto a AI nem te acerta
    agaixar igual
    o q eu nao curto dessa função tambem eh q vc "gruda" no local q escolheu de cover
  12. #111
    Jan 2015
    sim
    agaixar igual
    Tem uma coisa boa nela: se você atirar sem mirar com o botão direito, o personagem atira sem botar a cara, só coloca a arma por cima/lado e sai metendo bala.
  13. #112
    hmmm, ai sim.
    consegui um jeito de arrumar aqui, agora entro em cover sem dar crash
    testarei essa de atirar sem bota a cara
  14. #113
    edited
    Última edição por Kazeshin1x : 09-06-2015 às 22:37
    Citação Citando HKMp5K Ver mensagem
    Não cara, pode me chamar de hater de pessoas sem personalidade.
    TT For All, For Life
  15. #114
    Citação Citando Kushito Ver mensagem
    Pessoal, dá uma olhada nisso (propaganda do Adrena rsrs):
    http://adrenaline.uol.com.br/2015/04...inimo-de-reais
    Artigo interessante, voltado mais para o mundo real do que para as configs ultra da vida...
    Não achei que compensou. Ele montou um PC que roda jogos da geração PS3 e 360 pelo preço de um next-gen. Esse PC não roda Ryse nem Assassin's Creed Unity por exemplo.
  16. #115
    Não sei se é o tópico apropriado, mas baixei hoje o GTA V e ele simplesmente não abre.
    Já tentei de (quase) tudo fuçando na internet. Parece que é um problema com quem tem gpu mobile e dois.
    Alguém tem uma luz?
    Não sou contra nem a favor, muito pelo contrário.
    Those who mind don't matter, and those who matter don't mind.
    Can't stop, won't stop.
  17. #116
    Mudem o título tosco desse tópico, ou...
    deixem assim mesmo
    "What if it was the case that the world revealed whatever goodness it contains in precise proportion to your desire for the best?" -Jordan Peterson
  18. #117
    Citação Citando henrique fonseca Ver mensagem
    ele montou um PC que roda games melhor que um ps4/xbox one
    Dell 7559 - DS Lite - PS4 - Thrustmaster T100 - T.flight Hotas 4 - PSVR
    PSN: matheusocBR / Steam: matheusoc
  19. #118
    Citação Citando Matheusoc Ver mensagem
    Discordo.
  20. #119
    Discordo.
    Mas qual daquelas configurações você se refere? Segundo a Digital Foundry (postei um dos artigos na primeira página), um Core i3 + GTX 750 Ti ou R7 260X tem apresentado resultados melhores que o PS4 nos jogos multiplataforma lançados até aqui.
    Então de fato a afirmação do colega mais acima faz todo o sentido.
  21. #120
    Citação Citando Proper Ver mensagem
    Me referi ao tópico da Adrenaline que o cara montou. O PC só rodou a 30FPS jogos da geração passada. Shadow of Mordor, Metro 2033, etc
    Última edição por henrique fonseca : 10-06-2015 às 8:06
  22. #121
    Padrão GTA V em low config
    As únicas configurações que rodaram abaixo de 30 dos foram aquelas bem low-end, com GTX 650 combinadas com um CPU fraco. Como disse, GTX 750 Ti ou R7 265 em conjunto com um Core i3 ou FX-6300 tiveram médias de 45 fps e já são opções melhores que estes novos consoles (com custo aproximado, como eles bem mostram).
    É importante dizer também que tanto Shadow of Mordor e Metro possuem versões bem inferiores na geração passada quando comparada com o PC, então não dá para resumir "são jogos da geração passada" se os antigos consoles não são capazes de rodá-los de maneira decente (o primeiro então é uma vergonha, lançaram só por lançar, a versão PS3 tem um IQ muito ruim e roda uma grande parte do tempo entre 10-15 fps).
    Última edição por Proper : 10-06-2015 às 11:42
  23. #122
    É importante dizer também que tanto Shadow of Mordor e Metro possuem versões bem inferiores na geração passada quando comparada com o PC (o primeiro particularmente é uma vergonha), então não dá para resumir "são jogos da geração passada" só porque eles existem mal e porcamente nos antigos consoles.
    Mas como eu disse, não deve rodar O AC Unity nem Ryse. Então como pode dizer que é melhor que um XONE ou PS4?
  24. #123
    galera tem o gta online pra pc tambem??
    No milk today
  25. #124
    É lógico que roda, cara (tá cheio de exemplo no You Tube, com os settings usado). Não no máximo, porque aí é querer demais, até porque os exemplos citados são bem ruins, já que nem nos consoles eles rodam no máximo, ACU é uma porcaria em otimização, nem no PS4 ele sustenta 30 FPS.
  26. #125
    Jan 2015
    Citação Citando MrWhite Ver mensagem
    Tem, via Rockstar Social Club. Joguei um pouco, achei bem bacana.
